what did you do to your 914 today |
Steve |
Jul 9 2018, 07:28 AM
914 Guru Group: Members Posts: 5,780 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
For the 3rd brake light, I ran the ground in the engine compartment. For the positive, It’s just a spade connector on the rear tail light housing. Unplug the black/yellow brake light wire on the housing, plug in a spade T, plug the black/yellow wire and corvette 3rd brake light positive on it and your done. I also installed a two prong trailer plug on the engine lid, in case I need to remove the engine lid. I also used 1/4” shrink tubing for the positive wire to the trunk.
ValcoOscar |
Jul 9 2018, 08:44 AM
Garage Life Group: Members Posts: 2,482 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
For the 3rd brake light, I ran the ground in the engine compartment. For the positive, It’s just a spade connector on the rear tail light housing. Unplug the black/yellow brake light wire on the housing, plug in a spade T, plug the black/yellow wire and corvette 3rd brake light positive on it and your done. I also installed a two prong trailer plug on the engine lid, in case I need to remove the engine lid. I also used 1/4” shrink tubing for the positive wire to the trunk. Nice job Steve...good safety upgrade. Because of you I updated two of my cars to Spoke LEDs. Love them. I'll have to check out your 3rd brake light next time I see you. Oscar |
Steve |
Jul 9 2018, 01:00 PM
For the 3rd brake light, I ran the ground in the engine compartment. For the positive, It’s just a spade connector on the rear tail light housing. Unplug the black/yellow brake light wire on the housing, plug in a spade T, plug the black/yellow wire and corvette 3rd brake light positive on it and your done. I also installed a two prong trailer plug on the engine lid, in case I need to remove the engine lid. I also used 1/4” shrink tubing for the positive wire to the trunk. Nice job Steve...good safety upgrade. Because of you I updated two of my cars to Spoke LEDs. Love them. I'll have to check out your 3rd brake light next time I see you. Oscar I got the idea from Keith’s and Jim’s 914’s. They also both have it installed. |
sb914 |
Jul 9 2018, 04:34 PM
Surf Guru Group: Members Posts: 4,419 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
euro911 |
Jul 9 2018, 10:04 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Replaced the ignition switch in the 'BB' ... she's running fine (IMG:style_emoticons/default/biggrin.gif)
Also, finally got to test out the hydraulic clutch system that I installed a little over a year ago (IMG:style_emoticons/default/aktion035.gif) https://www.youtube.com/watch?v=/Tln0VF88ark |
mgp4591 |
Jul 9 2018, 11:33 PM
914 Guru Group: Members Posts: 5,529 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Picked up a 2011 WRX trans. I will get it to mate with my VQ35de using paper drawings... or not (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/av-943.gif) I've also got an idea for a not MR2 cable shift setup to fiddle with. Looking at the Subaru manual transmissions, I'm not impressed with the available gear ratios. I've been looking at the Audi 6 spd trans - looks badass when it's hooked to the EG33... (IMG:style_emoticons/default/drooley.gif) |
euro911 |
Jul 10 2018, 10:53 PM
Since I was able to get a new ignition switch and start the 'BB' up, I got to test out the hydraulic clutch system that I installed last year. Happy to report that it's working great and the 'BB' will be able to get loaded onto a transport under it's own power [to it's new home in South Carolina] (IMG:style_emoticons/default/sad2.gif)
So, in anticipation of someday getting back to work on the '71 ('Howard'), today I decided to order another Wilwood 260-6089 master cylinder, 260-1333 slave cylinder, and the awesome mounting kit from David Willouby (dwillouby) for it. I'll pick up tubing and the AN-3 fittings from Earl's Supply when I start in on that portion of the project ... (IMG:style_emoticons/default/chowtime.gif) Until then, more rough carpentry, electrical, drywall, finish carpentry, painting and carpeting tasks are all I can see me doing for the near future (IMG:style_emoticons/default/dry.gif) Maybe I'll have Howard ready for the Route-66 Run in 2019 ? ... (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
championgt1 |
Jul 11 2018, 09:02 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
914pipe |
Jul 11 2018, 10:59 PM
Say......TEEEEEEEN!!!!! Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
Got it shipped from Puerto Rico to our new home in Lenoir, NC. Was completely covered in salt and gave her a good wash. Now to figure out how to register it here! (IMG:style_emoticons/default/piratenanner.gif)
mgp4591 |
Jul 12 2018, 12:16 AM
Got it shipped from Puerto Rico to our new home in Lenoir, NC. Was completely covered in salt and gave her a good wash. Now to figure out how to register it here! (IMG:style_emoticons/default/piratenanner.gif) Welcome to the Mainland - Hope things are going well in the new home and location! (IMG:style_emoticons/default/driving.gif) |
mgp4591 |
Jul 12 2018, 12:18 AM
Adjustability is everything and I'm installing these shortly...
Mueller |
Jul 12 2018, 12:28 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
euro911 |
Jul 12 2018, 01:20 AM
I put most of the interior back together in the 'BB' ... had taken a lot of it apart when I was installing the hydraulic clutch system last year. Also started putting some spare parts in the trunk(s).
Almost ready for the transport company to come pick it up. I'd like to take it for a little drive around the neighborhood before they come though (IMG:style_emoticons/default/driving.gif) |
jfort |
Jul 12 2018, 03:15 PM
Senior Member Group: Members Posts: 1,145 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
Adjusted the clutch and the idle. It screams. Love it. DE in two weeks at Gratten MI.
Larmo63 |
Jul 12 2018, 04:42 PM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
ValcoOscar |
Jul 12 2018, 04:49 PM
Another relative arrived in my garage today.... (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) You need more garage space!!! (IMG:style_emoticons/default/smilie_pokal.gif) Nice stable mate Oscar |
ClayPerrine |
Jul 12 2018, 05:01 PM
Life's been good to me so far..... Group: Admin Posts: 15,981 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You need more garage space!!! (IMG:style_emoticons/default/agree.gif) I think EVERYONE on here needs more garage space. |
Larmo63 |
Jul 12 2018, 05:24 PM
Actually, I had my eye on this car on the Samba. He changed his ad the other day to a lower price and added "or trade?' to it.
I messaged him and described my '55 bug, he said he was interested. We met this morning, and in a no money deal, signed papers over to each other and drove off in each other's car(s). Weird, straight up trade. This is an extremely dry car from Prescott, Arizona and I got all of it's history too. It is just a lovely car, much better and peppier on the road than the bug. My poor 914 sits there. (I do drive it.) |
mgp4591 |
Jul 12 2018, 05:50 PM
Actually, I had my eye on this car on the Samba. He changed his ad the other day to a lower price and added "or trade?' to it. I messaged him and described my '55 bug, he said he was interested. We met this morning, and in a no money deal, signed papers over to each other and drove off in each other's car(s). Weird, straight up trade. This is an extremely dry car from Prescott, Arizona and I got all of it's history too. It is just a lovely car, much better and peppier on the road than the bug. My poor 914 sits there. (I do drive it.) The Bug was sweet but it's hard to beat a clean running Ghia - Congrats! (IMG:style_emoticons/default/aktion035.gif) |
Steve |
Jul 12 2018, 07:51 PM
Actually, I had my eye on this car on the Samba. He changed his ad the other day to a lower price and added "or trade?' to it. I messaged him and described my '55 bug, he said he was interested. We met this morning, and in a no money deal, signed papers over to each other and drove off in each other's car(s). Weird, straight up trade. This is an extremely dry car from Prescott, Arizona and I got all of it's history too. It is just a lovely car, much better and peppier on the road than the bug. My poor 914 sits there. (I do drive it.) The Bug was sweet but it's hard to beat a clean running Ghia - Congrats! (IMG:style_emoticons/default/aktion035.gif) Maybe it’s a 914 Karman thing, but I love Karman Ghias. That would of been a no brainer trade for me. Congrats!! |
Lo-Fi Version | Time is now: 15th January 2025 - 12:18 AM |
