> Changing Fan Belt in a /6 with A/C, Can't be hard, right?
iiibdsiil
post Jul 6 2004, 10:12 PM
Needs Door Locks
My fan belt is pretty loose on the 3.2. I figure for the extra $15, just replace it. Anyways, I have seen 911 belts done, kinda. I know there are the shims which you have to adjust accordingly.
So, my problems comes with the A/C and the shims. How does this work? Does each one have to be shimmed seperately, A/C and fan belt, or what?
Also, there is a special wrench for this too, correct? Since you have to take the center bolt out and not let the motor turn over?
Am I going to run into any problems with the fan being kinda close to the firewall? I know most of the /6 conversions, at least on the race cars, have a cut out in the firewall to make life easier. I a willing to do this at some point, but the belt is starting to scare me now.
Anything else I need to know?
Thanks in advance.
- Brett Smith
joea9146
post Jul 7 2004, 01:22 PM
The tension on the Airconditiong belt is adjusted by sliding the compressor from left to right... no shims required. The fan belt is where the shims are located. there should be a total of 6 shims all are required for the assembly to work properly. The shims go behind the pulley the more shims you put behind the pulley the losser the belt will fit. The shims push the pulley outward allowing the belt to drop down. No shims pushes the pulley in putting pressure on the belt pushing it upward. The extra shims must go between the Cone piece that is under the big nut.
Yes there is a special tool to hold the pulley while you lossen or tighten the nut.
I have a center hole which allows me to Zip the fan nut off with the impact gun. No holding required. Putting it on is a little tricky since I do not recommend the Impact gun for installation. With out a center hole this is a very difficult job.
Gint
post Jul 7 2004, 01:24 PM
Mike Ginter
I can't speak to the AC, but the fan belt does use shims and really isn't that hard. IF you have the factory tool to hold the pulley. I can take a pic later if necessary.
iiibdsiil
post Jul 7 2004, 02:15 PM
Needs Door Locks
I looked up the tool, on the other board, so I know what it looks like. I am going to go by my old job and borrow one from them, I know they have a couple.
And the A/C, I feel like an idiot. I knew that, lol.
Thanks guys.
ein 6er
post Jul 7 2004, 06:55 PM
brett,
it isn't that hard to do, just a little tricky reaching around the fan. keep track of how many shims are between the pully, so you know how many to put back on to tighten the belt. you may want to pull the engine lid if acess is a problem. also you really need to keep that pully wrench in the car, just in case, if it's a street car that is.
hey, you wouldn't by chance be going to the scca regional race at moroso this weekend would you? i'd love to see your 3.2.
ps, your link to your website doesn't work!
doug
- Lo-Fi Version Time is now: 26th December 2024 - 03:22 PM
