21 Pages V « < 18 19 20 21 >
> Apollo Racer Build Thread, Numeric 981 Shifter Upgrade
Andyrew
post Jan 17 2017, 11:56 AM
Post #381
Spooling.... Please wait
QUOTE(rnellums @ Jan 16 2017, 08:26 PM) *
I had previously cut a small hole in the trunk firewall to allow clearance for small air filter. I have been trying to figure a way to clean it up since. This weekend I took a stab at making a manifold flip for the EZ30 using 1-R bend 2.5" tube. I wish I had used regular steel vs. Stainless because the welds came out so poorly. I may be making another one of these in the near future. Not sure if it will help or hurt performance, but I can run a proper air filter and can finally close my trunk back off.
Did you use stainless wire? You should be able to weld stainless JUST like steel. Fiddle with your settings a little till its right.
rnellums
post Jan 17 2017, 12:06 PM
Post #382
Professional Enthusiast
QUOTE(Andyrew @ Jan 17 2017, 10:56 AM) *
Yes on the stainless wire and argon shield gas. Stainless has much lower thermal conductivity, so it heats up locally much faster than carbon steel which is part of the issue. I was in a bit of a hurry though, as my NSX was sitting outside and snow was starting to fly! Probably shouldn't rush things so much next time (IMG:style_emoticons/default/wink.gif).
914pipe
post Jan 18 2017, 08:12 PM
Post #383
Say......TEEEEEEEN!!!!!
QUOTE(Alphaogre @ Apr 30 2015, 10:07 PM) *
QUOTE(rnellums @ Apr 30 2015, 09:05 PM) *
I was getting tired of how loud my exhaust was so I added in another muffler/crossover tonight. Much better!
Marty at MSDS was kind enough to supply the mandrel bends (super easy to work with, and inexpensive too!) And the center muffler is just a cherry bomb muffler from the FLAPS. I HAVEN'T SEALED it all up yet, but so far it looks promising!
Please post a video of how that sounds, I have been playing with the idea of building an exhaust like that for a few moths!
Please!
rnellums
post Jan 18 2017, 09:38 PM
Post #384
QUOTE(914pipe @ Jan 18 2017, 07:12 PM) *
Try this on for size:
https://www.youtube.com/watch?v=VhRmOOy6TJ0
rnellums
post Oct 9 2017, 07:52 PM
Post #385
Not much to update here, mostly just a lot of driving. I decided I wanted something to cover the firewall, so bought a bit of quilted vinyl on Ebay and sewed in some velcro strips to cover the firewall and a home-built console. I also built an adapter to mount up the 5-spd shift knob from a Fiat 124. The perfect size, the right shift pattern, genuinely vintage, and not too expensive!
I also switched over from a in-tank pump to an external pump with top mount swagelock fittings connected to custom bent pickup tubes inside the tanks.
post Oct 10 2017, 08:46 AM
Post #386
Snazzy! Looks like it came with the car. What prompted your fuel pump change over? I missed the video in the prior post, before . Sounds great. (IMG:style_emoticons/default/beerchug.gif)
rnellums
post Oct 10 2017, 12:27 PM
Post #387
The pump just cut out while driving, and I had to get a tow. The pump was running, but not pumping. The new system should be much more robust and easier to repair if needed.
post Oct 10 2017, 06:07 PM
Post #388
Makes sense. I changed mine because of my faulty diagnosis. I like your approach to keeping those lines above the tank. It's nice not having to (IMG:style_emoticons/default/sheeplove.gif) with kinking a line beneath! (IMG:style_emoticons/default/beerchug.gif) You, Ray and myself need to hook up at a RRC one day when it's in UT. I'd love to compare exhaust noises and notes in general. (IMG:style_emoticons/default/beerchug.gif)
greggearhead
post Jul 9 2018, 01:55 PM
Post #389
Ross let me take this on the Silver Summit rally because all my cars weren't running. It's a beast, super fun, and super easy to drive.
My step son fell in love with it so much we are building a similar one very soon.
Thanks Ross.
Are there pics of how you routed your pipes through the longs? Did I miss it?
rnellums
post Dec 23 2024, 06:55 AM
Post #390
Wow. Hard to believe my last post was 2017!
Lots of updates since then, but mostly on the life side vs the car side.
On the car side things have been pretty much trouble free. No major issues or malfunctions. One fuel pump failure but that's really just about it. Lots of carefree miles!
Since my last posts here there have been quite a few updates to the car, mostly related to drivability / maintainability improvements. Since this is going to be a pretty big update I'll breakdown each post by update area.
rnellums
post Dec 23 2024, 07:06 AM
Post #391
Gauges:
I've updated the water temp gauge to a more calibrated scale - still located in the left-most meter.
I've also re-painted the gauge bezel satin black installed a 911 electronic speedometer to read the wheel speed sensor pickup from the Subaru transmission. I believe I've covered it before, but I use a "SpeedoHealer" adapter to convert the pulse rate from the Subaru to a calibrated pulse rate for the 911 Speedo.
rnellums
post Dec 23 2024, 07:25 AM
Post #392
Suspension:
I installed new Konis earlier this fall. Nothing special, but significantly improved ride vs the old dampers.
rnellums
post Dec 23 2024, 07:26 AM
Post #393
Front
rnellums
post Dec 23 2024, 07:49 AM
Post #394
The torsion Springs on my engine decklid were starting to bend the decklid mounts a bit so I made this manual lift and prop setup.
rnellums
post Dec 23 2024, 08:22 AM
Post #395
I had originally used in in-tank subaru fuel pump, but after that left me stranded I switched to swagelock bulkhead fitting pickups and an external fuel pump.
This worked great, but left a large garish hole in my tank and meant I had to live with the relocated fuel sender and inaccurate readings.
This fall I bought a new tank (dansk, free shipping via RMEuropean) and reworked the setup to allow me to go back to using the stock expansion tank and sender location.
Lost of cursing trying to get the backing nuts on the swagelock installed, but I'm pretty happy with the result.
rnellums
post Dec 23 2024, 08:24 AM
Post #396
I also re-worked my fuel pump mount (previously hose clamed to a homemade bracket) using some 3D printed clamps I designed up.
rnellums
Post #397
I relocated my clutch master cylinder reservoir as well.
rnellums
post Dec 23 2024, 08:29 AM
Post #398
I had never been that happy with the MR2 shifter. I came upon a (relatively) inexpensive numeric shifter out of a GT4 and pulled the trigger. One difficulty is that the forward/back is reversed so I designed up a bellcrank linkage to convert it to the right orientation.
Its mounted to a baseplate that bolts up to the stock shifter mount points.
I also bought new shift cables, ball joints, and revised the rear coldwater linkage to pinch-clamp to remove slop.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
rnellums
post Dec 23 2024, 08:42 AM
Post #399
The new shifter meant that a new center console was needed. I knew I wanted to add heated seats eventually so I added a console with a roll top to hold the switches. It also houses the OBD port.
3D printed in pieces on my Voron 2.4.
Its currently a bit wider than I'd like so I may work a revision in the next few months.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
rnellums
post Dec 23 2024, 08:48 AM
Post #400
I have wanted to refinish my seats for a while so I finally took the plunge.
Removed the ancient foam, welded in new webbing pickups, and sewed new webbing
Then I reinforced the headrest mounts, added new foam to the bolters and wrapped with new vinyl.
For the inserts I went with a pendleton outdoor fabric in a throwback to my southwest roots. We'll see how well it wears.
34 User(s) are reading this topic (34 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 01:37 AM
