Has anyone found a good gas cap gaket replacement |
moparrob |
Oct 17 2011, 08:59 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
I guess it makes sense that after 35 years the gasket in the gas cap would rot out. I don't want this gasket dropping any more debris into my tank, so I cut out the old gasket.
Does anyone make a rubber replacement or does anyone know if a cork or rubber one is still available? Thanks |
moparrob |
Oct 17 2011, 09:03 PM
I see this one for the plastic cap but for some reason I think the 75-76 are different...
new gasket for plastic cap Does anyone know for sure if it will work or not? |
moparrob |
Oct 17 2011, 09:06 PM
Steve |
Oct 17 2011, 09:14 PM
914 Guru Group: Members Posts: 5,765 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
70-73 is diferent. AA sells a cheap ugly replacement but it works.
http://www.autoatlanta.com/porsche-parts/p...?pn=343201551#a |
moparrob |
Oct 17 2011, 09:17 PM
Hmmm, I have a 74. Which one works for mine?
moparrob |
Oct 17 2011, 09:19 PM
It looks like AA sells the entire cap but not just the gasket
Steve |
Oct 17 2011, 09:28 PM
If its a screw on cap the gasket you listed will work. If its a bayonet type gas cap afaik you have to buy the whole cap.
moparrob |
Oct 17 2011, 09:46 PM
I've got the bayonet type.
Really? Why can't someone make a simple rubber seal which could be fit back under the 3 lugs of the bayonet mount? I looks like there is plenty of room to slide one in? |
bigkensteele |
Oct 17 2011, 10:49 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I've got the bayonet type. Really? Why can't someone make a simple rubber seal which could be fit back under the 3 lugs of the bayonet mount? I looks like there is plenty of room to slide one in? You should email Mark (aka Mikey914) at 914rubber.com. He is always looking for new stuff to produce. It may not happen soon enough for your need, but it would help the community! (IMG:style_emoticons/default/smile.gif) |
moparrob |
Oct 17 2011, 11:17 PM
Great idea. Will do.
Mikey914 |
Oct 18 2011, 09:37 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Simple part, just need a template to design tooling for. I figure 10 days. Most of that time will be wating for a sample the tooling will take me about 2 days tops.
$2.99 each on a group buy. Who needs them? No cash yet, just sign up if you are interested. |
McMark |
Oct 18 2011, 09:43 PM
I'll take 5.
Oct 18 2011, 09:56 PM
Resident German Group: Admin Posts: 41,944 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
moparrob |
Oct 18 2011, 10:05 PM
PM sent. I can send you an old gasket as a template if that helps.
pilothyer |
Oct 18 2011, 10:36 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Several please...........Jerry
Mr.242 |
Oct 18 2011, 11:11 PM
May your glass be smaller so it's always FULL! Group: Members Posts: 1,079 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
+3
Wahoo... |
bandjoey |
Oct 18 2011, 11:12 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
2
sean_v8_914 |
Oct 18 2011, 11:31 PM
Dude! you are the man.
i'm in for 5 |
sean_v8_914 |
Oct 18 2011, 11:32 PM
just make a whole 914, you're more than half way there
strawman |
Oct 19 2011, 12:35 AM
Senior Member Group: Members Posts: 885 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
I will take two!
Lo-Fi Version | Time is now: 26th December 2024 - 07:11 PM |
