861 Pages V « < 674 675 676 677 678 > »
Gatornapper
post Sep 27 2020, 06:14 AM
Post #13501
Phil -
DID paint the lower shroud of the fan housing, but in satin black - need to make it gloss, but not messing with the alloy section attached to the engine.
Not striving to match the perfection of your sweet goldie!
Hope you are well - I'm doing great now.
Take care......
GN
DRPHIL914
post Sep 27 2020, 07:17 AM
Post #13502
Dr. Phil
QUOTE(Gatornapper @ Sep 27 2020, 08:14 AM) *
Phil -
Take care......
GN
slowly feeling better, still not completely, but well enough yesterday to wash the cars. had to polish the fuchs to get the water spot stains off the rims, took a lot of elbow grease but results are pretty darn good.
let me tell you Shingles nerve pain is no joke!
but that’s what i got done.
jesse7flying
post Sep 27 2020, 08:44 AM
Post #13503
Rebuilt the CV joints on my '71 project car. Lots of crusty old grease in there, but surprisingly little wear on the metal surfaces. Van Svenson's YouTube vid on CV joints is the ticket for the job. Lot's to do on this old girl, but hope to have it on the road next year.
Bleyseng
post Sep 27 2020, 10:37 AM
Post #13504
Aircooled Baby!
Installed new rubber lines on the front brakes and installed a rebuilt PMB rear caliper on the rear, adjusted the venting clearance and finally bled the system to get a good firm petal.
brcacti
post Sep 27 2020, 06:41 PM
Post #13505
1974 914 1.8
Vacuumed the outside of the car today getting it ready for the next driving season in very hot AZ. Still a little too hot for use as of this week. Also took it off the blocks and ramps for test drive. Attached Image
simonjb
post Sep 27 2020, 07:17 PM
Post #13506
KiwiMan
Took my 1974 2.0 for a final ? Fall drive. And have almost finished up the restoration of the original Djet engine....
jhynesrockmtn
post Sep 27 2020, 08:12 PM
Post #13507
Went through the engine compartment fuel hoses and updated all including new fuel injector seals. The kit from AA was ok but I ended up being short some clamps. Luckily had a few around that were the proper type.
porsche914rick
post Sep 27 2020, 08:23 PM
Post #13508
Shingles nerve pain
2019 (IMG:style_emoticons/default/screwy.gif) Rick O
RolinkHaus
post Sep 27 2020, 09:30 PM
Post #13509
Wet sanding old paint. While the engines out. (IMG:style_emoticons/default/piratenanner.gif) Will do some before and after.
New / Old Porsche hauler, one owner 2001 ML with 93K (IMG:style_emoticons/default/aktion035.gif)
Mueller
post Sep 27 2020, 09:55 PM
Post #13510
914 Freak!
Installed new spark plugs, changed the valve cover gaskets.
Started to tidy up the wiring, made a few brackets.
One near the starter and the other on the engine mount.
tygaboy
post Sep 28 2020, 08:26 AM
Post #13511
QUOTE(Mueller @ Sep 27 2020, 08:55 PM) *
@Mueller - Oh come on, Mike! Now you're just showing off!
Worse than that, you're going to have to make me some stuff... (IMG:style_emoticons/default/shades.gif)
henjik
post Sep 28 2020, 03:12 PM
Post #13512
Region Association: Europe
Started to fit the rear cross panel and trunk floor.Attached ImageAttached Image
brcacti
post Sep 28 2020, 03:22 PM
Post #13513
1974 914 1.8
checked tire air pressure, TOMORROW morning will be my first drive to work this driving season. The weather is starting to improve especially during the morning and late morning hours here in S. AZ. I will leave work at 10 am get home before the heat hits us.
boxster914
post Sep 28 2020, 07:26 PM
Post #13514
I painted my rockers with wurth satin black (cleaned first with wurth surface prep) very happy with the result. Nice and smooth.
Also had to flex seal my windshield trim (lost the first set on the highway last week after windshield replacement). Not happy with this result. I'd appreciate any advice of how to permanently seat the trim in the clips without the use of flex seal!
Then took a nice drive.
Cairo94507
post Sep 29 2020, 06:25 AM
Post #13515
Michael
For the windshield trim you may have to remove the glass and start over. Clean out the track and install new clips and then the windshield. Then the trim. Additionally, I do not see the front mounting screw and spacer for the rocker install. But the rockers do look nice. (IMG:style_emoticons/default/beerchug.gif)
Mark Henry
post Sep 29 2020, 06:44 AM
Post #13516
that's what I do!
Drove the teen to Mike's914 and picked up some 5 bolt struts and hubs. Hard to to tell if I got a matching pair, he let me take home 3 struts to check out, I'll clean up the part numbers today.
3" struts because I have 2 sets of Alfa brembo's in my stash.
Not sure if I'll pass these to teenhulk or sale them in the future. (IMG:style_emoticons/default/confused24.gif)
boxster914
post Sep 29 2020, 07:06 AM
Post #13517
QUOTE(Cairo94507 @ Sep 29 2020, 08:25 AM) *
The rockers were fiberglass. Were the factory rockers fiberglass or is this an aftermarket part? Do you know of any pictures available on the web of the correct installation of the rocker in terms of the parts (you mention the mounting screws and spacer) used? I see that AutoAtlanta has a kit but I'm not sure where everything goes.
Jett
post Sep 29 2020, 08:29 AM
Post #13518
QUOTE(boxster914 @ Sep 29 2020, 06:06 AM) *
Here are a couple pics...
FlacaProductions
post Sep 29 2020, 09:10 AM
Post #13519
@boxster914 - Here's a good diagram from 914Rubber.com - which is also where you can get the spacers.
https://914rubber.com/spacer-for-rocker-panel-and-valance
ThinAir
post Sep 29 2020, 07:45 PM
Post #13520
Best friends
Duplicate post...
- Lo-Fi Version Time is now: 24th November 2024 - 05:19 PM
