> Rear trunk light, Replacement
Allan
post Jul 9 2004, 10:46 AM
Teenerless Weenie
I have a light fixture in my rear trunk but it is burned out and seems to be a sealed unit. Anybody know where to get these?
post Jul 9 2004, 10:59 AM
Resident German
QUOTE(Headrage @ Jul 9 2004, 09:46 AM)
i don't think they're sealed. (IMG:style_emoticons/default/idea.gif) (or are they?)
i believe the bulb is the same as the bulb in the interior light in your back-pad.
which also happens to be a common VW part (the bulb). you'll be able to get it at your local VW store ...
Andy
mike_the_man
post Jul 9 2004, 11:47 AM
I like stuff!
As far as I can tell it's the same bulb. Are you sure it's burned? It only comes on when the headlights are on. It's kinda a silly way to do things.
Allan
post Jul 9 2004, 12:27 PM
Teenerless Weenie
With just the head lights on? Well I guess they thought you would only need it at night while out on the road. I'll give it a try, thanks. (IMG:style_emoticons/default/blink.gif)
JWest
post Jul 9 2004, 12:51 PM
The trunk light is on the circuit that feeds the license plate lights. I think the lens should come off once it is unbolted, but it may be stuck from years of being attached.
efrenv
post Jul 9 2004, 01:09 PM
Check from inside the engine side.
Allan
post Jul 9 2004, 01:11 PM
Teenerless Weenie
I have had it out. It looks like a little sealed unit. No screws or clips to remove a cover.
- Lo-Fi Version Time is now: 26th December 2024 - 02:12 PM
