Under-body AND through-body sway bar?, Good idea? Bad idea? impossible? |
bondo |
Jul 6 2004, 01:29 PM
My new 914 has front and rear sway bars.. the Carrera suspension I plan to put on it has a built in sway bar. Can I use both to have an effectively larger sway bar? Also, should I use the rear sway bar or take it off? (I've heard they don't do much for you)
Mueller |
Jul 6 2004, 01:36 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
i see no reason why it wouldn't work, is the thru-the-body swaybar adjustable?
that is what you'd want for sure since the under-the-body bar is not adjustable if you have to buy anything new for this proposed combo, you might as well pony up and buy a bigger new thru-the-body swaybar..Tarett or SmartRacing |
bondo |
Jul 6 2004, 01:42 PM
I think all I'd have to do is weld tabs onto the a-arms. I don't think the bar is adjustable, it's just a stock bar. I would of course get something adjustable if I bought something new.
TonyAKAVW |
Jul 6 2004, 01:46 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I know that you have access to a machine shop bondo, you could very easily make the through-body sway bar adjustable by fabricating something. Its amazing how much places charge for the bits that attach to the sway bar. The bars alone are not that expensive...
-Tony |
Jul 6 2004, 02:01 PM
Resident German Group: Admin Posts: 41,943 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(TonyAKAVW @ Jul 6 2004, 12:46 PM) I know that you have access to a machine shop bondo, you could very easily make the through-body sway bar adjustable by fabricating something. yupp, you can make your own droplinks and slider ... the underbody bar would give you a certain "preload" and if you make the through-bar adjusteable, you can finetune your settings. don't see any reason why this shouldn't work ... (IMG:style_emoticons/default/smash.gif) Andy |
Lo-Fi Version | Time is now: 26th December 2024 - 04:16 PM |
