4 Pages V  1 2 3 > »
> Inner long Chassis Stiff Kit install, the complete photo documentary
Trekkor
post Jul 18 2004, 11:44 PM
I do things...
O.K. folks, here it is from start to finish:
First you must remove the seam sealer and body tar from the inside corner of the longs.
Trekkor
post Jul 18 2004, 11:45 PM
I do things...
It is very thick in the corners.
Trekkor
post Jul 18 2004, 11:48 PM
I do things...
notice the bead of seam sealer that must come out so the sheet metal can fit to the floor pan tight.
Trekkor
post Jul 18 2004, 11:49 PM
I do things...
another
Trekkor
post Jul 18 2004, 11:51 PM
I do things...
an air chisel works very well to remove the material
Trekkor
post Jul 18 2004, 11:53 PM
I do things...
the width of the chisel point using careful, short bursts will quickly break out the tar.
Trekkor
post Jul 18 2004, 11:54 PM
I do things...
tar out
Trekkor
post Jul 18 2004, 11:56 PM
I do things...
without removal of the seam sealer and tar the sheet metal panels will not fit properly.
Trekkor
post Jul 18 2004, 11:57 PM
I do things...
passenger side drops right in.
Trekkor
post Jul 18 2004, 11:59 PM
I do things...
driver side in. the area around the e-brake handle needs to be worked to fit the contour (IMG:style_emoticons/default/smash.gif)
Trekkor
post Jul 19 2004, 12:01 AM
I do things...
more (IMG:style_emoticons/default/smash.gif)
I like to grind the edges for a good bite with the welder
Trekkor
post Jul 19 2004, 12:03 AM
I do things...
the inside corners need to be bent and worked into place (IMG:style_emoticons/default/smash.gif)
Trekkor
post Jul 19 2004, 12:04 AM
I do things...
other side
Trekkor
post Jul 19 2004, 12:06 AM
I do things...
back piece in .
3 sided dry fitment. Make sure it fits tight before any welding begins.
Trekkor
post Jul 19 2004, 12:11 AM
I do things...
(IMG:style_emoticons/default/welder.gif)
put the weld in the hole and burn into the car's long. then back fill the holes and make good contact into the long sheetmetal.
It takes practice. Use low voltage and fast wire speed.
Trekkor
post Jul 19 2004, 12:13 AM
I do things...
mask off the interior and windows so as not to damage them. Ask me how I know (IMG:style_emoticons/default/headbang.gif)
grind your work
jgiroux67
Guitar Shredder
What are the black ovals for that are on the passenger side long's? Are they for access to the heater hose or what?
Trekkor
post Jul 19 2004, 12:17 AM
I do things...
driver side and ground down
Trekkor
post Jul 19 2004, 12:18 AM
I do things...
back plate
Trekkor
post Jul 19 2004, 12:20 AM
I do things...
all three sides tied in (IMG:style_emoticons/default/welder.gif)
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 22nd November 2024 - 05:42 PM
