what did you do to your 914 today |
DRPHIL914 |
Nov 7 2018, 12:02 PM
Dr. Phil Group: Members Posts: 5,811 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i got some interesting comments on my badge from Restoration Design . mostly it confuswd people that were not aware that there was an RS version (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/av-943.gif)
and many wanted to know what that stood for- Rust Special is what i told them Attached thumbnail(s) |
euro911 |
Nov 7 2018, 12:30 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Jonathan Livesay |
Nov 7 2018, 12:51 PM
Senior Member Group: Members Posts: 745 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Nice. What gauge are you connecting it to? Not quite sure. VDO cockpit or the one that Dr. 914 sells or maybe have NHW speedo build one to look stock(ish). Any suggestions?No - was hoping you could tell me (IMG:style_emoticons/default/laugh.gif) ... I just happen to have a couple of spare 911 pressure senders and like how you did your set up. I have a couple options. I remember getting a triple gauge unit from Kapt Kaos a decade or so ago ... will have to look for it to see if it indeed has a pressure gauge. If so, it will need some LED strip lighting to match the gauges that Timothy ( @timothy_nd28 ) did up for our '71's original dash gauges. The car didn't originally come with a center console, but I do have one, so another option would be to install a small pressure gauge (if I know which gauge to get) (IMG:style_emoticons/default/unsure.gif) I need to fish an additional wire from the engine bay to the dash for an oil temperature gauge too. The car didn't come with a temp sender either, but I have a Jonsey taco plate and VDO sender earmarked for it (IMG:style_emoticons/default/smile.gif) Let me know which route you take (IMG:style_emoticons/default/popcorn[1].gif) https://autoplicity.com/82527-vdo-gauges-vd...BCABEgJhZ_D_BwE https://autoplicity.com/259409-vdo-gauges-3...e-sending-units This gauge is about 8mm smaller in diameter than the original console gauges, but it's got a similar appearance. I'm leaning towards it especially since I'm not putting it in a center console. Unless someone messed with it you should be able to find the wire for oil temp. starting with a connection down around the passenger side of the engine shelf and terminating at one of a trio of plastic covered spade connectors in the center tunnel right next to the shift lever. All wiring harnesses had the wires for center consoles, they just didn't connect to anything. |
peteyd |
Nov 7 2018, 01:05 PM
Senior Member Group: Members Posts: 734 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
i got some interesting comments on my badge from Restoration Design . mostly it confuswd people that were not aware that there was an RS version (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/av-943.gif) and many wanted to know what that stood for- Rust Special is what i told them @DRPHIL914 awesome! Im sure people went home wondering about the "RS" and did some research to see if there is one. Or they told their buddy that they saw an RS model, thus starting more rumors. Pete |
euro911 |
Nov 7 2018, 02:40 PM
... I need to fish an additional wire from the engine bay to the dash for an oil temperature gauge too. The car didn't come with a temp sender either, but I have a Jonsey taco plate and VDO sender earmarked for it (IMG:style_emoticons/default/smile.gif) ... Unless someone messed with it you should be able to find the wire for oil temp. starting with a connection down around the passenger side of the engine shelf and terminating at one of a trio of plastic covered spade connectors in the center tunnel right next to the shift lever. All wiring harnesses had the wires for center consoles, they just didn't connect to anything.I don't think anybody's hacked any wiring, I bought the car from the original owner (IMG:style_emoticons/default/biggrin.gif) ... I'll look for it all the next time I'm in there. |
raynekat |
Nov 7 2018, 06:24 PM
Advanced Member Group: Members Posts: 2,167 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Love it!
i got some interesting comments on my badge from Restoration Design . mostly it confuswd people that were not aware that there was an RS version (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/av-943.gif) and many wanted to know what that stood for- Rust Special is what i told them |
Shadowfax |
Nov 8 2018, 07:42 AM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
Finished putting together most of the car. Have just a few areas left, but they are the ones I'm most nervous about - the sail panel vinyl and windshield. Got everything ready to go, just need a little courage (IMG:style_emoticons/default/beer3.gif) Will post pics once it's all done.
Edit: Well that was easy! @hansjan - PM me your address and I’ll send you the butyl primer. Didn’t use much at all. We might be able to pass this can around to a bunch of folks (IMG:style_emoticons/default/aktion035.gif) I fixed the corner trim piece after seeing this pic (IMG:style_emoticons/default/biggrin.gif) |
HansJan |
Nov 8 2018, 04:34 PM
Member Group: Members Posts: 400 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Finished putting together most of the car. Have just a few areas left, but they are the ones I'm most nervous about - the sail panel vinyl and windshield. Got everything ready to go, just need a little courage (IMG:style_emoticons/default/beer3.gif) Will post pics once it's all done. Edit: Well that was easy! @hansjan - PM me your address and I’ll send you the butyl primer. Didn’t use much at all. We might be able to pass this can around to a bunch of folks (IMG:style_emoticons/default/aktion035.gif) I fixed the corner trim piece after seeing this pic (IMG:style_emoticons/default/biggrin.gif) @Shadowfax Just to confirm: you did the windshield with 5/16 butyl and clips from Porsche? Surprised to see antenna hole at passenger side. I eliminated mine, but it was on the drivers side. Will send my address through PM. Please advise PayPal email address. When done I will make the remainder of primer available on this site. |
Shadowfax |
Nov 8 2018, 04:55 PM
Just to confirm: you did the windshield with 5/16 butyl and clips from Porsche? Surprised to see antenna hole at passenger side. I eliminated mine, but it was on the drivers side. Will send my address through PM. Please advise PayPal email address. When done I will make the remainder of primer available on this site. Correct - used the 5/16ths butyl cord and Porsche clips. Yeah I've seen a few on the passenger side but most seem to be on the drivers side. I guess it was whatever the dealer felt like doing (IMG:style_emoticons/default/sawzall-smiley.gif) |
914 Ranch |
Nov 9 2018, 06:10 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,471 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
914 Ranch |
Nov 9 2018, 06:16 AM
76-914 |
Nov 9 2018, 10:09 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,654 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
NARB, trying to see if I can get the phone to post pics correctly. I'll have to find another way to do this. It isn't you, Joe. Something with this site and how it see's my iPhone pic's.. Just click on the picture and it rights itself. Does this to me also and yes, I know the correct position to hold my Phone when taking pic's. (IMG:style_emoticons/default/beerchug.gif) |
ndfrigi |
Nov 9 2018, 10:46 AM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
fixed it for you Joe!
73-914 |
Nov 9 2018, 01:13 PM
Senior Member Group: Members Posts: 601 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None |
NARB is Super Beetle or Pontoon boat?
euro911 |
Nov 9 2018, 03:33 PM
I finished the ceiling. Now I have to clean up the shop and get Carerror and the NARB into here to get some real mechanical work done. Carerror has been living on the back porch for 5 months. Looks a little racy to me (IMG:style_emoticons/default/poke.gif)(IMG:http://www.914world.com/bbs2/uploads/post-19611-1541764913_thumb.jpg) The buggy is going in the trailer and the NARB ( Superbeetle) is coming in here. rac·y /ˈrāsē/ adjective: racy; comparative adjective: racier; superlative adjective: raciest (of speech, writing, or behavior) lively, entertaining, and typically mildly titillating sexually. Actually looks great, Joe ... matches the tile floor in my spare bathroom. Are you going to pour a driveway at some point? |
914 Ranch |
Nov 9 2018, 09:50 PM
Yes Mark, going to pour lots of concrete after I flip the house in HB.
michael7810 |
Nov 10 2018, 09:56 AM
Senior Member Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
euro911 |
Nov 10 2018, 12:15 PM
Michael N |
Nov 10 2018, 03:16 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
cali914 |
Nov 10 2018, 07:35 PM
cali914 Group: Members Posts: 456 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
awesome
Lo-Fi Version | Time is now: 16th January 2025 - 02:03 AM |
