what did you do to your 914 today |
burton73 |
May 10 2019, 04:11 PM
Senior member, and old dude Group: Members Posts: 3,741 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Cked wheels that I bought on 914world a year ago. Warped. All of them but one of the 5. Cast wheels are not a great thing. Only for an art project or rollers in shop
Bob B (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/stromberg.gif) (IMG:style_emoticons/default/stromberg.gif) |
rbzymek |
May 10 2019, 06:24 PM
Member Group: Members Posts: 199 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
Finished cleaning the last of my parts fro my Dual Weber rebuild in the ultra-sonic parts washer. Touching up roll cage & reinstall after all new interior. Replaced seat rails with race adjustable & grade 8 bolts. Stripped & repainted the hellhole from PO's silicone mess. Repainting the rear firewall engine side. In the middle of a progressive carb to L-jet conversion. All parts on hand, new FI harness fabrication nearly complete, pulled fuel tank and having it refurbished (lots of rust inside). Removed carb and manifold. Need to remake ignition harness. Next: Clean and paint runners and plenum plus get started on ignition harness. Pictures to follow.[font=Comic Sans Ms] Ray |
914-300Hemi |
May 10 2019, 08:36 PM
Senior Member Group: Members Posts: 1,373 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
euro911 |
May 10 2019, 10:31 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Sort of 914 related ... I bought a MIG welder from Kent at the G&R [914] swap meet last Sunday (IMG:style_emoticons/default/rolleyes.gif)
I picked up and assembled a cheap welding cart from Harbor Fright today ... seems like it'll do the job (IMG:style_emoticons/default/idea.gif) |
Bleyseng |
May 11 2019, 09:59 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Rebuilt my driver door window mechanism after it broke. Two hours later it was fixed
ndfrigi |
May 11 2019, 11:52 AM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
sb914 |
May 11 2019, 01:40 PM
Surf Guru Group: Members Posts: 4,425 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
76-914 |
May 11 2019, 03:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,656 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Sort of 914 related ... I bought a MIG welder from Kent at the G&R [914] swap meet last Sunday (IMG:style_emoticons/default/rolleyes.gif) I picked up and assembled a cheap welding cart from Harbor Fright today ... seems like it'll do the job (IMG:style_emoticons/default/idea.gif) LMK how that Harbor Freight wire works. I never had the courage to buy any. (IMG:style_emoticons/default/happy11.gif) |
porschetub |
May 11 2019, 04:25 PM
Advanced Member Group: Members Posts: 4,765 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sort of 914 related ... I bought a MIG welder from Kent at the G&R [914] swap meet last Sunday (IMG:style_emoticons/default/rolleyes.gif) I picked up and assembled a cheap welding cart from Harbor Fright today ... seems like it'll do the job (IMG:style_emoticons/default/idea.gif) Nice ,good welders,is it new ?,you will enjoy playing with it,ditched my old 150amp and bought a new BOC 180amp recently...modern welders have come a long to make MIG even better ,however my old one was 25yrs old (IMG:style_emoticons/default/biggrin.gif) . |
914Sixer |
May 11 2019, 06:09 PM
914 Guru Group: Members Posts: 9,046 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have one of the HF carts with my Hobart on it. Works good.
Literati914 |
May 11 2019, 06:34 PM
Senior Member Group: Members Posts: 1,800 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I have one of the HF carts with my Hobart on it. Works good. hmm.. maybe I have things arranged wrong but the HF welding cart causes my welder to lean back (shelf is angled)... which makes the hoses interfere with my gas cylinder that sits on it tank platform. DRIVES ME NUTS!! just make the shelf flat!! ... but it was cheap (IMG:style_emoticons/default/rolleyes.gif) |
mb911 |
May 11 2019, 08:26 PM
914 Guru Group: Members Posts: 7,426 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
euro911 |
May 11 2019, 08:50 PM
I have one of the HF carts with my Hobart on it. Works good. hmm.. maybe I have things arranged wrong but the HF welding cart causes my welder to lean back (shelf is angled)... which makes the hoses interfere with my gas cylinder that sits on it tank platform. DRIVES ME NUTS!! just make the shelf flat!! ... but it was cheap (IMG:style_emoticons/default/rolleyes.gif)I rolled it out front across the grass to get the 140 out of the back of my truck, and rolled it back the same way. It didn't feel wobbly at all. Just assemble with the hardware loose-fitting on a flat surface, then cinch it all down and it will be level, straight and plumb. The first screw stripped over-tightening it, but there was a spare in the bag ... I just made sure not to over-tighten the remaining ones. When I get a gas bottle, I'm going to cut-out an appropriate-sized hole in a piece of thick wood and place it on the bottom shelf for the bottle to sit in, and cut a semi-circular wooden upper support ... and I'll use some ratchet-straps to secure the bottle, rather that the supplied chains. It was a 'pre-owned' welder, fresh out of a repair session - got it from Kent ( @76-914 ) |
76-914 |
May 11 2019, 09:01 PM
Wood! You have a welder and now a small project to do. (IMG:style_emoticons/default/biggrin.gif)
Larmo63 |
May 11 2019, 09:11 PM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
KSCarrera |
May 12 2019, 03:22 AM
Member Group: Members Posts: 319 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
Drove my car to a Porsche restoration shop open day - 180-mile round trip in the sunshine and the car's first proper outing since importing it. Nothing fell off, so that's a good start.
Excuse poor photo - not mine (I'm in the grey sweater/grey hair combo in front of the car) – seems like my buddy never cleans the lens on his phone! (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) |
Chi-town |
May 12 2019, 08:07 AM
Senior Member Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Brought another one home (IMG:style_emoticons/default/laugh.gif)
cary |
May 12 2019, 10:10 AM
Took a day off and took the wife on a 100 mile Oregon PCA Arrive & Drive.
Instead of flying down for Luft #6. My navigator, Julie. My life partner of 37 years. We only missed one instruction. Too busy goofing off. Car got a new clutch on Friday. Had to smell the new exhaust gaskets and cooking anti seize for a bit. But nothing like open air motoring. |
jfort |
May 12 2019, 02:39 PM
Senior Member Group: Members Posts: 1,145 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
Heading to Mid Ohio at oh dark thirty for a drivers ed. It was running like shit bot blowing on each idle jet solved the problem. No excuses now. Just me.
914-300Hemi |
May 12 2019, 04:10 PM
Lo-Fi Version | Time is now: 18th January 2025 - 01:46 PM |
