My v8 conversion thread, With pics, progress, questions ect!! |
Andyrew |
Jul 23 2004, 11:55 AM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Im thinking 6k is my rev limit.
I just dont want it to fall off at 5k, I want it to pull to 6k. Oh ya, its a four bolt main... and I plan on putting roller rockers and possibly destrokeing the crank.. 327 or something... That should help, right? (IMG:style_emoticons/default/biggrin.gif) Andrew |
Mike T |
Jul 23 2004, 12:07 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
My car is an autocross car. No street. So the bracing is a bit extreme for what you would need on a street car.
Here is the front bracing along with the radiator setup. If you want to destroke your engine the 327 crank would be a good cost effective choice. The 3.25" stroke pistons are available cheap from Summit or other suppliers. If you wanted to go with a 3.00" stroke and make a 302 you'd have to find a large journal crank and that would cost more as would the pistons. Mike T Attached image(s) |
Mueller |
Jul 23 2004, 01:03 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Hey Mike,
is that a custom radiator or a one from Renegade/Rod Simpson?? |
dan10101 |
Jul 25 2004, 04:09 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Well, here is the cam that was suggested by the Machine shop.
Now that I'm comparing specs, it seems a bit odd in the Adv Dur vs the Dur @ .050. None of the cams I'm looking at have that much variation. Is this totally wrong for our purposes? It's an Elgin "Pro Stock" Cam These are the specs on the box. DURN DUR. @ .050 CAM LIFT Valve Lift Lobe Centers IN Ex IN Ex IN Ex IN Ex IN Ex 291 291 218 218 0.303 0.303 0.455 0.455 105 115 Thanks, Dan |
Mike T |
Jul 26 2004, 10:35 AM
QUOTE(Mueller @ Jul 23 2004, 11:03 AM) Hey Mike, is that a custom radiator or a one from Renegade/Rod Simpson?? I bought it used so I'm not sure but believe it's a Simpson. Seems to work well. Temps at this weekend's autocross were never over 200°. It's not a street car and temps were mid 70's. Never had the car running for more that 20 mins at a time. Sufficient for autocross I think. Mike T |
Andyrew |
Aug 3 2004, 09:01 PM
Heres an update...
Got the parts from Steve (very much earlyer than I expected. Thanks!!!) I have the bottom end assembled, the top end... well, silly me, I cant fine a stupid head bolt.. I assume I wont find one at the local flaps... So Im just going to hit pick and pull. Engine's painted... I'll paint, or clean the carb (depending on how bad it is..) and paint the air cleaner junk black with silver accents.. Should look pretty darn good! Heres a buncha pics. Attached image(s) |
Andyrew |
Aug 3 2004, 09:15 PM
The twin (huge) fans that I got from Steve... I think I'll just use one.. there 15in...
Andyrew |
Aug 3 2004, 09:21 PM
hehe... I know im going to be shot down for this one. But here goes nothing.
Steve dropped off this front hood, and honestly, I really like it! It will create a pull from the front hood, and it will allow for air to escape smoothly. Later on I'll cut the fender wells, and reinforce that area because of the strength lost from cutting the fenderwells.. But currently I think this will be perfect. Its a perfect design for my radiator and fan setup as well. I will be putting a grill in the opening, adding another layer of fiberglass to fill in any trouble area's, and for strenth, and finishing so it looks nice, and painting it all body color. ITS FUNCTIONAL..... Im no ricer.. Let me know what you think. Attached image(s) |
Andyrew |
Aug 3 2004, 09:24 PM
Adapter plate for the later model v8 (86 and up to the LS1) that will be for sale on ebay or whatnot soon. also the rails that hold the two radiator fans together.. Dont think im gona use it.
Andyrew |
Aug 3 2004, 09:27 PM
Cool trick stuff.
Harmonic balancer from renegade or whatnot. and hehe, remote oil filter, which I will tap into the lines and add a oil cooler, Yup, I dont want any over heating problems, my big ars aluminum radiator, big old fans, and this oil cooler, should prevent any of that problem. Besides all the engine stuff is clean, hot tanked, and everything should flow very nicely. Attached image(s) |
Andyrew |
Aug 3 2004, 09:28 PM
Water lines.. gona paint tomorrow or so.. (yes, if you dont know, I like keeping things clean..)
Andyrew |
Aug 3 2004, 09:31 PM
Boring single exhaust... One cat, one truck muff.. first few miles im going to do will be taking it down to a nice muff shop, and having them take out the cat. Shouldnt be that hard, not that much money.
Later on I'll spend some cash and do a nice, cool sounding dual exhaust. We have some interesting idea's.... Attached image(s) |
shoguneagle |
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Andyrew, you make the old parts look good. Hope they meet and exceed your needs along with being functional. It was good to meet you and your father. Enjoyed your car and what you are doing with it. Glad the parts are being used instead of rusting away.
I know you have a few holes to fill in parts needs. Let me know what they are. It appears I will be getting out of the 914 business until we move. Need to cut down on my P-Car reserves and get back involved when I get moved. Steve Hurt |
Andyrew |
Aug 3 2004, 09:34 PM
Alternator mount, and "custom" alternator... I'll just use my basically new alternator from pick and pull, spins better.
In the background is the smog pump... Can you guess what Im going to do with that?.. save it incase the Man says that all cars have to be smogged. Attached image(s) |
Andyrew |
Aug 3 2004, 09:36 PM
OH er.. ya..
Also my 9in Kevlar flywheel... Some interesting wear marks, but asside from those, it looks new. I'll save it for later, when I get a beeefy trani.. I'll use the 7in clutch Scott gave me for the time being.. mainly so that I break my clutch, and not my trani. |
Andyrew |
Aug 3 2004, 09:40 PM
Steve, so far, it looks like the only thing I need are the clutch extender (you have... Could use it in a week, or so, We'll drive down there... gota get outa the house), and a throwout bearing. I tried calling Rod simpson (cheapest) today but the guy didnt answer, so I'll call him tomorrow morn.
Next on my list Box of parts.. Reverse fittings.. some bolts, whatnot.. thermostat stuff, and a water pump!!!! Attached image(s) |
Andyrew |
Aug 3 2004, 09:42 PM
And last, but appropriately not least, is the engine mount bar..
Which I like.. Much better than the clamp two U clamps on with some square tubing, and go... (IMG:style_emoticons/default/laugh.gif) Andrew Attached image(s) |
Brad Roberts |
Aug 3 2004, 10:51 PM
Dont install the harmonic balancer until you get the spacer that goes behind it. It should be cheap from Renegade. It appears to be the only thing missing in your pics. If the balancer was installed on another engine (I know it was).. he may have not pulled off the spacer that was sitting behind it.
B |
Andyrew |
Aug 3 2004, 11:16 PM
Alright, Im sure Steve still has it on his engine.. If not, im going to get a throwout bearing from RSH, so I'll get one from him...(he seems to have the cheapest parts)
And ya, I actually was going to ask about that spacer... Thanks. Andrew |
Brad Roberts |
Aug 3 2004, 11:40 PM
Buy the throwout bearing from KEP. This is where everyone gets them from. Rod works from his house (no/low overhead) so yes his prices will be a tad cheaper than RHS.
B |
Lo-Fi Version | Time is now: 22nd November 2024 - 01:43 PM |
