> Jug size
ruddyboys
post Jul 8 2004, 01:16 PM
Hummel eigentümer
Is the outside diameter of a bigbore 96mm jug the same as the stock diameter?
bondo
post Jul 8 2004, 01:18 PM
Aww, that's not what I was hoping this thread was about (IMG:style_emoticons/default/smile.gif)
seanery
post Jul 8 2004, 01:19 PM
waiting to rebuild whitey!
A 96mm will fit in place of a 2.0 liter's 94mm without machine work to head or case. A 1.7 or 1.8 has a different answer.
ruddyboys
post Jul 8 2004, 01:23 PM
Hummel eigentümer
OK so if I need to order seals for the head and block, I should ask for the 2 liter seals.
I have a 70 1.7
seanery
post Jul 8 2004, 01:43 PM
I'm learning this as I go but, No seals between heads and cylinders. You'll need your heads machined unless you are using 2.0 heads. I'm not sure if the 96s will fit the 1.7 case without machining. Others will chime in I'm sure.
74914LE
post Jul 8 2004, 01:53 PM
You will need to have the heads milled out to fit the 96mm jugs. The case should work,
but it is a tight fit. I have done this twice. Both times I put the 1.8Ltr. Big Bore kit on a
1.7Ltr. case. With this set up, you get the thicker wall size on the cylinders, but the
heads must be enlarged.
74914LE
seanery
post Jul 8 2004, 02:12 PM
In my reading on the jug sizes, I've read a couple times that the 96s made for the 1.7s are junk (too thin) and that the 96s made for the 1.8 are the way to go on a 1.7 case. No experience, just passing on what I've read.
tat2dphreak
post Jul 8 2004, 02:20 PM
stoya, stoya, stoya
Sean... with 1.8 Heads you should be ok too... 1.8 jugs have the same o.d as 2.0 and the heads do not need to be flycut IIRC...
on the 1.7 heads you will have to cut for 96mm cylinders...
JWest
post Jul 8 2004, 02:24 PM
All cases have the same spigot size.
1.7 head registers are smaller than 1.8/2.0, which are the same.
Do not use the head seals - VW issued a bulletin to stop using them.
ruddyboys
post Jul 8 2004, 03:04 PM
Hummel eigentümer
I have the 96mm installed already, I am getting an oil leak around the jug and case and I suspect blow by on the head. I want to put the seals in to try to stop these problems. I need to know if I should buy the 2.0 seals. Does any one know were I can get the seals? AA has lists just one size for about 6 bucks each.
Joe Ricard
post Jul 8 2004, 03:28 PM
CUMONIWANNARACEU
Don't believe seas will fix this. However since you need to pulle the top end off the motor anyway have the cylinder lapped to the case and head. Then Apply the correct torque you will be fine. Little bit of orange/ copper permatex THIN LAYER at the case end. No more leaks.
markb
post Jul 8 2004, 04:04 PM
914less :(
QUOTE(bondo @ Jul 8 2004, 11:18 AM)
WoMBaT
post Jul 9 2004, 01:59 AM
QUOTE (bondo @ Jul 8 2004, 11:18 AM)
I say it's false advertising! Where's Johnny Cochran when you need him?
-Dan
- Lo-Fi Version Time is now: 26th December 2024 - 04:40 PM
