3 Pages V < 1 2 3 >
> Its Suspension Time!, anyone with tips tricks?
cha914
post Jan 14 2003, 05:55 PM
Post #21
MUSR 8 - 5lug conversion done wed - drive 500miles thrus
sorry, I got confused...when you said thickness, I thought you ment width of the disk...
Yea, I will start on those tonight probably...
Mueller
post Jan 14 2003, 06:12 PM
Post #22
914 Freak!
Back in the old days when I ran poly bushings instead of these really neat and surprisingly good deal needle bearings, LOL
I cut the groove with a Dremel as well, this is the bit to use, IMHO
(IMG:http://www.widgetsupply.com/dremel/cutter-burr/carbide/round/D-AD15.jpg)
Bleyseng
post Jan 14 2003, 07:41 PM
Post #23
Aircooled Baby!
Nice pic! Thanks, you sell those too??
Geoff (IMG:style_emoticons/default/beer.gif)
Brad Roberts
post Jan 14 2003, 07:44 PM
Post #24
914 Freak!
Mike would whore his ass out if he had too.
(IMG:style_emoticons/default/ar15.gif)
B
cha914
post Jan 14 2003, 09:13 PM
Post #25
hang in there mike...maybe in a year I will be giving you a call (IMG:style_emoticons/default/tongue.gif)
Thanks for all the help...let the games begin...
Tony
Gint
post Jan 14 2003, 11:08 PM
Post #26
Mike Ginter
This is what it looks like when you get it all out and bead blasted.
A weekend huh? Could happen if your goals aren't to CW the whole thing and you don't have problems.
Took me 2 months. But that's just me. Jp's older'n me, but I probably work slower.
cha914
post Jan 15 2003, 12:21 AM
Post #27
That looks real nice ginter...but mine are going to be rather brown and black...as long as they are functional it works for me...this is my car to learn on...
however, I am tired of learning how to fix it...I want to start learning how to drive it...after this weekend, or two, I will have taken everything off the car. So it will be time to have some fun with it.
Tony
Jeroen
post Jan 15 2003, 02:57 AM
Post #28
Region Association: Europe
wow! nice clean up!
did you have all that powdercoated, or is it DIY (por15 or something like it)?
good job!
Jeroen
Gint
post Jan 15 2003, 10:32 AM
Post #29
Mike Ginter
I bead blasted it and powder coated it all right in my garage. Some pics here.
gklinger
post Jan 15 2003, 11:33 AM
Post #30
doh!
QUOTE(Brad Roberts @ Jan 14 2003, 04:24 PM)
Just make a spiral path down the inside of them with something resembling a Dremel tool. I use a air grinder and carbide tip. Takes about 10 minutes per bushing. It really helps keep the grease in them.
I remember seeing on the PP board a post from someone who had done this, as well as drilling and tapping for zerk fittings. Is this necessary? It sounds like a good idea from the future maintenance aspect, but I'm wondering if it's worth it. If you did this, could you just pump a good grease in there, or would the special poly grease be preferred?
Garry
Brad Roberts
post Jan 15 2003, 01:08 PM
Post #31
914 Freak!
Hi Garry,
I think the zert is going a little far. I personally goop them up real well before assembly. The problem is: if you dont have some kind of groove in them, all the goop slides out when you slide them onto the control arms. When you purchase them, they come with a very very sticky grease. I heard from another list that the sticky stuff is the stuff used by pool companies for swimming pool seals. I buy the grease in a large tub instead of using the tiny packets that they send. I end up getting double the grease in my bushings from the start.
Welcome to the board. Good question.
B
Gint
post Jan 15 2003, 07:12 PM
Post #32
Mike Ginter
Brasshole, :sweet:
Where do you get the tub 'o grease? I need mass quantities for the Jeep bushings as well.
Dave_Darling
post Jan 16 2003, 11:57 AM
Post #33
914 Idiot
Jeez, Ginter--talk about a straight line.... (IMG:style_emoticons/default/laugh.gif)
--DD
Gint
post Jan 16 2003, 08:56 PM
Post #34
Mike Ginter
You know Dave, I read your reply and thought about it for all of 5 seconds....
Brad Roberts
post Jan 17 2003, 05:04 AM
Post #35
914 Freak!
Ginter,
I'll get the name of the stuff during the day (today) Bump this to the top so I can see it.
B
brant
post Jan 17 2003, 10:00 AM
Post #36
bump...
Gint
post Jan 17 2003, 01:49 PM
Post #37
Mike Ginter
Hi Brad!
(IMG:style_emoticons/default/wavey.gif)
Consider this a bump.
Gint
post Jan 17 2003, 04:47 PM
Post #38
Mike Ginter
'nother bump
Brad Roberts
post Jan 17 2003, 05:34 PM
Post #39
914 Freak!
The tubs are so large (with no markings) I cant even locate the last place I bought it from. Hang in there..Tony and I have been working on this since lunch.
B
Jeroen
post Jan 17 2003, 05:52 PM
Post #40
Hmmm... two guys looking for a heavy-duty lubricant
Scarry thought (IMG:style_emoticons/default/biggrin.gif)
Cheers,
Jeroen
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 28th November 2024 - 11:44 PM
