866 Pages V « < 526 527 528 529 530 > »
majkos1
post May 20 2018, 03:00 PM
Post #10541
went from this to .....
majkos1
post May 20 2018, 03:02 PM
Post #10542
To this! (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/shades.gif)
majkos1
post May 20 2018, 03:05 PM
Post #10543
I've practice on five doors before doing this....
majkos1
post May 20 2018, 03:18 PM
Post #10544
In a nut shell, here's the dimensions to finding the holes from outside.
I've taken pics of doing the first five doors
Got the hang of it,
Can do under 10 minutes.
I will put together step by step what's involve.... (IMG:style_emoticons/default/smash.gif)
SKL1
post May 20 2018, 03:29 PM
Post #10545
Red white and blue for Memorial Day....Attached Image Attached Image
ndfrigi
post May 20 2018, 03:59 PM
Post #10546
QUOTE(majkos1 @ May 20 2018, 02:05 PM) *
I believed inside the door has a factory welded screw and just need to drill it if you wanted to add right door side mirror.
marksteinhilber
post May 20 2018, 04:07 PM
Post #10547
QUOTE(ndfrigi @ May 20 2018, 02:59 PM) *
True, two easy ways. Drill up thru welded nut inside the door with a small drill to mak a pilot hole. Choose a size just smaller than the I’d of the threads. Then drill your clearance hole from a be outside. Second way is to use an ice pick from the inside to make a small center punch mark from the inside. Then centerpunch from the outside and drill the clearance hole till you just reach the nut. Viola!
TravisNeff
post May 20 2018, 04:10 PM
Post #10548
Welded up patches in the rear tail panel. Let me say I am going to be a real good grinder by the time I am done with this welding stuff. (IMG:style_emoticons/default/barf.gif)
marksteinhilber
post May 20 2018, 04:18 PM
Post #10549
I fixed an engine oil leak. Oil pressure switch on top of engine was leaking where center plastic is crimped inside the aluminum body. Took out the old one with a 1 inch deep socket and long needle nose pliers. Put new one in with a smear of thread sealant and a 22mm deep socket. Had to lower it down into place and start the threads using the long reach needle nose pliers. Also investigated the cursed L jet sticky throttle. Seems to need a shim washer now to center the throttle plate in the bore. Also suspect the extra spring causes the shaft to wear in the TB. May get it rebuilt with the ball bearings.Attached Image
majkos1
Post #10550
you are correct
those drill holes are exploratory drilling,
I then drill holes a bit bigger then tap
majkos1
post May 20 2018, 04:22 PM
Post #10551
QUOTE(marksteinhilber @ May 20 2018, 04:07 PM) *
That's what I did on first door.
Drill from inside.
Key trick is Center punch!
The door skin is thinner than the welded plate underneath.
If you locate the hole just right,creates a dimple.
Hence my pic.
majkos1
post May 20 2018, 04:26 PM
Post #10552
First door,
drilling out the holes,
I like the center punch idea from here too!
914 Ranch
post May 20 2018, 05:41 PM
Post #10553
Team Sharp where the 914 grow wings
Working on her tow vehicle. Putting insulation in and getting it street ready.
914 Ranch
post May 20 2018, 05:43 PM
Post #10554
Big Blu...The Elephantah...
Mueller
post May 21 2018, 10:00 AM
Post #10555
914 Freak!
On Sunday we drove up to Vacaville, CA for a Cars & Coffee and hang out with Dominic, he brought his original signal orange 914-6 and his 550 Spyder replica/tribute.
Afterwards we (my twins and I) headed to his house and then I got to a chance to drive the 550 for about 10 minutes up some twisties and along some nice country back roads. Super fun car.
Getting in and out of it sure is a challenge. Thanks again Dominic.
ndfrigi
post May 21 2018, 10:06 AM
Post #10556
QUOTE(914 Ranch @ May 20 2018, 04:41 PM) *
Sir Joe,
the view from rear facing your front cockpit of your trailer looks like a 914 seat. Is that intentional designing it?
914fahrer
post May 21 2018, 11:19 AM
Post #10557
Region Association: Germany
I polished my front Fender (IMG:style_emoticons/default/smile.gif)
ValcoOscar
post May 21 2018, 11:33 AM
Post #10558
Garage Life
I received 4 more 914 models from member ChicagoPete.
All 1/43 scale GT's (IMG:style_emoticons/default/piratenanner.gif)
Thank you...
JFG
post May 21 2018, 01:21 PM
Post #10559
For some reason the fuel pipe union at the tank started seeping. I was using an aluminium washer at that point. I bought some copper crush washers but one size was too small for the tank hole, the other size was right for the tank hole but too big for the pipe and would not tighten squarely. Third option was a teflon washer. This has worked but when slipping the rubber fuel hose on i loosened the nut!! After a cool down i got back to it and managed to get an adjustable spanner in to retighten. Fingers crossed it's fine tomorrow.
It's time to get started on the door cards. They were cut roughly for speakers and had been wet in the past which distorted them, the worst being around the speaker holes.
I filled the holes with hardboard and fibreglass on the weekend which enabled me to get the foam padding stuck down. Then it rained and i packed up for the night.
forrestkhaag
post May 21 2018, 05:25 PM
Post #10560
what did I do with the 914 today?........ NOTHING! (IMG:style_emoticons/default/hissyfit.gif)
i dropped off my carbs to the local Weber Guru and will await their return with corrected butterfly's, secondary venturi's and a few other slight modification in an attempt to get a reliable idle from warm to hot engine conditions. General interest pictures......... (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 13th January 2025 - 01:51 AM
