what did you do to your 914 today |
76-914 |
Feb 10 2019, 03:17 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,655 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The right outer CV decided to Divorce the V8 on the grounds of abuse!
djway |
Feb 10 2019, 04:11 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
anderssj |
Feb 10 2019, 04:25 PM
Dog is my copilot... Group: Members Posts: 1,716 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Drove it (on Friday), covered 73 miles and only had to bump/push-start it once (IMG:style_emoticons/default/dry.gif)
SWMBO was not impressed...especially after I told her that reliability is the enemy of adventure. You'd think that after 37 years I'd know better. (IMG:style_emoticons/default/biggrin.gif) |
MiniStevieG |
Feb 10 2019, 04:54 PM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
Replaced the weatherstripping on the doors and fixed my horn.
wndsrfr |
Feb 10 2019, 07:04 PM
Senior Member Group: Members Posts: 1,444 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Drove it (on Friday), covered 73 miles and only had to bump/push-start it once (IMG:style_emoticons/default/dry.gif) SWMBO was not impressed...especially after I told her that reliability is the enemy of adventure. You'd think that after 37 years I'd know better. (IMG:style_emoticons/default/biggrin.gif) Time for an Odyssey PC925?? Call next time & I'll be on the way! |
djway |
Feb 10 2019, 07:36 PM
Drove it (on Friday), covered 73 miles and only had to bump/push-start it once (IMG:style_emoticons/default/dry.gif) SWMBO was not impressed...especially after I told her that reliability is the enemy of adventure. You'd think that after 37 years I'd know better. (IMG:style_emoticons/default/biggrin.gif) ROFL |
wes |
Feb 10 2019, 11:09 PM
wes Group: Members Posts: 1,591 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Well started to work on cleaning out the seam sealer in the rear trunk floor only to find that it’s likely best to add a Restoration Design rear trunk floor pan piece first!
infraredcalvin |
Feb 11 2019, 12:57 AM
Distracted Member Group: Members Posts: 1,581 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
euro911 |
Feb 11 2019, 01:38 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Drove it (on Friday), covered 73 miles and only had to bump/push-start it once (IMG:style_emoticons/default/dry.gif) Time for an Odyssey PC925?? Call next time & I'll be on the way!SWMBO was not impressed...especially after I told her that reliability is the enemy of adventure. You'd think that after 37 years I'd know better. (IMG:style_emoticons/default/biggrin.gif) I recently purchased a PC925 from an ebay vendor for 'HOWARD' (our '71) - for good price too (IMG:style_emoticons/default/smile.gif) |
76-914 |
Feb 11 2019, 09:40 AM
The right outer CV decided to Divorce the V8 on the grounds of abuse! Stock CV or some other type? No, they're stock. I think of them as a fuse for the 901 transmission. (IMG:style_emoticons/default/av-943.gif) |
mmichalik |
Feb 11 2019, 09:50 AM
MikeM Group: Members Posts: 739 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Well started to work on cleaning out the seam sealer in the rear trunk floor only to find that it’s likely best to add a Restoration Design rear trunk floor pan piece first! I had the same problem but, fortunately, it wasn't a real difficult fix. The hardest part was reforming the panel sent to us by Restoration Design. I have a 75 and the panel is really made for an earlier car. http://www.2002and914.com/?page_id=743 It just took a little finesse, a bench vise, a round steel bar about 14 inches long and a body hammer. |
StratPlayer |
Feb 11 2019, 01:42 PM
StratPlayer Group: Members Posts: 3,310 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Giving a shout out to PMB Performance for the excellent job redoing my front trunk.
I had a front oil cooler installed more than 15 years ago, people that installed the cooler cut big rectangle holes in the fender wells to vent hot air, looked like crap. PMB filled in the holes, installed a new cooler, rerouted the ss oil lines. Mounting a space saver spare. The front trunk looks amazing...Thank You PMB mb Attached image(s) |
1adam12 |
Feb 11 2019, 02:22 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Custom mounted VDO gauges to my 914rubber radio delete panel. I'm happy with the results and now on to laying out the wiring.
clarkcou |
Feb 11 2019, 10:52 PM
Member Group: Members Posts: 115 Joined: 17-October 03 From: Peoria, Arizona Member No.: 1,257 Region Association: Southwest Region |
Used to work every week on my 914, almost daily, until 2008. Then laid off and moved cross country to PHX. Bought a house and been working on that all the time.
914 - Cleaned it out (it was used for storage) and put it up on jackstands. The Project RESTARTS! |
KSCarrera |
Feb 12 2019, 06:20 AM
Member Group: Members Posts: 319 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
Paid for and sorted out the shipping for my new toy. Should be over here (UK) in a month or so... Thanks Don and 914world.com (IMG:style_emoticons/default/cheer.gif)
Probably quicker and certainly in better condition than my first 'fourteener', a genuine 914/6 I bought from the service manager at Sonauto in Paris... |
BeatNavy |
Feb 12 2019, 07:05 AM
Certified Professional Scapegoat Group: Members Posts: 2,945 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Paid for and sorted out the shipping for my new toy. Should be over here (UK) in a month or so... Thanks Don and 914world.com (IMG:style_emoticons/default/cheer.gif) Probably quicker and certainly in better condition than my first 'fourteener', a genuine 914/6 I bought from the service manager at Sonauto in Paris... (IMG:style_emoticons/default/welcome.png) |
76-914 |
Feb 12 2019, 09:11 AM
Giving a shout out to PMB Performance for the excellent job redoing my front trunk. I had a front oil cooler installed more than 15 years ago, people that installed the cooler cut big rectangle holes in the fender wells to vent hot air, looked like crap. PMB filled in the holes, installed a new cooler, rerouted the ss oil lines. Mounting a space saver spare. The front trunk looks amazing...Thank You PMB mb Looks fantastic Jim. That previous cutout looked like an H20 conversion. (IMG:style_emoticons/default/beerchug.gif) |
cary |
Feb 12 2019, 01:52 PM
Finally added Chris's ( Tangerine Racing ) Pressure Relief Valve. It's been needed since WCR 2017. Saw some 25# pressure on some of the high altitude and high temp hill climbs.
cary |
Feb 12 2019, 02:00 PM
Then added the 914 Rubber parts stacked on my desk.
Inner & Outer Door Seals New side marker lenses New front roof latch cups for trunk The the shiny part, new fog light grills. Desk is all cleaned off of new parts. |
Stoddy |
Feb 12 2019, 05:15 PM
All things Porsche! Group: Members Posts: 53 Joined: 30-May 18 From: Monmouth (UK) Member No.: 22,173 Region Association: England |
Paid for and sorted out the shipping for my new toy. Should be over here (UK) in a month or so... Thanks Don and 914world.com (IMG:style_emoticons/default/cheer.gif) Probably quicker and certainly in better condition than my first 'fourteener', a genuine 914/6 I bought from the service manager at Sonauto in Paris... Where you based? I'm in Monmouth. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 17th January 2025 - 12:45 AM |
