what did you do to your 914 today |
cconcepcion |
Mar 25 2018, 04:46 PM
Member Group: Members Posts: 51 Joined: 5-January 06 From: Peoria,Az Member No.: 5,370 |
JFG |
Mar 26 2018, 02:23 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I found what was left of the green/black oil temp wire in the harness. New wire ordered to repair/replace this.
With the help of my good lady (22 years of tolerance today) i made a template for one piece of the tinware on the fan end. It took 2 hours but it is spot on. Will make the other 2 pieces on wednesday and then fabricate all 3 on friday. |
stevend914 |
Mar 27 2018, 03:13 AM
Member Group: Members Posts: 377 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
Had the 123 distributor installed and rewired the fog lights to work without having to turn on the headlights.
bulitt |
Mar 27 2018, 07:08 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Did nothing to my 914 today because I don't own one!
But on the bright side, there is no rust on my floor (IMG:style_emoticons/default/smile.gif) Carry on! |
michael7810 |
Mar 27 2018, 09:45 AM
Senior Member Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
F@#K - I installed my new Sekurit windshield and new trim today...well almost. Got the glass in OK and had the trim on except the 3 clips on the driver's A pillar. The glass was sitting higher on that side compared to the rest of the glass (I noticed that side was high when dry fitting the glass without the butyl but figured it would be OK). The trim was riding on the glass and I just couldn't push it down enough to engage the last 3 clips. I used a piece of wood against the trim and was hitting it with the palm of my hand which worked on the other 16 clips. So I gently tapped the wood with a rubber mallet (this is where you call me a DA) and voila 4 cracks appeared from the edge. 3 are about 1" long and the 4th about 3" long. So I marked them with a sharpie and started cleaning up. By the time I finished the long crack grew about an inch. Rookie mistake for sure. So I've capitulated and contacted a glass shop who recently installed a China glass in my buddies 914. Need to getter dun for Rt 66 and I have no desire to start over. Had my (2nd) new windshield installed by a pro and it looks great. (IMG:style_emoticons/default/piratenanner.gif) Installer was a character, when my neighbor stopped by to take a look he asked him if he was the guy who broke the first windshield. |
76-914 |
Mar 27 2018, 06:23 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,653 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Pulled the glass rocker covers and rear fairing then sanded the rocker covers down. Tomorrow I'll blast the metal fairing and engine grilles. Should have those in paint by this weekend. Also, installed the seat belts from Seat Belt Planet.
mmichalik |
Mar 28 2018, 11:59 AM
MikeM Group: Members Posts: 739 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Put the first coat of primer on the fender after all the metal work and body work was completed. This one is just to fill the 80 grit scratches in the little bit of plastic that ended up using. Gonna knock it down with 180 grit and prime up the entire fender tomorrow. If you're interested http://www.2002and914.com/?p=543
saigon71 |
Mar 28 2018, 03:56 PM
Advanced Member Group: Members Posts: 2,007 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Pulled a rocker cover off for repair.
Inspected the long after collecting 4 years of daily driving debris. Not bad. |
Cairo94507 |
Mar 28 2018, 04:26 PM
Michael Group: Members Posts: 10,165 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Nice and clean. (IMG:style_emoticons/default/beerchug.gif)
mobymutt |
Mar 31 2018, 12:53 PM
Senior Member Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
JFG |
Mar 31 2018, 01:17 PM
After making the front tinware (around the fan) from card templates yesterday, today i trial fitted them and making just a couple of tweeks the fit pretty damn good!
ClayPerrine |
Mar 31 2018, 03:31 PM
Life's been good to me so far..... Group: Admin Posts: 15,972 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Got out this morning and finished up the carb refresh on Elwood. 12.7 to 1 mixture ratio at idle. Found the float level was too high on one bowl, it was percolating into the bore when sitting still, filling it with gas. Once adjusted, I went to start it and it just went click.
I think the starter took a (IMG:style_emoticons/default/stromberg.gif) I will pull it off tomorrow to check. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
Rodzilla |
Mar 31 2018, 05:26 PM
Newbie Group: Members Posts: 8 Joined: 20-March 18 From: Huntsville, Alabama Member No.: 21,985 Region Association: South East States |
Bought a very nice set of Pedrini wheels for it......
sb914 |
Mar 31 2018, 06:06 PM
Surf Guru Group: Members Posts: 4,418 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
euro911 |
Mar 31 2018, 06:32 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Replaced broken springs on the wife's dishwasher door (IMG:style_emoticons/default/laugh.gif) ... and to be honest, it was actually a pain in the ass job (IMG:style_emoticons/default/dry.gif)
In another concerted effort to clean up around here, dug through some 914 parts I don't need that were in the C-van storage container. Will be posting some good stuff in the classified section soon ... (IMG:style_emoticons/default/popcorn[1].gif) |
cali914 |
Mar 31 2018, 09:16 PM
cali914 Group: Members Posts: 456 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
SO.O.C914er |
Mar 31 2018, 10:18 PM
Senior Member Group: Members Posts: 1,469 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
Eddy looks like Belmont shores you were driving through. My daughter will be moving there next month.
mlindner |
Apr 1 2018, 09:36 AM
Senior Member Group: Members Posts: 1,601 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Mobymutt....do I see a 240 mph speedo?
sb914 |
Apr 1 2018, 09:40 AM
Coondog |
Apr 1 2018, 09:43 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Eddy looks like Belmont shores you were driving through. My daughter will be moving there next month. Yep!!short cruise through Belmont shore Best 914 Dash award.... (IMG:style_emoticons/default/first.gif) |
Lo-Fi Version | Time is now: 11th January 2025 - 11:33 PM |
