Apollo Racer Build Thread, Numeric 981 Shifter Upgrade |
rnellums |
Jul 2 2014, 08:22 AM
Professional Enthusiast Group: Members Posts: 1,667 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/thumb3d.gif) Any idea's on ground clearance? Did you modify the length of the down piece off the header flange? SS welding is not in my skill set. (IMG:style_emoticons/default/mad.gif) It won't be much. Maybe 3"... I pounded the puppies flat where they passed by my subframe,but other than that no mods. I hadn't welded SS before last night. I used my mig with some stainless wire and some co2-ar mix gas. It welded much like normal steel, but burn through was faster. I can't vouch for the weld strength, but this part isn't structural anyways. |
rnellums |
Jul 2 2014, 08:23 AM
brant |
Jul 2 2014, 08:24 AM
914 Wizard Group: Members Posts: 11,826 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
76-914 |
Jul 2 2014, 08:32 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,648 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/thumb3d.gif) Any idea's on ground clearance? Did you modify the length of the down piece off the header flange? SS welding is not in my skill set. (IMG:style_emoticons/default/mad.gif) It won't be much. Maybe 3"... I pounded the puppies flat where they passed by my subframe,but other than that no mods. I hadn't welded SS before last night. I used my mig with some stainless wire and some co2-ar mix gas. It welded much like normal steel, but burn through was faster. I can't vouch for the weld strength, but this part isn't structural anyways. Ahhhhh! Activity! (IMG:style_emoticons/default/biggrin.gif) I'm stuck with painting the house so not much 914 work for me. (IMG:style_emoticons/default/mad.gif) You da man for trying the SS weld. I guess I'll look into it some more. Honestly, after some recent gas welding again, I'm seriously looking at tig. |
BIGKAT_83 |
Jul 2 2014, 08:41 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Get some ear plugs Subaru's make some noise. The car Chris posted a video of has some long magnaflow mufflers on it.
Chris H. |
Jul 2 2014, 08:42 AM
Senior Member Group: Members Posts: 4,050 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Speaking of welding and grinding, I had a tiny piece of metal in my eye for a week! No wonder I've been a little irritable. Dang that drove me nuts. I'm wearing goggles from here on out.
rnellums |
Jul 7 2014, 09:39 PM
when ever is good for you I want a ride someday too are you wrenching this weekend? Sorry Brant, I was already out of town when I got this! I'm out of town this weekend too for a wedding, but I'll be wrenching every night this week or you can just wait till the weekend after next to come check it out. Hopefully it will be ready to go by then! Get some ear plugs Subaru's make some noise. The car Chris posted a video of has some long magnaflow mufflers on it. I'm looking forward to hearing how it sounds when I start it up for the first time with these exhaust pipes once my O2 sensors get in! Its just about ready to go, I really just need to mount the shifter! Then I can start the long road of optimization hopefully! Speaking of welding and grinding, I had a tiny piece of metal in my eye for a week! No wonder I've been a little irritable. Dang that drove me nuts. I'm wearing goggles from here on out. I agree, the worst is when you are still wearing safety glasses and somehow the frag finds its way around and into your eye! |
rnellums |
Jul 7 2014, 09:46 PM
I finished up the cable clutch bell crank linage tonight. Its allowing me to use the stock clutch cable to pull on the new subie clutch.
I re-used a pretty stout pulley axle that comes on the back of the transmission before you pull the tail cone. I had to drill a new hole to get it to fit in the right place, but there is plenty of room to drill. I picked up a couple of bronze bushings from Ace and machined the OD to fit into some steel pipe using my mini-lathe. Then I welded the whole bushing to a piece of angle iron and drilled a few holes so I could play with the throw ratios! My linkage from the bell crank to the throw out arm is currently a piece of allthread. I'll get something more official in there eventually, but this will work for test driving! The clutch pedal has a very different feel to it. The way I have the ratios set up right now it is much softer to push than a stock pedal, which makes it feel kind of weird. I can dial up the pedal pressure, but I think I'll go with it for right now. |
76-914 |
Jul 7 2014, 10:00 PM
(IMG:style_emoticons/default/piratenanner.gif) Way to go, Ross. Question; which wire off the tranny did you use for the VSS to the ECU. Is it the middle one of the 3 wires? I'm right where you are with your build. (IMG:style_emoticons/default/beerchug.gif)
rnellums |
Jul 10 2014, 11:03 AM
I put the car back on its wheels for the first time with the exhaust installed. The pipes exit right where I want them to, but my ground clearance is pretty suspect, if estimate between two and three inches! I hope my suspension is stiff enough!
The engine is remarkably quiet at idle, but it gets throaty pretty quick when you throttle up. Sorry no videos yet! The issue I'm having now is air in the coolant system. I can't seem to get the last bit out! Anyone have any tips? |
rnellums |
(IMG:style_emoticons/default/piratenanner.gif) Way to go, Ross. Question; which wire off the tranny did you use for the VSS to the ECU. Is it the middle one of the 3 wires? I'm right where you are with your build. (IMG:style_emoticons/default/beerchug.gif) I haven't dealt with that yet. Hopefully tonight! |
Chris H. |
Jul 10 2014, 11:37 AM
The issue I'm having now is air in the coolant system. I can't seem to get the last bit out! Anyone have any tips? Wow those pipes look mean! Love it! Careful backing out of the driveway (IMG:style_emoticons/default/biggrin.gif) ! On the air in the system, can't picture your setup but here are the things I have read: - Run the car with the radiator cap off to let the bubbles escape as freely as possible - Jack the car up at different angles, especially if you know where the pocket probably is. - DRIVE IT AROUND |
Scott S |
Jul 10 2014, 12:46 PM
Small Member Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
The issue I'm having now is air in the coolant system. I can't seem to get the last bit out! Anyone have any tips? Hi Ross - Get a hold of Bob (BIGKAT). He explained to me how his orange car was set up (cooling wise) and how he directly addressed the air issue. It was pretty fantanstic - making it litterally a non issue ever again. Cool stuff. |
904svo |
Jul 10 2014, 01:55 PM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
The issue I'm having now is air in the coolant system. I can't seem to get the last bit out! Anyone have any tips? Hi Ross - Get a hold of Bob (BIGKAT). He explained to me how his orange car was set up (cooling wise) and how he directly addressed the air issue. It was pretty fantanstic - making it litterally a non issue ever again. Cool stuff. This is how I purge the air out of my conversion, I used a radiator drain valve. You open the valve to let out all the air while the engine is running |
rnellums |
Jul 10 2014, 02:11 PM
This is how I purge the air out of my conversion, I used a radiator drain valve. You open the valve to let out all the air while the engine is running Perfect! I bought a t like that last night, but didn't think it would work. It looks like it just fits onto the heater core hoses? |
mgp4591 |
Jul 10 2014, 03:07 PM
914 Guru Group: Members Posts: 5,515 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
This is how I purge the air out of my conversion, I used a radiator drain valve. You open the valve to let out all the air while the engine is running Perfect! I bought a t like that last night, but didn't think it would work. It looks like it just fits onto the heater core hoses? That could work well. What's the highest point in your cooling system? Then install it there and that should do it. |
904svo |
Jul 10 2014, 04:34 PM
This is how I purge the air out of my conversion, I used a radiator drain valve. You open the valve to let out all the air while the engine is running Perfect! I bought a t like that last night, but didn't think it would work. It looks like it just fits onto the heater core hoses? That could work well. What's the highest point in your cooling system? Then install it there and that should do it. The way Subaru cools the engine it must be installed there!!!! They use a close loop system on start up, the air & steam must be removed before the thermostat opens. Thats why people have trouble with air in the system. |
bam914 |
Jul 10 2014, 08:52 PM
Member Group: Members Posts: 342 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
Best way to fill a cooling system and not have air in it.
http://www.amazon.com/UView-550000-Airlift...r/dp/B0002SRH5G |
Amenson |
Jul 11 2014, 06:48 AM
That's opposite lock!! Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None |
I had a heck of a time getting the air out of my system as well. I have an expansion tank and coolant reservoir in both the front and rear. I tried bleeding it with different combinations grade and radiator cap installations and still could not get the air out.
Eventually I worked it out by leaving both caps on and tight and heat cycling the system several times while making sure that the reservoirs were always full while it was sucking coolant back in. I am pretty sure that I had a few small leaks initially that were allowing coolant out and air back in also. Good luck. Scott |
76-914 |
Jul 11 2014, 12:30 PM
The issue I'm having now is air in the coolant system. I can't seem to get the last bit out! Anyone have any tips? Hi Ross - Get a hold of Bob (BIGKAT). He explained to me how his orange car was set up (cooling wise) and how he directly addressed the air issue. It was pretty fantanstic - making it litterally a non issue ever again. Cool stuff. This is how I purge the air out of my conversion, I used a radiator drain valve. You open the valve to let out all the air while the engine is running Copper (IMG:style_emoticons/default/blink.gif) Where were you when I was getting flamed for using copper. (IMG:style_emoticons/default/lol-2.gif) I hope you'll be kind enough to take a pic of the inside of one of those fittings. I know you've been running this set up long enough to see the results. My $$ says your good. Ross, 3/4" copper OD=7/8" nom 3/4" tee OD = 1" nom. Highjack over. EDIT: I just saw it's 1/2" copper so 1/2" pipe OD = 5/8" nom and 1/2 Tee OD = 3/4" |
Lo-Fi Version | Time is now: 1st January 2025 - 08:21 AM |
