> rear spring identification, measure and post
sean_v8_914
post Dec 12 2011, 09:17 PM
Chingon 601
while spring diameter may not be exact science , it can be used as a guide to help us figure out aprox spring rate.
here are some measurements I took from the stash of springs
12.88mm = 200#
11.88 = 180#
11.26mm = 165 progressive
10.8mm = 140#?
9.7mm = stock X#
stugray
post Dec 12 2011, 11:10 PM
Welt
43/92 SP100 10.7 mm (100#)
67253 SP180 11.7mm (180#)
Eibach
336767 080.250.0225 9.86mm (225#)
1000.250.0175 9.90mm (175#)
So it seems that you can tell with the weltmeisters, but not the Eibachs.
sean_v8_914
post Dec 13 2011, 07:48 AM
Chingon 601
those eibachs would be teh 2.5" and 2.25" smaller type used on adjustable spring perches like ground control. your part number indicates 2.5"
stugray
post Dec 13 2011, 09:32 AM
Both Eibachs are 2.5" One I got from the PO is a 175# and the ones I just got from ground control are 225#
- Lo-Fi Version Time is now: 2nd January 2025 - 09:41 PM
