Battery tray, Bolt hole |
Archie |
Oct 1 2011, 01:31 PM
Member Group: Members Posts: 197 Joined: 23-September 09 From: Western Canada Member No.: 10,844 Region Association: Pacific Northwest |
Hello group,
Does anyone please have the ORIGINAL measurement for the centre of the battery hold-down clamp bolt hole from the inside lip of the tray? Thanks! |
type47 |
Oct 1 2011, 07:11 PM
my bad..... (IMG:style_emoticons/default/icon_bump.gif)
Archie |
Oct 1 2011, 10:16 PM
pilothyer |
Oct 1 2011, 10:52 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Archie
Mine is an original factory battery tray....not installed...the hole is 1/2 inch from the inside edge, and is 5/16 inch in diameter. I have a picture available, if needed........The hole is large enought for slight error since the welded nut threads on the support are much smaller. Jerry |
type47 |
Oct 2 2011, 04:17 PM
Er, probably not, Jim. Why do you say that? Didn't read your question carefully enough and posted info not requested.... |
Archie |
Oct 2 2011, 04:42 PM
Archie Mine is an original factory battery tray....not installed...the hole is 1/2 inch from the inside edge, and is 5/16 inch in diameter. I have a picture available, if needed........The hole is large enought for slight error since the welded nut threads on the support are much smaller. Jerry Thanks, Jerry. Exactly what I needed. |
Archie |
Oct 2 2011, 04:44 PM
Didn't read your question carefully enough and posted info not requested.... No problem, Jim. I was outside of a couple of glasses of Merlot when I posted anyway, so I thought it was me! |
Lo-Fi Version | Time is now: 2nd January 2025 - 12:16 PM |
