4 Pages V < 1 2 3 4 >
> Inner long Chassis Stiff Kit install, the complete photo documentary
Trekkor
post Jul 19 2004, 12:21 AM
Post #21
I do things...
corner detail shot
Trekkor
post Jul 19 2004, 12:23 AM
Post #22
I do things...
ready for paint
Trekkor
post Jul 19 2004, 12:24 AM
Post #23
I do things...
paint
Trekkor
post Jul 19 2004, 12:26 AM
Post #24
I do things...
rattle can , daddy (IMG:style_emoticons/default/cool_shades.gif)
Trekkor
post Jul 19 2004, 12:27 AM
Post #25
I do things...
spray it
Trekkor
post Jul 19 2004, 12:28 AM
Post #26
I do things...
bird's eye
Trekkor
post Jul 19 2004, 12:40 AM
Post #27
I do things...
The black ovals are tar pieces that cover access holes to the paper air tubes.
This install took about six hours.
Why do it?
Simple...It makes an instant, noticable differance in all around handling and steering response.
Obvious stiffening and strengthening can be had for 18#'s of metal.
Take out and leave out the sound deadening matte behind your back pad and it's a three pound investment.
The car will stay flatter and turn in smoother in the fast turns. My car does not lift the front wheels anymore.
I also added a rear stock sway bar to go with the package.
I believe that my car is now very well balanced for me and now I must gain experience to drive it well.
No understeer at all to speak of. Oversteer is only present when throttle induced ( the good kind ).
Come to Marina and feel the car.
Trekkor
Hope you enjoyed my little show (IMG:style_emoticons/default/welder.gif)
RON S.
post Jul 19 2004, 04:58 AM
Post #28
9140430841, FINALLY RUNNING
Great job, (IMG:style_emoticons/default/smilie_pokal.gif)
That is a great documentary on your install.
At bare minimum,you've given someone else an education,and some encouragement to tackle their own job.
You should let us know where you got your kit,and for how much$$$$.
Ron
sgomes
post Jul 19 2004, 06:38 AM
Post #29
Electric Member
Awesome job both with the welding and the pictorial! (I think that is the first time I've seen someone add the arrows ON THE CAR and not with photoshop!)
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
I vote for "classic" status! Anyone second the nomination? (IMG:style_emoticons/default/wavey.gif)
seanery
post Jul 19 2004, 08:10 AM
Post #30
waiting to rebuild whitey!
The kit is Engman's Inner Long Reinforcement kit Available Here
nebreitling
post Jul 19 2004, 01:19 PM
Post #31
Member Emeritus
QUOTE(sgomes @ Jul 19 2004, 04:38 AM)
I second that!
Trekkor just showed me this at the AX in Alameda. I must say that just jumping up and down on the longs, one can notice a substantial improvement.
i'm thinking about it now...
buck toenges
post Jul 19 2004, 01:33 PM
Post #32
How do you think that this "inner" kit compares with those "outer" longitunal kits? Same amount of stiffness? Less weight?
bperry
post Jul 19 2004, 04:55 PM
Post #33
Lurker
Out of curiousity, which welder did you use and did you use gas
or just flux wire?
--- bill
Katmanken
post Jul 19 2004, 05:19 PM
Post #34
You haven't seen me if anybody asks...
I'm still trying to figure out how he welded all those little holes...... (IMG:style_emoticons/default/blowtorch.gif)
to a painted metal chassis....... (IMG:style_emoticons/default/blink.gif)
Without going through a paint strip step.
Ken (IMG:style_emoticons/default/biggrin.gif)
Trekkor
post Jul 19 2004, 05:26 PM
Post #35
I do things...
Miller wire feeder mig welder.
When the wire hits the metel kit it burns right through the painted surface, then you swirl a puddle of metal to fill the hole. Very simple. You'll be a pro in ten minutes. (IMG:style_emoticons/default/wink.gif)
Trekkor
post Jul 19 2004, 05:32 PM
Post #36
I do things...
The secret to good welds on thin material is low voltage and fast wire speed. (IMG:style_emoticons/default/welder.gif)
Here's the settings I used.
seanery
post Jul 19 2004, 05:35 PM
Post #37
Does that have clickstops at each # for power? Mine has an infinite adjustment rheostat.
Trekkor
post Jul 19 2004, 05:45 PM
Post #38
I do things...
I know it clicks at each interval. I've never tried it between 'em. Not my machine.
Trek
Qarl
post Jul 19 2004, 05:46 PM
Post #39
Shriveled member
I have a question...
Is there a reason why you didn't weld all edges of the stiffening piece?
It appears from the photos that you welded the holes, and then only did a stitch weld around the outside perimieter of the stiffening kit.
Trekkor
post Jul 19 2004, 06:11 PM
Post #40
I do things...
Good question. (IMG:style_emoticons/default/idea.gif)
My understanding is that a deep spot weld every 3 inches and perimeter stiches are enough.
I don't know if full beads around the edges would do anything but add time...and weight! (IMG:style_emoticons/default/lol2.gif) \
KT
- Lo-Fi Version Time is now: 3rd April 2025 - 06:35 PM
