Phenolic Block Intake Gaskets for 4 Bolt Heads, Where can I get a set, quickly? |
bobhasissues |
Oct 3 2011, 08:48 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
Almost done reassembling my engine. My new AMC 2.0 heads have four bolts rather than three. My 2.0 gasket kit has the three bolt type intake gaskets. Where can I get the four bolt type without buying an entire gasket set?
I will drill the three hole gaskets if I absolutely have to, but would prefer to find a source for these gaskets. |
Cap'n Krusty |
Oct 3 2011, 08:52 PM
I can look tomorrow if you can't find something closer .......
The Cap'n |
McMark |
Oct 3 2011, 09:13 PM
Got a set here, $14 + shipping.
But, I bet if you call a euro shop tomorrow morning and ask for intake manifold gaskets for a 1971 914 1.7, or for a 1978 VW Bus 2.0, they'll be able to get them same day. Part number is: 022 129 707 F |
Oct 3 2011, 11:22 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If your old heads had three-bolt intakes, they were probably better heads than your new ones. And your old engine tin won't fit correctly; the spark plug holes will be in the wrong place. You'll need to trade someone for 1.7 or 1.8 tin.
--DD |
McMark |
Oct 4 2011, 09:27 AM
Not if it's AMC casting, reworked by Len Hoffmans to make Jake's LE heads. (IMG:style_emoticons/default/wink.gif)
Oct 4 2011, 05:55 PM
...That's why I said "probably"...
--DD |
Lo-Fi Version | Time is now: 21st December 2024 - 09:03 AM |
