861 Pages V « < 598 599 600 601 602 > »
mitchdiego1
post Jul 19 2019, 11:04 AM
Post #11981
QUOTE(Beeliner @ Jul 18 2019, 03:17 PM) *
QUOTE(mitchdiego1 @ Jul 18 2019, 12:19 PM) *
Put in a electronic ignition and WOW!! (IMG:style_emoticons/default/piratenanner.gif)
More information, please!!
1976 non cat. Replaced the original black coil (car died on a cruz) with a Bosch Blue coil and replaced the condenser and points with Pertronix Ignitor Electronic Ignition
Jett
post Jul 19 2019, 05:45 PM
Post #11982
QUOTE(DRPHIL914 @ Jul 19 2019, 06:25 AM) *
QUOTE(Jett @ Jul 18 2019, 01:13 AM) *
Got our nickel plated emblems back...
nice! are you doing these for sale or just did a set for yourself? inquiring minds want to know!
One set is for our 73, but we did do two sets. The second 2.0 emblem has one shorter stud bit still works perfectly. PM if you need the set at the cost. The metal emblems are getting harder to find and the nickel plating and clear coating took some time. Queen City Plating in WA did the work and they are known for being good and expensive. ...probably why I did not offer the second set for sale.
SO.O.C914er
post Jul 19 2019, 07:10 PM
Post #11983
It’s Friday and sunny drove it to work today with her top off!! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/shades.gif) Paul
Larmo63
post Jul 19 2019, 10:49 PM
Post #11984
I'm fiddling with corner balancing and stance-ing my car. I've been busy measuring, wrenching, driving, re-measuring, re-wrenching, driving, etc.....
I know with my svelte 200#+ pounds on the driver's side it can be set a pinch higher on the left side, but I'm driving myself koo-koo.
Fun stuff.
Valy
post Jul 20 2019, 01:13 AM
Post #11985
QUOTE(Larmo63 @ Jul 19 2019, 09:49 PM) *
Fun stuff.
Set it higher on the left and if you don't like it just have a couple of beers before you get in, for counter balance.
Alfieg23
post Jul 20 2019, 04:26 PM
Post #11986
Attempted to take my 914 to body metal work shop 38 miles from home. At approximately 36 miles from home, my wiring harness went up in flames and burned through my fuel lines. Thankfully there was a semi-tractor driver who had a fire extinguisher and was able to douse the fire in my engine compartment. Additionally, my 914 colleague Brad, came to my rescue and stayed with me and my 914 until the flat bed arrived. I had my 914 flat bedded to my mechanic's shop. Here's hoping I can source a new wiring harness and I think I will go with stainless steel fuel lines going forward. Tomorrow will be another day.
euro911
post Jul 20 2019, 05:19 PM
Post #11987
It would help to know the year of your car and which FI system you're running?
Just saw a 'L-jet' harness listed in the classifieds this AM. I don't know any of the particulars ... http://www.914world.com/bbs2/index.php?showtopic=339376
post Jul 20 2019, 05:22 PM
Post #11988
914-6 GT in waiting
QUOTE(Alfieg23 @ Jul 20 2019, 06:26 PM) *
What year?
@Alfieg23
forrestkhaag
post Jul 20 2019, 08:02 PM
Post #11989
Took the car out for a summer drive / it was a balmy 109 so it was quite comfortable. Think about that for a minute. One's oil doesn't have to warm up. Bearing grease is fully lubed and pliable. Tranny gear oil is supple and all gears hit on targetsd without the "winter crunch" of cold gearbox juices.
On the down side, there are no other 911's or 914-6 versions on the road as most of the locals have their rides in mothballs........ (IMG:style_emoticons/default/WTF.gif)
One question looms ever present: When I elect to fire up the little beast after a few weeks of inactivity, it takes many many revs to get to oil pressure and even then, a few more seconds of rev to get the thing to come to life. Is this "normal" for a 6 with front oil cooler and stock 914-6 oil tank etc.
The Clewett crank fire ignition system is flawless once the oil pressure gauge pumps up but before that, many seconds of rev is required to make life where there was none.????
I am not sure if this is normal procedure........ (IMG:style_emoticons/default/beerchug.gif)
just for interest, an old photo or two....... but maybe a good one or two...
Steve's car in the lead at 90+_..... YES!
914Toy
post Jul 20 2019, 08:21 PM
Post #11990
QUOTE(forrestkhaag @ Jul 20 2019, 07:02 PM) *
Could it be that your oil tank is empty after weeks of standing from gravity pulling the oil out of it into the engine. Thus, the oil pump is sucking air until the scavenger side of the pump has put some oil back into the tank which then feeds the high pressure side of the pump?
914fahrer
post Jul 21 2019, 07:54 AM
Post #11991
Region Association: Germany
Polished my front hood. (IMG:style_emoticons/default/smile.gif)
RAB914
post Jul 21 2019, 03:52 PM
Post #11992
RAB914
Post #11993
Costa05
post Jul 21 2019, 06:13 PM
Post #11994
Bent up some u-straps and test fit radiator hoses on underside of pan.
Alfieg23
post Jul 22 2019, 04:31 PM
Post #11995
QUOTE(mepstein @ Jul 20 2019, 07:22 PM) *
What year?
1972
@Alfieg23
Alfieg23
post Jul 22 2019, 04:32 PM
Post #11996
What year?
1972
with a 1974 1.8 engine.
@Alfieg23
DRPHIL914
post Jul 23 2019, 12:11 PM
Post #11997
Dr. Phil
drove it last night to go get dinner, had not been in the car for a few weeks!.
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/piratenanner.gif) time to start the short list of to-do's before Okteenerfest!
mmichalik
post Jul 23 2019, 12:16 PM
Post #11998
MikeM
Took the '74 to Triple A and used their DMV services to get the car registered in my name and the new plates.
Then I drove it to my mechanic to give it a solid once over to see what we've got and what needs to be done.
He was impressed with the car, liked where it was at, made a couple of minor recommendations and changed the oil. (Brad Penn)
Got a few adjustments to the shift linkage that we're going to do, put some new bushings and such and then we'll be off to the races.
Such a blast to drive. Been taking my daughter with me, since it's going to be her car next year, and let her feel the pain of the DMV process. (even though it was at AAA and not NEARLY as painful as the real DMV). And I'm training her what to look for, with the gauges, with traffic around us, etc.
We'll start her on driving here in the next few weeks. She'll be one of only a hand ful of her age that will know how to drive a stick. (IMG:style_emoticons/default/smile.gif)
jim_hoyland
post Jul 23 2019, 03:23 PM
Post #11999
Get that VIN ?
Reinstalled the sun visors and replaced the rear view mirror.
post Jul 23 2019, 05:29 PM
Post #12000
QUOTE(jim_hoyland @ Jul 23 2019, 02:23 PM) *
That looks a lot nicer w/o "The Bar of Mirrors" Jim. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 28th November 2024 - 06:39 AM
