what did you do to your 914 today |
saigon71 |
Dec 6 2019, 04:39 PM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Drove to the office on Wednesday before realizing they had salted the roads. That's very pretty Bob -- nice pics! I'm now a disciple of your salty road philosophy. Fortunately, they haven't laid it down here yet this year. (IMG:style_emoticons/default/beerchug.gif) It's always a sad day when the teener goes into winter hibernation. |
FlacaProductions |
Dec 6 2019, 08:57 PM
Senior Member Group: Members Posts: 1,803 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
new top seals - both horizontal ones and the fuzzy one around the back....my fingers hurt!
AZBanks |
Dec 6 2019, 09:49 PM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Finally got it registered and got plates on it. Drove it all over with the top off.
Saigon71 Beautiful car. Bring it down to Arizona and you can drive it all winter. We need more green 914's in Arizona. Jett, You can bring yours as well. It's not the same green but it is gorgeous. Attached thumbnail(s) |
North Coast Jim |
Dec 7 2019, 08:54 AM
Member Group: Members Posts: 331 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Getting to the end point on the Tangerine Racing remote Oil cooler install. Well engineered and it looks as if it will solve all of my high temp conditions noted this last Summer OR maybe it was a mis-calibrated oil temp sender. In any case I'm now committed.
Had to remove all of the original thermostat/cooling items such as the flappers, thermostat bellows with cable and oil cooler. The Passenger side cooling path has been cleaned up and will now push the same volume of air as the drivers side. No more higher temps on the passenger side due to oil cooler placement. Yes the engine had to be removed and I took this time to adjust valves and clean up some oil leak areas. Remote system incorporates a thermostat in the oil network so warmup is quick and controlled. Also includes a fan to force air over and thru the cooler. Need to finish up with the wiring and oil lines and of course top off the cooler before engine start later today. Attached image(s) |
DRPHIL914 |
Dec 7 2019, 09:40 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Installed my SPOKE fog lights and now at a local car show!!!
Jett |
Dec 7 2019, 09:56 AM
Senior Member Group: Members Posts: 1,670 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Finally got it registered and got plates on it. Drove it all over with the top off. Saigon71 Beautiful car. Bring it down to Arizona and you can drive it all winter. We need more green 914's in Arizona. Jett, You can bring yours as well. It's not the same green but it is gorgeous. (IMG:style_emoticons/default/smile.gif) Arizona and sun sound like good ideas (IMG:style_emoticons/default/smile.gif) btw. I might have a set of re-chromed (from G-Car) foglight grills, if you are looking. |
DRPHIL914 |
Dec 7 2019, 12:44 PM
Lots of comments on the 914 and our 50th!! But more questions about what is. 914RS! (IMG:style_emoticons/default/w00t.gif)
sb914 |
Dec 7 2019, 01:04 PM
Surf Guru Group: Members Posts: 4,399 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Rs =‘Really sweet in your case !
mb911 |
Dec 7 2019, 03:03 PM
914 Guru Group: Members Posts: 7,258 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
76-914 |
Dec 7 2019, 04:03 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,634 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Looks like it will be ready for next spring. Great job! (IMG:style_emoticons/default/beerchug.gif)
dlee6204 |
Dec 7 2019, 06:00 PM
DRPHIL914 |
Dec 7 2019, 07:24 PM
Gatornapper |
Dec 7 2019, 07:30 PM
Senior Member Group: Members Posts: 1,259 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Yup. One of my fav 914's now.....
GN Finally got it registered and got plates on it. Drove it all over with the top off. Saigon71 Beautiful car. Bring it down to Arizona and you can drive it all winter. We need more green 914's in Arizona. Jett, You can bring yours as well. It's not the same green but it is gorgeous. |
Gatornapper |
Dec 7 2019, 07:32 PM
Gatornapper |
Dec 7 2019, 07:41 PM
Engine quit running on Nov. 10th after running like new on Nov. 3rd with new .060 idle jets and getting carbs dialed in...have spent hours searching for cause because ignition is all new. Today discovered bad dizzy stuck in 27 deg. advance - no wonder she wouldn't start. One spring missing......
Weighing my decision on new dizzy & Pertronix ignitor, dumping points.... GN |
FlacaProductions |
Dec 7 2019, 09:09 PM
Jett |
Dec 7 2019, 09:44 PM
rjames |
Dec 8 2019, 12:33 AM
I'm made of metal Group: Members Posts: 4,145 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Engine quit running on Nov. 10th after running like new on Nov. 3rd with new .060 idle jets and getting carbs dialed in...have spent hours searching for cause because ignition is all new. Today discovered bad dizzy stuck in 27 deg. advance - no wonder she wouldn't start. One spring missing...... Weighing my decision on new dizzy & Pertronix ignitor, dumping points.... GN Get the 123 Ignition. |
ClayPerrine |
Dec 8 2019, 02:04 PM
Life's been good to me so far..... Group: Admin Posts: 15,906 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Betty and I took Igor and Frody to Maverick Region PCA for cars and coffee yesterday morning, then on to the toy run in Plano, Texas. We took both cars home, I put the new Mahle Gas burners on Elwood, and we went to the Maverick region holiday party. We had 9 914s, including Igor and Elwood, in a display at the Grapevine Porsche dealer.
I was outside talking to a guy looking at the display, and when I walked back inside, I found out Igor won best in show at cars and coffee. (IMG:style_emoticons/default/smilie_pokal.gif) |
North Coast Jim |
Dec 8 2019, 02:32 PM
Betty and I took Igor and Frody to Maverick Region PCA for cars and coffee yesterday morning, then on to the toy run in Plano, Texas. We took both cars home, I put the new Mahle Gas burners on Elwood, and we went to the Maverick region holiday party. We had 9 914s, including Igor and Elwood, in a display at the Grapevine Porsche dealer. I was outside talking to a guy looking at the display, and when I walked back inside, I found out Igor won best in show at cars and coffee. (IMG:style_emoticons/default/smilie_pokal.gif) Congrats |
Lo-Fi Version | Time is now: 27th November 2024 - 07:43 AM |
