> oil leak again
ruddyboys
post Jul 7 2004, 06:57 PM
Hummel eigentümer
Found the oil leak, push rod tubes at head(I did put in new seals from PP). I did notice they were a little loose on the tube. There is also a leak on the left side jug against the block. Could this be just a torque problem or should I install new spacers/seals that were originally on them (I threw them out). Where is a good source for these, also I originally had aluminum, but have seen copper ones on evil-bay once, which is better.
Also having a leak at the jug/block cause a lack of power?
Rusty
post Jul 8 2004, 12:25 AM
Wanted: Engine case GA003709
I don't think a leak at the cylinder/case mating point would cause power problems. It would certainly be inconvienent... but nothing like a leak at the cylinder-to-head mating surface. That would be horrendous.
-Rusty (IMG:style_emoticons/default/smoke.gif)
ruddyboys
post Jul 8 2004, 04:52 AM
Hummel eigentümer
To be on the safe side I want to install the seals, any idea were to get them, and price
- Lo-Fi Version Time is now: 26th December 2024 - 06:37 AM
