fixing door handles, tips, tricks, suggestions? |
914werke |
Dec 15 2011, 04:51 PM
"I got blisters on me fingers" Group: Members Posts: 11,038 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
URY914 |
Dec 15 2011, 06:35 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 124,451 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
EDIT I reuse the original pin on my repairs. Why not a nut & bolt arrangement? How do you re-use a peened alum rivit? 1. The pin is steel and not aluminum. 2. The orginal pin fits in the hole like it was was made for it. And it was. 3. A bolt is not the correct diameter. Which means a sloppy action. 4. The threads on a bolt will over time gall the povit surface of the handle. Now the repair bolt that AA sells for thier replacement flapper is better than a standard bolt because it has a large shoulder and few threads. But still not as good as the original pin. |
Lo-Fi Version | Time is now: 5th January 2025 - 03:38 AM |
