Carb vs Injection, what do you think |
akellym |
Aug 13 2004, 06:44 AM
Eyes Of The Deep Battle Group: Members Posts: 598 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region |
I currently have injection on my 1.7 with the big bore kit. After several months I am still not able to get it to idle right when cold. Everything has been checked and replaced twice!
So I have been thinking about switching to carbs. I would like to know what you guys think about the idea. Thanks Attached thumbnail(s) |
ArtechnikA |
Aug 13 2004, 06:48 AM
elaborate on 'not right'... too fast? too slow ? too rich? too lean ?
did you change the cam? if not - twice may just not be enough... BTW - welcome - and - sweet car ! |
akellym |
Aug 13 2004, 06:55 AM
cam has not been replaced. idles to high then drops to not wanting to run until it gets hot and then runs great.
Jake Raby |
Aug 13 2004, 08:36 AM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Wait on the KitCarlson EMS..... You can keep it stock appearing and then dial it all in with the laptop!
Mark Henry |
Aug 13 2004, 09:11 AM
My first choice would be to fix the stock FI, some of the other members might be able to help you with this.
My second choice would be an aftermarket programmable FI system. You can use most of your stock FI intake, pump, etc. My last choice would be dual carbs, Weber’s or Dells, forget about the single progressive…it’s a piece of crap. Don’t forget to add a better dizzy and low-pressure fuel pump to the carb cost. |
eeyore |
Aug 13 2004, 09:24 AM
This is OT but, by gawd that's a beautiful shade of blue and amazing finish. Any idea on color name / paint code? (IMG:style_emoticons/default/boldblue.gif)
davep |
Aug 13 2004, 09:30 AM
914 Historian Group: Benefactors Posts: 5,225 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I'm with Brad and Mark. If the stock FI cannot easily be repaired, then go with aftermarket programmable FI.
SLITS |
Aug 13 2004, 09:31 AM
Closest apears to be L 98 P - Metallic Blue
akellym |
Aug 13 2004, 12:49 PM
the color is a early 90's 911 color, I believe is was called Electric Blue. From a distance is looks black, until you get close. At least that's what the body shop told me.
akellym |
Aug 13 2004, 12:51 PM
When is the KitCarlson EMS due out and and idea on cost.
Aug 13 2004, 01:53 PM
Resident German Group: Admin Posts: 41,954 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/agree.gif) FI is the way to go ...
wanna buy a set of freshly rebuild 40 Webbers ??? (IMG:style_emoticons/default/biggrin.gif) Andy |
Lo-Fi Version | Time is now: 2nd January 2025 - 07:37 PM |
