861 Pages V « < 601 602 603 604 605 > »
Robarabian
post Aug 3 2019, 03:59 PM
Post #12041
914 A Roo
Took it for a PCH Highway 1 and canyon run back through Mulholland Highway... Attached Image
PatrickB
post Aug 3 2019, 05:08 PM
Post #12042
Drove to mosport... almost ! Broke it. Sitti g at Mark Henry's (Thanks!)
dangrouche
post Aug 3 2019, 09:42 PM
Post #12043
dangrouche
pump relo
AZBanks
post Aug 3 2019, 11:08 PM
Post #12044
Bought it.
michael7810
post Aug 4 2019, 09:58 AM
Post #12045
Great color Eric
mmichalik
post Aug 4 2019, 12:53 PM
Post #12046
MikeM
sanded down and primed up abut 1/3 of the engine bay. Awfully tight spot....
Got a little more welding to do in one area that I discovered today, before I can move on.
dt4
post Aug 4 2019, 12:56 PM
Post #12047
Region Association: England
watched it get a little bit closer on the shipping app
it should be arriving in Felixstowe on the 7th and unloaded by the end of the week.
FlacaProductions
post Aug 4 2019, 09:03 PM
Post #12048
I got a s**t ton done today. I'm only back to where the 914 lives every few weeks so I spend that "down time" plotting, obtaining parts and doing research.
Today I got to pull the trigger on things: installed all new LEDs around the exterior positions and dome light (thanks @Spoke for the relay to make it all flash correctly!), new tail light lenses (back to US from the PO's Euros), pulled the dead stereo and installed a new Fusion marine unit to drive the Blau's in the 914Rubber pods, reconnected some wiring under the passenger seat, replaced a headlight retaining ring (thanks @GaroldShaffer ) to repair the one that broke a tab when I installed the 914Rubber (Thanks @Mikey914 !) LED headlights last time (those headlights are great!), installed new 914Rubber black aluminum trim strips to replace the wavy plastic ones....and then I drove it for a couple of hours...it was a really great, fun, satisfying day. I couldn't have done it without a lot of help from here during the research phase!
Justinp71
post Aug 4 2019, 09:59 PM
Post #12049
QUOTE(Robarabian @ Aug 3 2019, 02:59 PM) *
I bet that’s a ton of fun with a Wrx motor. Did that car come from the Bay Area? I think I may have seen it 10 years ago at parts heaven???
Gatornapper
post Aug 5 2019, 08:08 AM
Post #12050
Took my eldest son for a spin on our wonderful twisty country roads to show him how great a 44 year old car handled - he used to have a C5, and has driven my 987.2 S, so he has high standards.....
Of course, getting from 3rd to 4th was impossible, so we had to do with 3rd to 5th with a double-clutch move.....
GN
Costa05
post Aug 5 2019, 02:25 PM
Post #12051
Finally got to test fit GT air dam @mowog4 gave me. Thanks Ed.
Next up is prepping front bumper for black paint. Attached Image
Cairo94507
post Aug 5 2019, 02:33 PM
Post #12052
Michael
Wow- that air dam looks great! (IMG:style_emoticons/default/beerchug.gif)
dabird
post Aug 5 2019, 07:14 PM
Post #12053
Diagnosed my high idle issue. Car was idling at 2k. Did a little research on these forums and suspected my AAR might be stuck open. Started the car cold and let it run for 15 min , pulled the line from the AAR to the air breather and it was still sucking air when it should be closed. Plugged the line and the idle dropped to about 1200, pulled and plugged the other AAR line and the car idles at about 900. Now I need to look into unsticking or rebuilding it. May just decide to live without it for a while
Gatornapper
post Aug 5 2019, 07:35 PM
Post #12054
Love it! My fav color!
Congrats!
GN
QUOTE(AZBanks @ Aug 3 2019, 11:08 PM) *
Bought it.
Gatornapper
post Aug 5 2019, 07:38 PM
Post #12055
Shifting had become impossible so put car on lift & pulled linkage - shocked to find NO bushings in coupler, firewall bushing shot and not even in place, other bushings shot. How did this car ever shift?!?
New bushies on the way, can't wait to get them in. It will shift like new!
GN
dangrouche
post Aug 5 2019, 09:01 PM
Post #12056
dangrouche
(IMG:style_emoticons/default/dry.gif) had to re-weld the cracked motor lid bracket for the second time; this time used gussets
Robarabian
post Aug 5 2019, 09:43 PM
Post #12057
914 A Roo
QUOTE(Justinp71 @ Aug 4 2019, 08:59 PM) *
Yes, it did. An older gent named Thomas "Carreraguy" on the forum. It is an amazing car and I am so happy with it. The only weakness is the gearing of the 901 and I may Subaru swap to the trans as well eventually. I got behind a GT3 in the canyon and when he couldn't lose me he had that totally stunned look on his face.... he asked what was in it and i said "Stock" and drove off..
Best!
euro911
post Aug 5 2019, 10:03 PM
Post #12058
QUOTE(dabird @ Aug 5 2019, 06:14 PM) *
Soak the mechanical portion in PB Blaster or diesel fuel for a couple days ... then apply 12v to it to heat it up ... then drain and blow compressed air through the ports.
Repeat as needed ...
914Sixer
post Aug 6 2019, 07:00 PM
Post #12059
Finished up the gauges and the fog lights. Made up wire harness for front bumper conversion for the fog light plug in.
anderssj
post Aug 7 2019, 05:48 AM
Post #12060
Dog is my copilot...
Dawn patrol, about 75 miles (IMG:style_emoticons/default/piratenanner.gif)
- Lo-Fi Version Time is now: 28th November 2024 - 02:27 AM
