My v8 conversion thread, With pics, progress, questions ect!! |
Andyrew |
Jul 8 2004, 07:36 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
And finally valves!
whew.. Sorry andy/brad, admin team... Oh heck its only 2megs.. Thanks drew Andrew Attached image(s) |
MattR |
Jul 8 2004, 07:47 PM
QUOTE(Andyrew @ Jul 8 2004, 05:23 PM) Anyone decifer this? front of block.. inside It appears to be a GM code (IMG:style_emoticons/default/wacko.gif) . Nice find! Keep the pics coming! |
Andyrew |
Jul 8 2004, 08:02 PM
The next series of pics I could post would be my flare progress.. but im not gona do that yet...
Andrew |
86motoman |
Jul 8 2004, 08:09 PM
Member Group: Members Posts: 200 Joined: 13-May 04 From: Walla Walla, WA Member No.: 2,064 |
Here is a site for all of your chevy numbers. http://www.mortec.com
(IMG:style_emoticons/default/biggrin.gif) |
smrz914 |
Jul 8 2004, 08:17 PM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
Andrew you will probably have to use an elecrtic pump depending on how you mount the alternator and water pump. BTW very nice find on the engine. And if you do use a electric pump put it up front.
skline |
Jul 8 2004, 08:23 PM
Ok, First off, the pistons are standard GM pistons, the cross hatching on the cylinders tells me it has been bored at least once, but not worn much since, the black on teh camshaft tells me that it doesnt have that many miles on it40 to 50k, the block is for sure a factory 4 bolt main block so it is a 350, the numbers you were referring to mean the engine was made in 4 of 83, what year car did you say it was in? If you give me the number stamped on the front pad on the block in front of the head and behind the alternator, I can tell you what the engine was originally installed in and with what options ie: HP rating, transmission, with or without A/C and so on. Also give me the casting number off the head and I can see what that is also. If they are 305 heads, you got lucky, they have the smaller chambers for higher compression, mine are 55cc, stock they run 58cc. Mine have been modified with larger valves which made the chambers smaller. Anything I can do to help you get it up ad going, let me know.
Scott Oh BTW, I worked for Chevrolet back in the 70's as an automatic transmission line mechanic. |
skline |
Jul 8 2004, 08:33 PM
Here is the fuel pump I am going to install. It was graciously donated by a club member. You cant run the stock fuel pump with the water pump or alternator mounted the way Renegade does.
Andyrew |
Jul 8 2004, 09:12 PM
I cant run the stock alternator the way its mounted from the factory, alrighty thats peachy with me.. Why cant I run the stock fuel pump? Its so perfect... (whine)
Scott.. The engine was in a 84 caprice... no clue why. Engine number.. ok C5F368754 VO219TJH Heads 333882.....74-80...350/400......76cc chambers Engine block 3970010....302.....69....4...Z-28 Camaro 3970010....327.....69....2...Trucks and industrial 3970010....350...69-80...2 or 4 http://www.914world.com/bbs2/index.php?act...70&st=40&hl=350 Need anything else? I'd like to know what the numbers are for it.. Andrew |
smrz914 |
Jul 9 2004, 12:23 AM
Andyrew,
Tell us how you are mounting the water pump and the alternator, then we can tell you why or why not you can run a stock fuel pump. |
Andyrew |
Jul 9 2004, 12:27 AM
I dont know how im mounting it. However Scott and Steve have the parts for me to mount it is how im going to mount it.
thesey914 |
Jul 9 2004, 12:51 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
QUOTE(Andyrew @ Jul 9 2004, 02:34 AM) Too bad it takes like 20 years to make that kind of texture... Also known as 'Patina' (IMG:style_emoticons/default/wink.gif) |
skline |
Jul 9 2004, 07:38 AM
QUOTE(Andyrew @ Jul 8 2004, 08:12 PM) The engine was in a 84 caprice... no clue why. Engine number.. ok C5F368754 VO219TJH I will find out today what those numbers mean and post them for you. The mounts I am sending you mount it off to the side both the alternator and the water pump, it will block where the fuel pump mounts. Trust me, I tried everything to make it not and there is just no way. |
Brett W |
Jul 9 2004, 07:56 AM
Advanced Member Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Good luck with your project.
If you have to go with a different crank might step up to a 400 crank and build a 383. Or step down to a 327 crank. I might be able to hook you up with a set of TRW Forged 11.0:1 327 pistons for pennies. Replace the cam with something with a little more hit. Call up Summit and snag a cam with some balls and really scare the neighbors. With a little time and a little extra money you can really make a sweet motor. Might try and find a set of aluminum heads on ebay or at a local machine shop for cheap too. Scott, I assume you are aware that the fuel pump you have will be loud as hell? We ran a few of those on race cars and they are noisy. You may have to fab some sort of isolator to cut the noise. When my Holley blue was mounted in the trunk I could hear the pump over then engine at idle. |
Andyrew |
Jul 12 2004, 08:51 PM
Progress pics from yesterday.
Got the engine completely appart, took out the lifters (that was a serious job... they where in dere good) Anyways, enough with the talk, heres the action. Attached image(s) |
Andyrew |
crank
Andyrew |
Jul 12 2004, 08:52 PM
Out of curiosity, is this timing chain stock?
Andyrew |
Jul 12 2004, 08:53 PM
Lifter w/o cleaning, Look at the wear, Can I still use these?
Andyrew |
Jul 12 2004, 08:54 PM
Mental note for myself, The rip on the left is the back of the engine. the right is the front of the engine.
Andyrew |
Jul 12 2004, 08:58 PM
Got scotts parts today (IMG:style_emoticons/default/smilie_pokal.gif)
Funny, the UPS guy comes out and has a clamp in his hand, asks if it goes with our stuff, Dad notices that its a clamp, says maybe, but tells him he can keep it. Scott, I got everything you listed in the box. I will list them, and if anything is missing, let me know and I'll call ups. The box was pretty ratty when I got it, but the parts where fine. Im sure the guys moving the box figured it was like 10 lbs, but then lifted it and it was Woops 50... Lol, Everything looks good though, I'll get some pics. Thanks Scott! Andrew (now Steve... OUT of curiosity, how far are you? I still have to rebuild my engine, so I have a while..) |
Andyrew |
Jul 12 2004, 09:16 PM
Ok, here a pic of the parts I got from scott. I will get another (amost complete) batch of parts from Steve.
Scott, let me know if there is any major parts missing here, a couple of clamps I dont care about. Also Scott, did you find out any details about that engine? Thanks Andrew Attached image(s) |
Lo-Fi Version | Time is now: 22nd November 2024 - 08:13 AM |
