861 Pages V « < 665 666 667 668 669 > »
garrettlee2
post Aug 18 2020, 07:31 AM
Post #13321
Attached Image I used it as my train station car. No one steels 914s right?
Mark Henry
post Aug 18 2020, 02:10 PM
Post #13322
that's what I do!
What did I do to my 914 today?
Got a ticket (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/dry.gif)
Cairo94507
post Aug 18 2020, 03:59 PM
Post #13323
Michael
Oh NO! Sorry Mark. Can you take traffic school to keep it off your record? Man that sucks.
As for me, I pulled the wheels off to have them checked and spun to be sure they are all balanced perfectly. Should have them back tomorrow. I met with the technician and explained what I was doing and why. He seemed genuinely interested and promised to take very good care of the wheels and make them 100% right. Of course his boss was standing there telling him they came off a fresh complete restoration car.
brcacti
post Aug 18 2020, 04:09 PM
Post #13324
1974 914 1.8
QUOTE(garrettlee2 @ Aug 18 2020, 06:31 AM) *
I had to lay down to look at that picture (IMG:style_emoticons/default/poke.gif)
Mark Henry
post Aug 18 2020, 06:33 PM
Post #13325
that's what I do!
QUOTE(Cairo94507 @ Aug 18 2020, 05:59 PM) *
Nah no biggie, I was coasting after a downhill doing 106kph in a 80 so that's about 66mph in a 50, nice cop dropped it to 95kph. No points, $52. fun tax.
Moments before I was going a lot faster...whew.
ottox914
post Aug 18 2020, 08:36 PM
Post #13326
The glory that once was.
Enjoyed the memories of our last autocross with this pic taken from my friends S2K while we both were in grid.
euro911
post Aug 18 2020, 08:40 PM
Post #13327
Back in the early 70s, when the feds lowered the national speed limit to 55, I got a ticket for going 62 mph on the freeway in my '67 VW bus (IMG:style_emoticons/default/busted_cop.gif) (IMG:style_emoticons/default/blink.gif) ... crazy days (IMG:style_emoticons/default/screwy.gif)
Literati914
post Aug 18 2020, 09:09 PM
Post #13328
I welding up 35 holes in the passenger's rear quarter of my #1 project that someone in the past had slathered bondo into, after they'd pulled it straight. The welding followed by a cool water quinch actually got the entire panel back into it's correct contours and removed an 'oil can' that had been bondo-ed over. I was psyched . . until my grinding warped it again (and I went slow cause I know better too (IMG:style_emoticons/default/headbang.gif) ). So I get to deal with that tomorrow.
Cairo94507
post Aug 19 2020, 03:10 PM
Post #13329
Michael
(IMG:style_emoticons/default/driving.gif) Got the wheels back and put them on and took it for a nice drive. Rides as smooth as can be now. The shop told me all 4 were 1-2 ounces off. (IMG:style_emoticons/default/beerchug.gif)
Deetman
post Aug 19 2020, 03:23 PM
Post #13330
Relatively new to the 914 world (but had a 911SC and a 1966 912 before), and love the car. Replaced the Chevy Camaro RS wheels with Fuchs replicas, removed all stickers and put a proper door decal on. Time for a photo shoot...(sorry I posted those on FB, I guess a few people already saw the pictures).Attached Image Attached ImageAttached ImageAttached Image
ndfrigi
post Aug 19 2020, 04:02 PM
Post #13331
QUOTE(Deetman @ Aug 19 2020, 02:23 PM) *
Welcome to 914world!
Congratulations and nicely done on those changes.
Cairo94507
post Aug 20 2020, 06:47 AM
Post #13332
Michael
@Deetman - Amazing what a couple changes can do for a car. Your car looks very nice. Oh, and (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/beerchug.gif)
Robarabian
post Aug 20 2020, 09:59 PM
Post #13333
914 A Roo
Now that it runs good... had to pull it. Time to seal all the oil leaks (crank seals/trans seals/ pushrod tube etc..) valve adjustment and major cleaning. Project 71 is now underway!
DRPHIL914
post Aug 21 2020, 06:28 AM
Post #13334
Dr. Phil
yesterday i finally got some time to take the car out for a drive to test the speedometer cable and angle drive that i installed a couple weeks back, and i can report that the huge needle bounce i had going on is gone!! it was just annoying. So now that ij've put in the new 914rubber speedo gear drive thing in the trans as well, that all is updated and sorted.
Sucks but i may be pulling the transmission before Teenerpalooza because i have a squeek once the car is warmed up , and i am sure its the throw out bearing, which is only like 8-9 years old, was put in new when i pulled the trans to put in new clutch and flywheel, then i rebuild the trans at a DrEvil clinic about 5 years ago, cant remember if i kept the same one or changed it out but i guess 10 years a bearing could go bad, probably dont have 10k miles on it ... always something!!!!.
next up, clear bra treatment !!!
phil c
post Aug 21 2020, 07:59 AM
Post #13335
DRPHIL914- just sent you a pm
DRPHIL914
post Aug 21 2020, 09:18 AM
Post #13336
Dr. Phil
QUOTE(phil c @ Aug 21 2020, 09:59 AM) *
(IMG:style_emoticons/default/bye1.gif) got it!
dangrouche
post Aug 21 2020, 05:05 PM
Post #13337
dangrouche
RADIO wiring hack to get an "accessory position" to listen to the radio with the motor off at no risk to frying your points.
while R&R of my ignition lock core assembly today, I tapped a wire off of the "S" terminal of the ignition switch (beneath the steering wheel) and routed it directly to the red accessory wire of my stereo head unit. I added an inline fuse of course. Now after the car is shut off, the radio remains on. When the key is eventually removed, the radio goes off completely and the radio circuit does not drain the battery. To switch the radio on, I turn the ignition key to the run position, without cranking, then let the radio come on, then turn the key to the off position, leaving the key in. The radio remains on until the key is removed. There is no parasitic drain. I saw this hack on a YouTube entitled "Replacing VW Beetle Ignition barrel and switch. It was done by "BoostedVW" eight years ago. The discussion of the radio hack is cited at the 15-minute mark of this 17-minute video.
euro911
post Aug 21 2020, 10:34 PM
Post #13338
https://www.youtube.com/watch?v=/0rB3KYA3Xpw
brcacti
post Aug 22 2020, 12:23 PM
Post #13339
1974 914 1.8
DRPHIL914
post Aug 22 2020, 12:26 PM
Post #13340
Dr. Phil
went to Cars and coffee today- had some nice company....
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: zulu33
- Lo-Fi Version Time is now: 25th November 2024 - 04:51 AM
