My v8 conversion thread, With pics, progress, questions ect!! |
nebreitling |
Sep 29 2004, 12:22 PM
QUOTE(Jaiderenegadesimpson V8 914 @ Sep 29 2004, 09:51 AM) QUOTE oh....just kidding 9one4racer Didn't you guys see this? If anything maybe 9one4racer needs to learn how to post smilies. (IMG:style_emoticons/default/rolleyes.gif) Felix still comes off as an ass. Andrew, nice work with all this! |
Brad Roberts |
Sep 29 2004, 03:02 PM
And if he really knew what was in Mikes kits... he would'nt be making "tongue in cheek" comments. The centerless ground "race" for the bearings to ride on is MUCHO expensive.
B |
Brad Roberts |
Sep 29 2004, 03:21 PM
QUOTE look like run of the mill brass Um.. Brass ?? No. WE make maybe 100$ on the front kit. The rear has less margin. WE are wide open too suggestions on how to make more money on the parts. Feel free to source everything for us. Months where spent finding/locating decent prices and parts for the kits. The rear requires quite a bit of machine work. Factor in all the time spent "hand holding" and we basically make NOTHING on them. I thought the whole idea was to make money ? Can you let us make a buck ? I'm sure I can figure out a way to build Chrysler products cheaper. B |
Mueller |
Sep 29 2004, 04:14 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
apology accepted and likewise..... (IMG:style_emoticons/default/beerchug.gif)
hope you are sitting down...that price does not include installation (IMG:style_emoticons/default/smash.gif) these bearings are not designed to replace the factory rubbing bushings, these are a better alternative to the hard plastic bushings that most people "upgrade" to no brass at all, the sleeve which goes onto the a-arm is 52100 solid rod, it is bored out, hardened and centerless ground per recommendations from Timken/Torrington..sure I could have used a chromoly sleeve or something else to hold costs down, but I choose not to..I'm not forcing anyone to buy these, too expensive or not to your liking, then pass on by and buy/make something else, no big deal to me still on the front kit: the other sleeve which goes into the factory housing is machined from seamless tubing brass bushings can be had for less than mine ($100 less), but I feel (and do others) that they fill a different segment (do a search for Elephant Racing) I don't talk negative about Chucks parts and I hope he does the same........ no need to remove your posts, it's not the end of the world, you failed to see the humor in my joke, I thought it was kinda funny that someone that could design an engine would have trouble posting a picture, I guess it was more of an inside joke....sorry if my humor is "different" (IMG:style_emoticons/default/smile.gif) how about starting over with your "introduction" with a brand new post/thread and introduce yourself....the GN motor has been discussed a few times in the last few years but as far as I know, you are the first one to have done one....besides, I'd love to pick your brain on engine design being that once my shop is finished, I'm going to start building a 1/4 scale Offenhauser Attached image(s) |
Andyrew |
Sep 29 2004, 04:27 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
9one4racer
Your a ok in my book! (IMG:style_emoticons/default/wavey.gif) I've seen muellers bearings and everything else he's made... and its alot of work.. He's a great guy,and he's helped me a lot, so I (like many others here) took offense when you cheap shoted his work. You've said what youve needed to say, and now I dont want this to go any farther. Take it privately if at all. mike, I'll drain a little oil.. good advice.. Heck I'll just change it... ( leave the filter though..) cus Its a rebuilt engine... all the fan talk.. I have a 16 in fan in there currently... Im sure its somewhere above 2500cfm.. If for some reason I have problems with it overheating, I will take the hood off to see if thats restricting it (doubt it..) then add the second fan in.. then if that doesnt do it, then I'll finish forming my ram air front bumper... ie fiberglass it in so there is no wishy washy air going in between the bumper and the body, so it goes through the front trunk.. If that doesnt work, I'll add some expanding foam to get rid of ALL the tiny air gaps.. AND IF THAT doesnt work, I'll change to marine exhaust hoses, and redo my whole cooling lines. BUUUUT my problem with overheating IS NOT when its running, but when it gets shut off. When it gets shut off, the temp slowly goes up, maybe to 230 (highest i've seen it) when the car is running, it will max at about 200 so i've seen. while the radiator stays at 190 and casually drops... (I have a temp on the radiator..) So any leads on that would be helpfull. Dankie guys.. |
lapuwali |
Sep 29 2004, 04:39 PM
QUOTE BUUUUT my problem with overheating IS NOT when its running, but when it gets shut off. When it gets shut off, the temp slowly goes up, maybe to 230 (highest i've seen it) when the car is running, it will max at about 200 so i've seen. while the radiator stays at 190 and casually drops... (I have a temp on the radiator..) This is actually pretty common with all water-cooled cars. The water is no longer circulating, but the heads are still at operating temperature. The heads run considerably hotter than the coolant flowing past it, so when the water stops flowing past it, the heads will heat up the water sitting there. There's no more heat being put into the heads (indeed, the water is drawing out what heat there is), so this actually isn't a problem. If you ran a cylinder head temp probe under a spark plug, I'd bet you'd see it running at around 250dF while driving, even if the coolant temp is steady at 200dF. Perfectly normal. Quite awhile ago some engines relied on a convection roll being formed in the cooling system to circulate the water, either in addition to a weak pump, or in place of a pump. Thermo-siphon is the commonly seen term. Such engines often did not show much of a temperature rise after shutoff, since they weren't depending on an engine-driven water pump to circulate the water. Most engines today completely depend on the water pump being there and operating at full flow to keep the coolant moving. |
soloracer |
Sep 29 2004, 04:50 PM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
QUOTE(9one4racer @ Sep 29 2004, 01:11 PM) (IMG:style_emoticons/default/Yack.gif) Just to clear things up: All I wanted to do from the outset was to give a little friendly advice. <snip> Just a little side note to Levi. My uncle used to say "If you can't take a joke, don't be a joke!" I always try to be cheerful and can take the occasional "punch to the nose". But we here in Canada don't punch our friends in the nose, literally or figuratively. (IMG:style_emoticons/default/beerchug.gif) I'd just like to say in closing that if this is the way this forum treats newbies then you guys are probably right and I shouldn't post here anymore. To those of you who are interested, please email me your questions and I will gladly answer them to the best of my ability. I do this because of the love of motorsport and Porsches and a genuine belief to help people learn from my mistakes. I will leave my posts on until the end of the week at which point I will remove them as per everyone's request. 9one4racer Dirt is for vegetables. Pavement is for racing!!! (IMG:style_emoticons/default/wavey.gif) P.S. Those smilies are for just you, Jaiderenegade Guys, I'm sure 9one4racer is good guy. He is Canadian after all. He's just from the eastern part of the country and they're not known to have much of a sense of humour. (IMG:style_emoticons/default/bootyshake.gif) |
Andyrew |
Sep 29 2004, 05:02 PM
James, thats kind of what I thought....
Currently I have to add in a resevor to my system.. because I have no "slack" of extra water.. My fill is directly in line with (the highest point on) the water lines. It is one in to the right, and its just like tacked on. Works great, till you shut off the system and the pressure builds up and the water escapes and goes into the catch tanks, then it boils if its over 220. (which it will creap up to... after the engine is shut off.. and james, you confirm my thoughts that that is ok.) Now.. to figure that one out.. gahh... Gona need some more fabricating... GAHHHHH! never ending process... Now if I can only figure out why the engine has no power... |
Mueller |
Sep 29 2004, 05:29 PM
QUOTE into sourcing and machining your parts. I am just providing your posters with lower cost, better thought-out alternatives. The American dollar goes alot further here in Canada (about 25-35% futher depending on exchange rate) and you guys don't have to pay any duty (just shipping) on automotive parts. From your reply you seem angry that you can't charge people more. like I posted earlier, there are other alternatives, I've lost a few sales to Chuck with his bronze bushings...some people have said cost was the driving factor, others just liked his design better and some people stick with the plastic since it's an even cheaper solution...I don't get mad or pissed off when they tell me they are buying or using something else.... I do wish I could make them less expensive, but I do this on the side, I can only afford to purchase so much stock and parts at a time. Believe it or not, there is another company selling kits pretty much just like the ones I am selling, and they cost $100 more than mine do....so if anything, I am doing a service by offering a less expensive alternative feel free to make a better/cheaper/more thought-out alternative...who knows, maybe I'd be willing to buy a set if I feel they are better than what I currently have...to me it's all about evolution and who knows what the next hot ticket will be (air bearings (IMG:style_emoticons/default/smile.gif) ) andyrew, it's been a while since I've played with water-cooled cars, have you driven and shut off your dads car to see what the cooling system does??? oh yea, a buddy of a buddy e-mailed me yesterday, he has a ratty 944 turbo he is looking to get about 3500 or so for, I hope to have pictures and details this weekend....supposedly runs strong, but needs cosmetics. |
Andyrew |
Sep 29 2004, 06:30 PM
QUOTE Thanks for the feedback and a big thanks to Mike and Andrew. You have my sincere promise no more negative posts. Heck dont worry about "negative posts" Once you get a little more posts under your belt, and show that you actually know what your talking about then we will have no problem accepting your "negative" posts. Just ask questions before you jump to conclusions (or say your conclusions aloud..) It saves you from getting into messes... Whenever I talk to someone with differing views, I always want to know their side of the story before I shut them down.. Sometimes they have valid info! Mike, thats a great price.. if all the bla bla bla.. you know... You thinking of getting it? I know you know their potential... I drive the turbo's and my moms car alot.. The only thing they do is maybe have the fan run for a little.. and the turbo recirculates the water to cool the turbo... but thats it... No boil over bla bla bla... BUT my friends 92 camero is a whole diff story.... |
propricer |
Sep 29 2004, 06:31 PM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
Andrew ... is your fan set up to run even after the engine stops ???
Andyrew |
Sep 29 2004, 06:34 PM
QUOTE(propricer @ Sep 29 2004, 05:31 PM) Andrew ... is your fan set up to run even after the engine stops ??? We're manually turning the fan on/off for now. So we're running it for a short time after the engine is shut off. |
dan10101 |
Sep 29 2004, 11:50 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
9one4racer
Welcome. Don't worry about the 'stuff', your not the first. It happens here and everywhere. We welcome your opinions. I'm curious about your setup. Do I see 2 radiators? Did you try one before and it didn't work? Which engine are you running? I'm the Dad in the project. The one that's suppose to be experienced. (IMG:style_emoticons/default/blink.gif) |
dan10101 |
Sep 30 2004, 12:05 AM
Aside from cooling, we're running into the power drag problem...
Here's what we know so far.. The problem: Under moderate to heavy throttle in 2-4 gear the car feels like there is a trailer loaded with a ton of bricks holding the car back. Under light throttle, the car responds well. The engine stops very quickly once the idle is turned down or timing is changed. In other words it's tight. Granted it's all new components. Tried both carbs. Problem is similar with both. A/F is close enough to not cause this problem. 12-13 under full throttle. Tried some different timing settings, no change. Possible problems. (brainstorming here so nothing gets ruled out) 1) Binding in the drive axles. 2) Missmatch in the connection from SBC to Transaxle 3) Internal engine problems. 4) Secondaries not opening. (ruled out with changing carbs) 5) Plugged Cat and/or muffler 6) flapper valve on the one exhaust manifold closing somehow forcing all exhaust thru the intake and out the other exhaust. 7) Transaxle failure(dragging) under high torque 8) brakes draggin. (rolls fine so not likely) 9) squating under throttle causing something to drag (like the axle) 10) Distributor to far advanced or retarded 11) Completly mismatched engine components killing all HP. There must be a couple more I'm missing Be blunt. We'd just like to solve this so he can start driving the car. We get to play with it again on Friday. So we'll have some time to think about next steps. Dan |
Sep 30 2004, 12:14 AM
Resident German Group: Admin Posts: 41,889 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE You may want to add a line above the 'BROWSE' button in the File Attachment area to let all us newbies know about the 10 post rule so we don't have to ask you veteran posters any more "stupid" questions. all this hot canadian air for nothing ... (IMG:style_emoticons/default/wink.gif) you don't need 10 posts to attach a picture. you can do so in your first post. there never was a limit on when you can attach pictures ... as for your engineering *advice*, yes, you're welcome to throw ideas at us, we all do all the time. but unless you have something better to show in your hands, don't piss on someone elses product that has proven to work very well. i just ordered a set of muellers roller Bear-Rings and i have no problem forking out the $400 for a set. why? because i know what my alternative would be and i have driven a few cars with them installed and i can tell the difference ... have you? some people, (IMG:style_emoticons/default/confused24.gif) Andy |
tesserra |
Sep 30 2004, 12:26 AM
Member Group: Members Posts: 210 Joined: 26-March 03 From: Lafayette CA Member No.: 479 |
Not accelerating under full throttle and high load is ususally fuel pressure. Check for clogged fuel filter.
Is your vacum advance hooked up to the right port on the carb? If it is hooked up to manifold vacum, not venturi vacum, you could have some goofy timing issues. Just a couple of thoughts, George |
dan10101 |
Sep 30 2004, 12:35 AM
QUOTE(tesserra @ Sep 29 2004, 10:26 PM) Not accelerating under full throttle and high load is ususally fuel pressure. Check for clogged fuel filter. Is your vacum advance hooked up to the right port on the carb? If it is hooked up to manifold vacum, not venturi vacum, you could have some goofy timing issues. Just a couple of thoughts, George Good Ideas. I'll double check the vaccum connection and it's result on the timing. Would low fuel pressure show up on an wideband A/F gauge? We're getting decent mixture. Seems like it would lean out if it was starving for fuel. |
dan10101 |
Sep 30 2004, 12:41 AM
QUOTE(Levi @ Sep 29 2004, 10:27 PM) Well maybe I'll chime in here....The engine sounded fine to me, its suppost to be tight...I think I mentioned that during my brief visit?? The fact that its hard starting tells me that the timing needs to be set correctly, if that doesn't fix the problem, its the carb.....( I don't remember what carb your running?? ALSO, try NOT refilling the radiator it may be just pushing out the excess fluid...it is possible to overfill the radiator!!!! It was fun to come bye and visit I'm really bummed I missed Andy..and by 15 minutes no less, Andy, It's to bad I live so far away, I would have that engine purring for you in short time. Feel free to PM me if you want to Levi, I remember what you said. I'm just not ruling anything out after our rod bearing fiasco. I just haven't owned an engine this tight in well, forever.. It starts ok. Just pump the gas a couple times then when it bites, keep it running until it warms up. The timing is definantly off. I can't get a read on the normal timing mark (can't see it against the firewall), and I'll need some instruction on how to do it properly with the Renegade damper pulley. My careful calculations and markings got us in the ballpark, but not close enough to rule out that as the problem. We have both a holley and a Qjet. Both seem to act about the same. |
Andyrew |
Sep 30 2004, 12:42 AM
Ok, let me point out that we have not given it 100% throttle yet... maybe 75%... but that SHOULD activate the secondary's...
Its got good low end low throttle tq. and it sounds good at that... now give it more throttle.. and it makes a very loud working noise...I really want to break in the rings.... but I dont want to do further damage if im causing damage.... |
neo914-6 |
Sep 30 2004, 01:07 AM
Try this: connect a vacuum gauge, idle at 900 rpm, and turn the distributor slowly until the vacuum peaks then back it off 1-2 pounds.
Lo-Fi Version | Time is now: 22nd November 2024 - 10:32 PM |
