861 Pages V « < 626 627 628 629 630 > »
michael7810
post Jan 19 2020, 05:56 PM
Post #12541
Took the twins and their friends for a neighborhood ride
ndfrigi
post Jan 19 2020, 08:07 PM
Post #12542
QUOTE(michael7810 @ Jan 19 2020, 03:56 PM) *
I like your picture!
My 2 daughters and my nephew a few years ago!
marksteinhilber
post Jan 22 2020, 02:55 PM
Post #12543
Stuffed a spare 914 motor into a 912!Attached Image Attached Image
jim_hoyland
post Jan 22 2020, 05:33 PM
Post #12544
Get that VIN ?
Nice work (IMG:style_emoticons/default/smile.gif) How much modification did it require ?
brcacti
post Jan 23 2020, 07:14 PM
Post #12545
1974 914 1.8
Made more upgrades to my 914 carport
euro911
post Jan 23 2020, 11:20 PM
Post #12546
QUOTE(brcacti @ Jan 23 2020, 05:14 PM) *
PIX ?
Maltese Falcon
post Jan 24 2020, 11:04 AM
Post #12547
Grilling away today...
Maltese Falcon
post Jan 24 2020, 11:07 AM
Post #12548
Leftovers made a cool 914 Mesh biz card holder...Attached Image
brcacti
post Jan 24 2020, 11:22 AM
Post #12549
1974 914 1.8
marksteinhilber
post Jan 24 2020, 03:19 PM
Post #12550
QUOTE(jim_hoyland @ Jan 22 2020, 03:33 PM) *
Jim: The motor requires no real mods as it was used in 1976 912e. It stabbed right in to existing flywheel and starter. I found some 912e side tins, but had to modify a 912 firewall tin and 914 front fan belt tins to fit the opening in the 912 engine compartment. It also required fabricating an engine mounting bar that is unlike the 912e as it goes through the tin and connects to the 912 engine mounts in the engine bay. Finally, a throttle hook up rod, electric fuel pump wiring and hoses, and some modified alternator and oil press/temp wire harnesses were needed.
So if you see a 912 roller cheap, don't be afraid to give it a 120 hp 2056 transplant!
Mark Henry
post Jan 24 2020, 03:37 PM
Post #12551
that's what I do!
Finished up the plumbing on the used 1.7 engine for the wife's 914, I did all the PR seals adjusted the valves, oil filter, cleaned the sump screen, new fuel lines, new rubber intake elbow, etc.
Fingers crossed but this was a running engine.
I didn't paint the tin, etc., as this is likely a temporary engine. I'll build a new engine for it when I have the time.
Maybe a 2.0... maybe bigger (IMG:style_emoticons/default/confused24.gif)
poorsche914
post Jan 26 2020, 01:29 PM
Post #12552
T4 Supercharged
Dropped the engine for cleanup and swap into GT-flared car.
Costa05
post Jan 26 2020, 02:07 PM
Post #12553
Got it off jack stands after about two years. (IMG:style_emoticons/default/piratenanner.gif) Tend to forget how low the car is. More to do still but the progress is there.
N8T914
post Jan 26 2020, 07:59 PM
Post #12554
Hood, Headlights & Grill
KSCarrera
post Jan 30 2020, 10:42 AM
Post #12555
Region Association: England
Put 914 on rolling road at Rawspeed in Plymouth. Around 130bhp at 5200rpm and 115ftlb torque from 3500 to 4500rpm. Makes over 100ftlb from 2700 to 5300rpm - a nice flat torque curve!
https://www.facebook.com/keith.seume/videos...59502615594768/
burton73
post Jan 30 2020, 12:09 PM
Post #12556
burton73
QUOTE(KSCarrera @ Jan 30 2020, 08:42 AM) *
Sounds great
Bob B
brcacti
post Jan 30 2020, 05:20 PM
Post #12557
1974 914 1.8
Had mechanic install xr700 electronic ignition
SKL1
post Feb 1 2020, 12:52 PM
Post #12558
Took the '71 to a local P car (especially AC'ed) C&C in Scottsdale. Were actually several 914's there.
Starting to plan the car's 50th birthday party this coming September as it is a 9/70 build. Appropriate to do it on the 14th- will have had 50 great years with that car!!
brcacti
post Feb 1 2020, 05:29 PM
Post #12559
1974 914 1.8
Worked on fan/defrost indicator lights originally two were working, now 3 are might have one bad socket will test with my meter when I get back into it.
soccerplyr
post Feb 3 2020, 09:45 AM
Post #12560
Yesterday it was a balmy 58 degrees here in Salt Lake so I got to drive it! Today I woke to a foot of snow.
- Lo-Fi Version Time is now: 26th November 2024 - 10:52 PM
