Fuse block for red wires from batt, EDIT: 3/06/13. not making kits anymore. |
moparrob |
Sep 24 2011, 10:31 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Is your panel basically the same as these pre-wired ones?
(IMG:http://www.914world.com/bbs2/uploads_offsite/bmcautos.com-11663-1316925088.1.jpg) BMC fuse panel |
Ian Stott |
Sep 25 2011, 11:41 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Cap'n, A member in Canada just had a fire last week. Fire originated at the 14 pin connector at the relay board. Probably damaged the wiring harness before he could get the batt disconnected. Wiring harness is pretty expensive and a fused red wire would have prevented that. Fuses shouldn't have to be too big. Max capacity of stock alternator is 55 amps. I think each red wire fused at 25 anps would be sufficient. Do you think that would not be enough? Just trying to get the info needed to make a decision. Thanks, Tom It would be interesting to know how and why a fire originated in the 14 pin connector. and why the fuses for some of the circuits that go through there failed to protect the wiring. The Cap'n I was disconnecting the 14 pin connector so I could clean up the board and the area around it, as soon as I touched the connector it got hot and I tried to pull it off the board but it was too hot to touch and then a puff of smoke and then flames, ran to evacuate the house and then went back to the garage and got the neg battery cable unhooked, so much smoke and it stinks! Ian Stott Moncton Canada |
Tom |
Sep 25 2011, 01:28 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Ian,
If your key was in the OFF position, the only power to the relay board is the two red wires from the battery, which are unfused. Tom |
Ian Stott |
Sep 25 2011, 01:31 PM
Ian, If your key was in the OFF position, the only power to the relay board is the two red wires from the battery, which are unfused. Tom Key was off, never again will I play with electrical without unhooking the batt. I am looking now at the different battery isolators, seems like the one Porsche sells is the one to get. Ian |
FourBlades |
Sep 26 2011, 08:04 AM
From Wreck to Rockin Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I am interested in getting a kit.
I also want to run my headlights and driving lights off relays. I'd like to run a new power line from the battery to the front of the car to 3 relays to power the lights (low, high, driving). It makes sense to me to fuse this line right next to the battery. Would that require 5 fuses in a block? Thanks, John |
stugray |
Sep 26 2011, 01:02 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I like the concept & that looks really clean, however why not use just one of these:
http://www.vteworld.com/content/electromec...anl/anlfuse.php They even have them with integral voltmeters: (IMG:http://www.914world.com/bbs2/uploads_offsite/site.unbeatablesale.com-10819-1317063725.1.gif) http://www.sears.com/shc/s/p_10153_12605_S...u=SPM5039089501 oohhh: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.parts-express.com-10819-1317064677.1.jpg) http://www.parts-express.com/pe/showdetl.c...tnumber=263-624 I would run one wire directly to the starter, then put a 50 Amp fuse for the rest of the car. Stu |
Tom |
Sep 26 2011, 01:15 PM
OK, the parts are on order and the following folks have PM's
wingnut86 Type 47 Fan X moparrob X 76-914 X michael 7810 X Panel Billy X rwilner Harpo X Jmuriz Vacca Rabite Gint X Sir Andy X Scarlet75 X bigkensteele X Rleog X Thanks, Tom |
moparrob |
Sep 26 2011, 01:42 PM
Thanks Tom, PM received. I was hoping you would respond to message #41 above so I could get a better idea as to the design of your fuse block and how it may differ from that pictured. Thanks.
Tom |
Sep 26 2011, 06:06 PM
Moparrob,
The fuse block looks the same, but the wires are smaller. I am supplying two 14 ga. and two 12 ga. wires. Did you not get the pics? E-mail me at t.powell@wavecable.com and I can send some more pics of what the kit includes and how it looks installed. Installed pics are on the first post of the thread. Tom |
moparrob |
Sep 26 2011, 09:14 PM
No problem. Got it. I'll send a check out as soon as I get some stamps (I am a Paypal addict) tomorrow.
Thanks. |
Tom |
Sep 27 2011, 11:09 AM
At this time all of the kits have been spoken for. After some questions, I realized I never put up a pic of what the kit contains. There have benn a few design changes; the plexiglass plate is dark grey and thicker, the female lugs are 4 14-16 lugs and 4 10-12 lugs, and the two stand-offs will be pvc pipe at about 1/2" diameter. Oh, and I'm adding a 15 amp fuse for a total of 7 fuses.
Kit doesn't show the heat shrink or two cable clamps, but they will be there. Here are a couple of pics: Tom Attached thumbnail(s) |
Tom |
Oct 2 2011, 02:31 PM
Update on the kits and those who expressed interest.
In post #47 there is a list of the folks that I sent a private message to on 26 Sept. The names with an X behind the name have answered the PM. The rest who haven't, are you still interested? Parts should be here later this week October 3-7. I can start sending kits on Friday or Saturday after receipt of payment. Thanks, Tom |
moparrob |
Oct 2 2011, 05:07 PM
Update on the kits and those who expressed interest. In post #47 there is a list of the folks that I sent a private message to on 26 Sept. The names with an X behind the name have answered the PM. The rest who haven't, are you still interested? Parts should be here later this week October 3-7. I can start sending kits on Friday or Saturday after receipt of payment. Thanks, Tom Pm sent |
Tom |
Oct 4 2011, 11:44 AM
Got the tracking number for the parts and they will be here Friday. I can ship kits as early as Saturday if payment has cleared.
The payment has been received from the following and you guys will get kits shipped Saturday. Montoya 73 2.0 Michael 7810 Harpo - sent you a PM. bigkensteele Rleog Thanks, Tom |
Gint |
Oct 4 2011, 05:44 PM
Mike Ginter Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I'm a horrible procrastinator with a check. But I actually mailed mine this morning. I'm in no particular rush to get it though. Thanks.
Tom |
Oct 4 2011, 07:26 PM
OK Gint, I'll keep on the look-out for it.
Thanks, Tom |
wingnut86 |
Oct 5 2011, 01:25 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
USPS "...Money Gram for Mongo..." (IMG:style_emoticons/default/biggrin.gif) is en route Tom. I'll send receipt numbers when I get home tonight...
(IMG:style_emoticons/default/happy11.gif) |
76-914 |
Oct 15 2011, 10:56 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Wow. Opened my kit tonight. It's very professionally done. I think Tom might be related to Mikey914 (IMG:style_emoticons/default/beerchug.gif)
moparrob |
Oct 15 2011, 11:08 PM
Yep, I got mine too. Thanks again - it looks good!
Tom |
Oct 16 2011, 07:23 AM
Thanks guys,
I have three to ship out Monday to Type47 Fan,wingnut86, and rwilner and then there a couple of guys I'm waiting on to see if they decided or not. If they don't, I already have several guys wanting to purchase the left over ones. Also adding a pic with the cable clamps installed and the fuses down graded. 20 amp in the outside fuses and 15 amp in the two inside ones. If one blows, I'll up it to the next higher. In this case, smaller is better. Thanks again, Tom Attached thumbnail(s) |
Lo-Fi Version | Time is now: 27th December 2024 - 10:44 AM |
