Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
This is the only number I could find on the case:
VC (WV logo in some kind of recycle logo) G108287 It's a 2.0L that had D-Jet on it. The heads are 914 2.0L heads. I got the engine with the car (spare engine). The PO claimed he took it of from a 914. Anyone recognizes this? ![]() |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,717 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
I think that the G cases are Bus cases.
It will work fine in a 914, but the oil temp sender location is different. |
cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
neither of these links have it, but that is either a replacement or exchange case.
http://www.thesamba.com/vw/archives/manual...ode_letters.php http://www.thesamba.com/vw/archives/info/engine_letters.php |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Volkswagen Canada. They had a rebuilding facility there. The product quality was questionable. As for the "oil temp sender" location difference, there IS no such issue. Porsche added one in the plate on the bottom of the case, VW didn't use one. The hole, as well as a plate to cover it, is still there. There are a number of differences in the cases, all dependent on the year and the original use for a particular unit, but they're essentially all the same, 1969 through 1979. T4s and busses used a different oil filler and dipstick setup than Porsche used, and carbureted engines had a mounting point for the fuel pump machined into a boss on the case.
The Cap'n |
Valy |
We're getting somewhere!
So the logo means that this is a recycled/replacement case, probably VW Canada. It seems to be pretty new, all clean and shinny. No leaks at all I'm rebuilding it since the DAPO broke one head, probably when he packed the engine for me. Then he drained the oil and let it stay with the sump open so all the dust could get in. There isn't too much dirt inside the open sump but who knows? Should I completely split the case to clean it or can I rinse it somehow without taking everything apart? Again, the case is perfectly sealed now. |
Ductech |
Member ![]() ![]() Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region ![]() |
If your there you might as well .... who knows who had there greasy mits inside that case. Might be worth looking at from the inside before investing time or even parts putting the jugs and heads back on.
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
....not a 914 case? (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Al Meredith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 972 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 ![]() |
I once bought a crew cab with a VW recycled ( arrows in a circle ) it was the quietest engine I,ve ever seen. I also aquired a similar engine from an auction at PAP and it had new heads on it. The heads has a part # printed on them. I used the case to build a 2056.
Valy |
....not a 914 case? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) It has all the 914 characteristics like heads, oil dip stick, etc. It's just a strange SN. |
Lo-Fi Version | Time is now: 19th April 2025 - 07:45 AM |
