euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Just saw this, and it may explain the leak that I can't seem to find. However, I am not running stainless, but stock exhaust. I don't run heat, so that's not an issue, but the backfire is. Does this problem happen with the stock steel exhausts too? I assume it would, but this thread seems to focus only on the stainless. TIA |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Yikes! Forget heat then... (IMG:style_emoticons/default/unsure.gif)
Phoenix914 |
Member ![]() ![]() Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States ![]() ![]() |
Here is a link to another battery operated CO detector. The one previously linked is discontinued from Home Depot.
http://www.amazon.com/dp/B004Y6V5CI/?tag=g..._sl_s7wc0ilmw_e Now I'm paranoid about my SS HEs. This isn't something I had thought about previously. Thanks for this thread! |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Attached thumbnail(s) ![]() |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
That looks just like a set I bought off of Ebay... back when I didn't know any better. In theory that could be fixed. But in practice, it's not worth it... and probably dangerous.
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Yep, had a perfect looking set of 2.0l exchangers took them off the parts car I could turn the end 180 degrees. (IMG:style_emoticons/default/dry.gif)
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
Whenever I bolt the heat exchangers to a motor, I check to see if they hold air by putting each cylinder to tdc and blowing into the muffler end of each port. I use a rubber stopper with an aluminum tube through it - something I made, looks like this, kind of.
(IMG:http://www.914world.com/bbs2/uploads_offsite/media.offbeatempire.com-11782-1443219910.1.jpg) This is also a good test to see if the exhaust is sealing at the head, which can be a problem, and can be done with the boxes on the car, just gotta take off the muffler. |
Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
Anyone have a clue as to who made them for "AA" back in 1979? Those are the ones I have & they seem to be just fine after 6k miles.
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I'm pretty sure that SSI made all of the 914 four-cylinder ones.
--DD |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,708 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I'm pretty sure that SSI made all of the 914 four-cylinder ones. (IMG:style_emoticons/default/agree.gif) |
Johny Blackstain |
I'm pretty sure that SSI made all of the 914 four-cylinder ones. --DD I'm pretty sure that SSI made all of the 914 four-cylinder ones. (IMG:style_emoticons/default/agree.gif) Has the quality of the materials or craftsmanship on the stainless exchangers gone down over the years? The factory exchangers rusted out after 4 years & nearly killed my Pop from CO poisoning, which is why he bought the stainless ones back in 79. |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Don't think so. A metalurgist for GE aircraft engines always warned me that my 914 SSI exchanger pipes would rust. He said it was due to the type of stainless tubing used.
He advised using a magnet on the tubing and the air shrouds. One was magnetic and the other was not, This was a guy used to casting turbine blades as a singe crystal and with air passages within. Never run my SSI's so still shiney. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I posted this last year, heating season is here again. These are big cracks, a tiny one you would not be able to hear would still be dangerous. These are not accident damaged. If you have a set on your car, grab the carbon monoxide detector from home and take a ride with the heat on and windows rolled up. There is a detector used in small aircraft also available. The last photo is how we now test for leaks using air pressure. Brad The engineering term is "work hardening" the problem exists from constant heat cycling till the SS fractures,you will notice the cracks are @ the start of the bends or in the middle of 2,the tube is under more stress in these areas. The larger outside radius is always the thinnest part of the tube. My experiences with this problem have indicated poor quality SS or the incorrect grade used ,old age also plays a part. To add to the problem closing the pipes in speeds up this issue that's why you don't see cracks outside the heatexchangers,many aftermarket SS systems come with a warning not to use exhaust wrap for that reason,SS pipe get very hot. |
EdwardBlume |
Tangerine or headers.Not the end of the world.
bretth |
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region ![]() |
So are you saying that if it is not magnetic it is less likely to fracture? I used to work GRC years ago not with metals though. I believe 304 and up are non ferris.
Brett Don't think so. A metalurgist for GE aircraft engines always warned me that my 914 SSI exchanger pipes would rust. He said it was due to the type of stainless tubing used. He advised using a magnet on the tubing and the air shrouds. One was magnetic and the other was not, This was a guy used to casting turbine blades as a singe crystal and with air passages within. Never run my SSI's so still shiney. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
I just checked my 1.7/1.8 SSI's and neither the tubes or the shields are magnetic which means the are 300 series SS, probably 304 one of the least expensive grades and should be good good choices. The 300 series are called 18-8 grades which is 18% Ni and 8% Chrome with most of the balance Iron.
The magnetic grades are 400 series and are just 12% Chrome balance mostly Iron. These grades can be hardened by heat treat so that's what hunting knives are made from. BTW I pressure tested mine are are OK. Barefoot |
914ltd |
Member ![]() ![]() Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
Hey 'teeners, It's time to bring this up again. There is a lot of good information on this thread about the SSI's. Also keep in mind that CO can impair your judgment. What might have been the root cause of a 914 accident? Don't dismiss how dangerous this can be! Brad |
GaroldShaffer |
Little late in bumping this thread. Never to late to check those SSI exchangers you have waiting to install.
914ltd |
Little late in bumping this thread. Never to late to check those SSI exchangers you have waiting to install. Thank you Garold. This IS an important thread for 914 owners. Garold or I or someone else should post this, at least, every heating season. Don't avoid using SSI's but be sure to check for CO if you do. Brad Mayeur |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,913 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 12:40 PM |
