861 Pages V « < 632 633 634 635 636 > »
AZBanks
post Mar 5 2020, 04:37 PM
Post #12661
Took the top off and drove it all over town.
brcacti
post Mar 6 2020, 04:37 PM
Post #12662
1974 914 1.8
Drove it to work Thur and Fri. FUN. (IMG:style_emoticons/default/driving.gif) also set the idle up just slightly.
JamesM
post Mar 7 2020, 02:54 AM
Post #12663
QUOTE(eric9144 @ Mar 4 2020, 09:44 AM) *
Worked on the headlights on the GT car, cleaned up the ground stud behind the bucket a bunch using a dremel and a tiny brass wire wheel, it made it better but the when I connect a headlight on the drivers side its still obviously under powered. Might have to replace the headlight plug next, anyone have this problem before?
Had a similar issue when i swapped to LEDs, found the wire orientation in one of the headlight plugs was incorrect.
eric9144
post Mar 7 2020, 09:55 AM
Post #12664
QUOTE(JamesM @ Mar 7 2020, 12:54 AM) *
I'll check that next, cleaned up the metal in the plug sockets and re-assembled so I could drive it!
Took it over to AAA to add it to my classic policy, will be real curious how they react on the agreed value part.
Left there and did an unintentional burn out onto the freeway at the traffic meter (IMG:style_emoticons/default/happy11.gif) Then took the twisty way home (IMG:style_emoticons/default/driving.gif)
DRPHIL914
post Mar 7 2020, 03:02 PM
Post #12665
Dr. Phil
stopped by PMB booth to visit Eric Shea and the group, went to C&C Amelia to display the 914 and drove it to new Brumos Museum!
eric9144
post Mar 8 2020, 10:19 PM
Post #12666
Adjusted the engine lid latch, was sticking and generally crappy to unlatch. Then just admired the 3.8 (IMG:style_emoticons/default/chowtime.gif)
Attached ImageAttached Image
falcor75
post Mar 9 2020, 01:41 AM
Post #12667
Managed to crush the contact housing for my flexfuel/e85 sensor when I put the engine back into the car. Ooops.... Ordered a new one so some cable crimping might need to take place later this week.
Gatornapper
post Mar 9 2020, 06:51 AM
Post #12668
Drove her around for about an hour, let my 38 yr. old son drive it (the one who said, after taking a 35mph turn at 60 in my first Cayman 8 years ago, "HOLY COW DAD! You know what this car just said to me? 'IS THAT ALL YOU GOT?!?' " ).
Sadly, he spent most of the time trying to learn how to shift between 1st & 2nd, as he's only good with 5-speeds with a synchro 1st gear.....
Then came home and changed the oil.....Valvoline VR1.......
GN
Johny Blackstain
post Mar 9 2020, 12:13 PM
Post #12669
Tried, again, to fix my 74 headliner from flopping in the wind... most annoying (IMG:style_emoticons/default/dry.gif)
brcacti
post Mar 9 2020, 03:37 PM
Post #12670
1974 914 1.8
Sunday took the car to a car show, did not win, the original class was won by 50s cars
Johny Blackstain
post Mar 10 2020, 12:02 PM
Post #12671
Changed the center caps on my six from phoenix red to silver/chrome, washed her & went for a drive (IMG:style_emoticons/default/cool_shades.gif)
DRPHIL914
post Mar 10 2020, 12:25 PM
Post #12672
Dr. Phil
QUOTE(Johny Blackstain @ Mar 10 2020, 02:02 PM) *
looks good! Now, bring it to TN in September!!! ( Okeenerfest coming back to TN again- I think that's the last time I saw you, was at Townsend Tn)
- I like the other center caps better btw (IMG:style_emoticons/default/poke.gif)
Johny Blackstain
post Mar 10 2020, 01:15 PM
Post #12673
QUOTE(DRPHIL914 @ Mar 10 2020, 01:25 PM) *
(IMG:style_emoticons/default/biggrin.gif) I had them the matching phoenix red but my creamsicle has polished stainless, Brutus the 916s' are shiny & Larry Phillips gorgeous Gulf tribute are also shiny centers so I'm giving it a try. Seems more period correct for my wannabe 916 (IMG:style_emoticons/default/laugh.gif)
eric9144
post Mar 13 2020, 09:53 PM
Post #12674
Switched everything to spokeworksled.com today honestly
one of the most impacting changes you can make:
The only before, not even euro divided into two sections:
afters:
@Spoke thank you for what you've brought to the 914 community! (IMG:style_emoticons/default/beerchug.gif)
KSCarrera
post Mar 14 2020, 03:08 AM
Post #12675
Region Association: England
Rebuilt spare pedal assembly. Now for the swap...
914 Ranch
post Mar 14 2020, 12:01 PM
Post #12676
Team Sharp where the 914 grow wings
I have been working on the cold Air Intake for Carerror. Today I was fitting the mock-up of the right side scoop trying to get the shape and fit correct.
Carerror's build thread is in the Paddoc.
The big ass scoop is going in just infront of the rear wing.
I'm just trolling for more viewers as my thread is just about to hit 15,000 viewers…
ValcoOscar
post Mar 14 2020, 12:16 PM
Post #12677
Garage Life
QUOTE(Johny Blackstain @ Mar 10 2020, 11:02 AM) *
My wife owns you're lost stable mate. (IMG:style_emoticons/default/confused24.gif) Attached Image
Oscar
eric9144
post Mar 14 2020, 07:41 PM
Post #12678
Finished off my LED conversion by swapping out the flasher relay on the fuse panel (IMG:style_emoticons/default/beerchug.gif)
Got a box of stuff from 914 Rubber to try to knock out some of the the odds and ends that need to be fixed. Glad I have some parts to keep me entertained for the next couple days, sounds like most of SoCal is in social lock down.
Craigers17
post Mar 15 2020, 02:54 PM
Post #12679
Trying to refresh the intake/FI system. Finished taking off the plenum(damn you slot head screws!) and cleaned up the engine tin and top of case. I still have a lot of cleaning to do, but this thing had a ton of dirt, grease, & general debris on it. Also need to sand/grind the surface rust off the battery tray.
I wanted to know if anyone has ever sprayed/poured anything into the plenum and let soak to remove the grime that has settled on the bottom? Same question for the runners? Finally, I'm seeing what look to be some hairline cracks on the top of the case. Does this look normal or concerning? EDIT: I think they're just imperfections in the case.Thanks !
Attached ImageAttached ImageAttached Image[attachmentid=734
597]
DRPHIL914
post Mar 15 2020, 03:31 PM
Post #12680
Dr. Phil
i think mine looked worse than that when i first bought it and had to clean it all up too. yes i would spray degreaser inside and out and then check for any rust holes that could cause you vac leaks . you should be fine, lots of elbow grease but worth the trouble. lots of these look like that when they’ve been sitting for years and never cleaned up.
QUOTE(Craigers17 @ Mar 15 2020, 04:54 PM) *
597]
- Lo-Fi Version Time is now: 26th November 2024 - 02:12 PM
