what did you do to your 914 today |
ConeDodger |
Jul 15 2018, 04:37 PM
Apex killer! Group: Members Posts: 23,877 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I left a cars and coffee event like I thought I was in a Mustang!!! (IMG:style_emoticons/default/evilgrin.gif)
Attached thumbnail(s) |
euro911 |
Jul 15 2018, 11:20 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I left a cars and coffee event like I thought I was in a Mustang!!! (IMG:style_emoticons/default/evilgrin.gif) How many cars and/or pedestrians did you hit? (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/poke.gif) |
76-914 |
Jul 16 2018, 07:44 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,654 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Installed the fuel filter and pump into the front trunk so filter changes might be easier. Next will be to cover the new trunk floor board with Perlon and cover the vertical wall Nice work, Jim. The addition of that pressure gage is a smart idea. (IMG:style_emoticons/default/beerchug.gif) |
Shadowfax |
Jul 16 2018, 08:20 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
Placed a large order from 914Rubber (Windshield chrome trim, Butyl Cord, Windshield to Dash Seal, Windshield setting blocks, Windshield Chrome Retainer Clips, Front trunk plugs set of 9, Eyebrow grommets, Trunk lock gasket, Front Turn Signal Boots, Side marker electrical boots, Outer Door Seals, Sail Vinyl - German reproduction like OEM- Precision cut, Rear Trunk seal set - Upper and lower, Bumper Top Rubber Base Set, early front and rear bumper package) and finished removing what I could from the car for the repaint. Should have it back in about 3 weeks. Will go to the dealer later and order the windshield.
Thank God that my wife loves me and tolerates my car problem ... I mean hobby (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/white914.jpg) |
troth |
Jul 16 2018, 08:34 AM
Member Group: Members Posts: 156 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
Installed the fuel filter and pump into the front trunk so filter changes might be easier. Next will be to cover the new trunk floor board with Perlon and cover the vertical wall Nice work, Jim. The addition of that pressure gage is a smart idea. (IMG:style_emoticons/default/beerchug.gif) I've been wanting to put in a permanent pressure gage, but was afraid the heat and vibration in the engine compartment might not be so good for the gage. I like the idea of putting it in the frunk instead. Your set up is slick, but I'd like to think up something that doesn't require any hole drilling. Hmmmmm... |
troth |
Jul 16 2018, 08:38 AM
Sorry I missed you Dr Phil. I'm 30 miles west of Daytona. I will work something out for an event here. As Team NARP I have been board here and it is time to let my (Team Sharp) light shine. Thanks Joe, I'm in Gainesville for school during the spring and fall, that can't be too far from you... Hoping to make it to the 24 in January. I went to Daytona for Rennsport III awhile ago, but have never been to the 24 hours there. |
76-914 |
Jul 16 2018, 09:15 AM
Installed the fuel filter and pump into the front trunk so filter changes might be easier. Next will be to cover the new trunk floor board with Perlon and cover the vertical wall Nice work, Jim. The addition of that pressure gage is a smart idea. (IMG:style_emoticons/default/beerchug.gif) I've been wanting to put in a permanent pressure gage, but was afraid the heat and vibration in the engine compartment might not be so good for the gage. I like the idea of putting it in the frunk instead. Your set up is slick, but I'd like to think up something that doesn't require any hole drilling. Hmmmmm... Use a glycerine filled (liquid filled) gage. (IMG:style_emoticons/default/beerchug.gif) |
Larmo63 |
Jul 16 2018, 09:11 PM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
My first hot rod was a Ghia. A '64 that I put 356 Super 90 in. Built the car in '70. Somehow I just can't stop playing with them. Parked Carerror by the lake today, working in her garage space. Need to have an event here. Joe is having his own event there....... |
jim_hoyland |
Jul 17 2018, 04:45 AM
Get that VIN ? Group: Members Posts: 9,577 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Installed the fuel filter and pump into the front trunk so filter changes might be easier. Next will be to cover the new trunk floor board with Perlon and cover the vertical wall Nice work, Jim. The addition of that pressure gage is a smart idea. (IMG:style_emoticons/default/beerchug.gif) I've been wanting to put in a permanent pressure gage, but was afraid the heat and vibration in the engine compartment might not be so good for the gage. I like the idea of putting it in the frunk instead. Your set up is slick, but I'd like to think up something that doesn't require any hole drilling. Hmmmmm... Glycerine filled gauge is a must; No holes drilled. The inlet was routed though the hole previously used for the washer tank pressure line from the spare tire. The outlet passes though a hole in my bracket, but then passes through the location of the 1.8L fuel pump location. The blister plate has been removed. Subsequently, a lean cover is fitted over the entire unit for safety. Attached image(s) |
jim_hoyland |
Jul 17 2018, 12:44 PM
Installed a brand new 914Rubber front trunk floorboard. The plywood and Perlon is 1st rate !
I added an APS door pull to lift the board. Next up is new Perlon for the front trunk wall; already test fitted, it’s a better fit than the original (IMG:style_emoticons/default/smile.gif) Attached image(s) |
Nie Zu Alt |
Jul 17 2018, 11:34 PM
Member Group: Members Posts: 173 Joined: 1-June 05 From: Centennial, CO Member No.: 4,184 Region Association: Rocky Mountains |
I started work on the engine bay clean-up. First was the removal of the Dynamat stuck to the firewall. A heat gun, scraper, and two hours later, it is off. What a pain in the butt. I'm glad I removed it as the P.O. applied it over surface rust. Next up is to take it to metal, prime and paint.
Thanks, Doug |
JFG |
Jul 18 2018, 12:03 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
A bit of a list of small jobs today
Ordered my registration plates now that dvla (dmv) have sent me a reg number. Fitted the passenger door panel and fixings. colour sanded and polished the passenger door (followed by an extensive clean up of the mess over the rest of the car) painted some missed bits under the driver side long/door step Realigned the front bumper bracket as it seemed twisted preventing the bumper lining up properly The reg plates should take a week to arrive. My goal is to have the car ready to drive the day they arrive. A little over 2 years of work and it's so nearly ready. |
DRPHIL914 |
Jul 18 2018, 12:56 PM
Dr. Phil Group: Members Posts: 5,811 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Installed the fuel filter and pump into the front trunk so filter changes might be easier. Next will be to cover the new trunk floor board with Perlon and cover the vertical wall Nice work, Jim. The addition of that pressure gage is a smart idea. (IMG:style_emoticons/default/beerchug.gif) I've been wanting to put in a permanent pressure gage, but was afraid the heat and vibration in the engine compartment might not be so good for the gage. I like the idea of putting it in the frunk instead. Your set up is slick, but I'd like to think up something that doesn't require any hole drilling. Hmmmmm... Glycerine filled gauge is a must; No holes drilled. The inlet was routed though the hole previously used for the washer tank pressure line from the spare tire. The outlet passes though a hole in my bracket, but then passes through the location of the 1.8L fuel pump location. The blister plate has been removed. Subsequently, a lean cover is fitted over the entire unit for safety. Jim this looks great! The boxster spare looks like it fits perfect as well! not as deep as the space saver! I need to start shopping for one too, but the prices have been going up it seems the parts resellers on ebay are asking more and more for those. |
JmuRiz |
Jul 18 2018, 01:56 PM
914 Guru Group: Members Posts: 5,522 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Maybe it’s a 914 Karman thing, but I love Karman Ghias. That would of been a no brainer trade for me. Congrats!! If I decide to keep the '70 Ghia, I have a spare rebuilt 1720cc type 616 motor I can toss in there (IMG:style_emoticons/default/aktion035.gif)(IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/beer.gif) I have one of those in my other old car, great choice! ~100hp of fury (IMG:style_emoticons/default/biggrin.gif) |
76-914 |
Jul 18 2018, 06:25 PM
Finally got around to registering the 1970 red car; 9 months later. (IMG:style_emoticons/default/blink.gif)
DRPHIL914 |
Jul 18 2018, 09:17 PM
i bought more stuff from 914rubber, i looked at it, oh and i paid for the new front windshield!
euro911 |
Jul 18 2018, 10:43 PM
I took delivery of the Wilwood hydraulic cylinders and the mounting bracketry from David Willouby (dwillouby) to eventually do the conversion on the '71 (IMG:style_emoticons/default/biggrin.gif)
Mailed the title for the 'BB' to Bill (bill1963) (IMG:style_emoticons/default/dry.gif) Otherwise, just been cranking away at my den/music studio remodel. Will finish up the drywall tomorrow ... ... then move on to the insulation and drywall installation to finish the old front porch project. |
Mueller |
Jul 18 2018, 10:51 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
1st I tipped over a tool box.... made so much noise a few neighbors came outside to see what the ruckus was.
Then I removed some sheet metal from the 914. |
Mueller |
Jul 18 2018, 10:53 PM
Yes, that old Bridgeport vice took a huge chunk out of my driveway.
Chris914n6 |
Jul 19 2018, 01:00 AM
Jackstands are my life. Group: Members Posts: 3,431 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
1st I tipped over a tool box.... made so much noise a few neighbors came outside to see what the ruckus was. Then I removed some sheet metal from the 914. That's a clean set of holes. It's always been my opinion that RH cuts too much out with no regard for structural integrity. I might have you beat on garage noise though... Working on Dads old 73 Chevy truck w/454. Shut if off, ran a little extra long then backfired. Next door neighbor came out with his gun. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/ar15.gif) |
Lo-Fi Version | Time is now: 15th January 2025 - 04:08 AM |
