861 Pages V « < 676 677 678 679 680 > »
brcacti
post Oct 6 2020, 02:06 PM
Post #13541
1974 914 1.8
sanded some connections so my 914 starts again. Will observe and this could be an ongoing work in progress. At least I can jump start it just in case it is not fully fixed.
Cairo94507
post Oct 7 2020, 11:27 AM
Post #13542
Michael
Switched out the polished metal shift ball for the custom wood knob made by our very own @VaccaRabite . Can't wait to give it a try. The car now has about 2K miles on it; I love driving it. (IMG:style_emoticons/default/beerchug.gif)
Gint
post Oct 8 2020, 06:35 PM
Post #13543
Mike Ginter
Nothing. And I'm seriously wanting to get it out and drive it.
Roofers have been going for 12 hours. And a full work day.
post Oct 9 2020, 08:55 AM
Post #13544
QUOTE(Gint @ Oct 8 2020, 05:35 PM) *
You need some more cars Gint. (IMG:style_emoticons/default/happy11.gif)
JOEPROPER
post Oct 9 2020, 04:37 PM
Post #13545
The answer is "no" unless you ask...
Layed the hood on, pulled it out of the shop and took it down the road for preliminary roadtest. Ran okay, but idle is still too high and need to continue to work out the bugs and get it buttoned up.Attached Image
JOEPROPER
post Oct 9 2020, 04:42 PM
Post #13546
I wish I knew how to rotate these pictures.
brcacti
post Oct 9 2020, 04:49 PM
Post #13547
1974 914 1.8
QUOTE(brcacti @ Oct 6 2020, 01:06 PM) *
Hi all, well it starts AGAIN after sanding many connections, hope it lasts ANOTHER year at it did last time. Drove it to work today
Jett
post Oct 9 2020, 05:13 PM
Post #13548
Bought some 914 Rubber gear for the driver...
zoomCat
post Oct 11 2020, 02:33 PM
Post #13549
Stripping the rear deck. Attached Image
zoomCat
post Oct 11 2020, 02:59 PM
Post #13550
Essential for DA work.
Cairo94507
post Oct 11 2020, 05:45 PM
Post #13551
Michael
I took my car back to the 2nd owner's home so he could see how it turned out. I bought it from him 10 years, 8 months and 1 day ago. I found out he and his soon to be wife eloped in my Six and got married in Lake Tahoe. I met his wife too. They were both blown away with the car and he tried to buy it from me. I told him it was not for sale but that he was the 3rd guy to try.
He was elated to see I did not go back to the original color- (IMG:style_emoticons/default/av-943.gif) just saying.
Here are my brother ad I standing in front of his home with him looking at the car. We had a nice 150 mile round trip to Santa Cruz and back. Top off, windows down, sun shining, 6 singing.... just doesn't get any better.
914-300Hemi
post Oct 11 2020, 08:42 PM
Post #13552
QUOTE(Jett @ Oct 9 2020, 04:13 PM) *
Just bought those for my grandkids.
neilbardsley
post Oct 12 2020, 02:35 AM
Post #13553
Region Association: Europe
The car arrived today. I bleed the brakes. Starting with the rear and then the front. Then I read the manual which said I had to bleed the front first so I started again. Strangely I couldn't get the brake pedal any firmed. I used a pressure bleeder. Pretty sure I removed all air from the system. Should I of had Mrs B pumping the brakes instead?
Then I changed the oil. It was pretty low. Since this car has sat for a few years. I will run for 100-200 then change the oil again to clean out any crap. I didn't take the strainer off but will do that next time. Less than 3l when in which is strange?
There is a smell of burning oil when the motor is running but I guess there might be some oil in the hear exchangers?
Next I need to get the gears changing but I don't know how to access the coupling? Is it from the black panel between the seat or from under the car?
ndfrigi
post Oct 12 2020, 02:53 AM
Post #13554
QUOTE(neilbardsley @ Oct 12 2020, 01:35 AM) *
Welcome to 914world and congratulations owning a 914!
1. Brake bleeding recommend start to rear passenger (upper valve) then rear driver side, then front right and then front left side.
2. Burning oil, yes probably just from Heat exchanger from oil leak or oil inside the exhaust/header.
3. Shift adjustment is just below the shifter base. Unless you need some bushing replacement within the entire shift linkage.
ClayPerrine
post Oct 12 2020, 05:55 AM
Post #13555
Saturday we took Elwood to cars and coffee at the national Breast cancer headquarters. Then I came home, got the truck and trailer, and drove to Tennessee to pick up the parts car from Perry Kiehl. It will be used to fix Betty's 914.
Two long days of just driving. And I found out something interesting. A 914 with no doors and no front trunk lid is an aerodynamic nightmare. The front bulkhead is a big, flat wall broadside to the wind. The firewall and back window are another big, flat wall broadside to the wind. So SUV with trailer and stripped 914... max speed 80 MPH. It just won't go any faster due to aero drag.
But the body shop is going to get started on the fix. (IMG:style_emoticons/default/piratenanner.gif)
seanpaulmc
post Oct 12 2020, 06:34 AM
Post #13556
Worked on cleaning up the rear shift rod, stripping the rust, and treating with Ospho before painting. Then moved on to installing new 914rubber bushings into the shift knuckle. Tough to get started in the holes. Had to add a chamfer on the leading edge.
@Mikey914
On the replacement bushings, are the holes supposed to be oblong? It's noticeable when not installed but I thought they would round out once pressed in, however, the holes still look a little large after pressed in.
Wanted to get some feedback on this before I finish painting and putting this assembly back together.
914e
post Oct 12 2020, 08:11 AM
Post #13557
After a little over year of taking it apart, painting it and putting much of it back together. We drove it.First drive Lucky for me the monthly Aircooled AZ Sunday coffee only a mile away. The weather is finally cool enough to work on it again.
Targa70
post Oct 12 2020, 10:01 AM
Post #13558
I received it, from Glenn, after he did a fantastic job of putting all the pieces back together again.
And for the first time since 2005, I drove it. thank you @gms
post Oct 12 2020, 10:13 AM
Post #13559
914-6 GT in waiting
QUOTE(Targa70 @ Oct 12 2020, 12:01 PM) *
Michael N
post Oct 12 2020, 07:11 PM
Post #13560
Certifiable
QUOTE(mepstein @ Oct 12 2020, 08:13 AM) *
Make that a double. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Car looks amazing.
- Lo-Fi Version Time is now: 24th November 2024 - 03:17 PM
