what did you do to your 914 today |
Eric_Shea |
Aug 4 2012, 09:33 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Yanked the oil tank. Tightened the sail panel trim piece. Put the oil tank back in. Installed the filter console. Installed the lower tank GT line. Installed the console to thermostat GT line. Test fit the 911 RS rear tires on the GT. Added 7mm spacers. Test fit the tires again. Changed the outer drivers side suspension mount. Set her on the ground. She likey.
Black22 |
Aug 4 2012, 09:41 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
[/quote]
Is the B&W car your work ride? (IMG:style_emoticons/default/sad.gif) [/quote] By the looks of that frowny face I'm not sure you'd like my answer (IMG:style_emoticons/default/happy11.gif) No, it's not. Mine's a little more...shall we say, subtle. (IMG:style_emoticons/default/biggrin.gif) |
Michael N |
Aug 4 2012, 09:48 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
Went for a drive with the Alfa Romeo club through the Santa Cruz mountains and then took the full Canepa Designs facility tour. That tour was awesome and I saw some incredible cars including the 1st Duesenberg production car that is under a 10000 hour restoration. Sure glad I am not writing the check for that labor bill.
JRust |
Aug 4 2012, 10:48 PM
914 Guru Group: Members Posts: 6,310 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I pulled the motor out of my Donor camaro. My LS1 is now on my stand awaiting adapter plate, ECU tune & wiring harness work (IMG:style_emoticons/default/biggrin.gif)
I also installed the rear main seal in my 74 2.0! |
euro911 |
Aug 4 2012, 11:00 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,858 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
By the looks of that frowny face I'm not sure you'd like my answer (IMG:style_emoticons/default/happy11.gif) I got a speeeeding ticket on the way to the G&R back in April (IMG:style_emoticons/default/dry.gif) ... and a (IMG:style_emoticons/default/bs.gif) one for a burned-out brake light a month ago. $25 fix-it (IMG:style_emoticons/default/sheeplove.gif) ... used to be "you've got a light out, have a nice day" (IMG:style_emoticons/default/mad.gif)No, it's not. Mine's a little more...shall we say, subtle. (IMG:style_emoticons/default/biggrin.gif) Never got a ticket in a Porsche though (IMG:style_emoticons/default/confused24.gif) |
JawjaPorsche |
Aug 5 2012, 09:18 AM
Went to Home Depot this morning a searched for a tool to put the drop link on. A small bar clamp looked like it might work. Success! After finally getting them on I am fried! I am 63 years old. Hopefully this will be the last time I will ever have change them! Sometimes the simplest looking job is really a pain in the ass. (IMG:style_emoticons/default/bootyshake.gif)
Also replaced my Oil Filler/Breather Housing Gasket which was 40 years old! As I result I had to adjust my idle a little. Just spend the better part of the afternoon "trying" to replace my Rear Sway Bar Drop Link Bushings! Finally got them replaced on the drop links! Damn that was a bitch! Boiled water too! Got one end of link on the sway bar bar with no problem. However, the end that connects to the shock and arm: No way! I even got a "big ass channel locks" from Home Depot and it was not big enough! I will take it to my mechanic next week and he will put it on in five minutes! |
Black22 |
Aug 5 2012, 09:32 AM
By the looks of that frowny face I'm not sure you'd like my answer (IMG:style_emoticons/default/happy11.gif) I got a speeeeding ticket on the way to the G&R back in April (IMG:style_emoticons/default/dry.gif) ... and a (IMG:style_emoticons/default/bs.gif) one for a burned-out brake light a month ago. $25 fix-it (IMG:style_emoticons/default/sheeplove.gif) ... used to be "you've got a light out, have a nice day" (IMG:style_emoticons/default/mad.gif)No, it's not. Mine's a little more...shall we say, subtle. (IMG:style_emoticons/default/biggrin.gif) Never got a ticket in a Porsche though (IMG:style_emoticons/default/confused24.gif) I'm guessing that was CHP? It's well known that if they pull you over, you ARE getting the citation. Even if you're with another agency. Needless to say they aren't well liked for this very reason. They just gave my 83 year old, fixed income, widow grandmother a $485 dollar cite for getting out of the HOV lane too soon (before broken white lines) to get to her off ramp. According to my grandmother the lane change was safe. I'd like to have a word with that officer. (IMG:style_emoticons/default/dry.gif) |
pnewman |
Aug 5 2012, 11:21 AM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
Caravan'd down to Garold Schaffer's Annual BBQ on the border of IN and IL with Mike, Mark and Glenn.
First time in ten years that I took my teener out for a 5 hour drive and at >95 degrees F! Oil temps got up to >110 C for a short period on the return trip while doing 85 mph for 1 hr trying to beat the rain. I had to back off the pedal to 65 mph let her cool down. Started to rain 10 minutes from my house. Then 10 minutes after I pulled in the garage the storm let loose and their was a huge down poor. Thanks Garold! Attached image(s) |
euro911 |
Aug 5 2012, 01:39 PM
I'm guessing that was CHP? It's well known that if they pull you over, you ARE getting the citation. Even if you're with another agency. Needless to say they aren't well liked for this very reason. I've seen several places where you have to get out of the carpool lane a few miles ahead of your off ramp. It's frustrating if you're not familiar with the area.They just gave my 83 year old, fixed income, widow grandmother a $485 dollar cite for getting out of the HOV lane too soon (before broken white lines) to get to her off ramp. According to my grandmother the lane change was safe. I'd like to have a word with that officer. (IMG:style_emoticons/default/dry.gif) Anaheim CHP got me on the 91 Fwy. I sped up to get away from some texting drivers next to me in the #2 lane (IMG:style_emoticons/default/dry.gif) Unless something's changed, I thought safety trumped a posted speed limit (IMG:style_emoticons/default/confused24.gif) LAPD rookie wrote the brake light ticket (during daylight hours). I asked him if he actually knew why there are two brake lights on a vehicle. Apparently, it's all about the $ now (IMG:style_emoticons/default/mad.gif) ... I'm on a fixed income too. Garold's BBQ looked like a good time (IMG:style_emoticons/default/beerchug.gif) |
wndsnd |
Aug 5 2012, 02:50 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Took dor off, worked gap, put door on, took door off, worked gap, put door on, took door off............
jsayre914 |
Aug 5 2012, 03:09 PM
Speed Up !!! Group: Members Posts: 3,206 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I downshifted on the expressway to pass a spyder (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer3.gif)
(IMG:style_emoticons/default/first.gif) |
914werke |
Aug 6 2012, 12:24 AM
"I got blisters on me fingers" Group: Members Posts: 10,946 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
braved the unusual 90 degree warmth here in the PNW and dug into the distributor as it was the last thing keeping the LE off the road.
Success!! Off came the top & the took it out for the the first real over road shake down since I started the resto. |
messix |
Aug 6 2012, 12:29 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
braved the unusual 90 degree warmth here in the PNW and dug into the distributor as it was the last thing keeping the LE off the road. Success!! Off came the top & the took it out for the the first real over road shake down since I started the resto. (IMG:style_emoticons/default/aktion035.gif) |
6freak |
Aug 6 2012, 07:44 AM
I downshifted on the expressway to pass a spyder (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/first.gif) I missed 3rd (IMG:style_emoticons/default/headbang.gif) |
JRust |
Aug 6 2012, 08:06 AM
Installed my tranny after rear main seal replacement. Still need to install the muffler. Then run a speedometer cable as mine broke. Also clean all the damn oil under my car from the oil leak. What a frikkin mess (IMG:style_emoticons/default/mad.gif)
bulitt |
Aug 6 2012, 01:55 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Progress!
Adapter, flywheel, clutch, trans on. (IMG:style_emoticons/default/piratenanner.gif) Disco ball to go with the gold paint next! (IMG:style_emoticons/default/blink.gif) |
dlee6204 |
Aug 6 2012, 01:57 PM
Progress! Adapter, flywheel, clutch, trans on. (IMG:style_emoticons/default/piratenanner.gif) Disco ball to go with the gold paint next! (IMG:style_emoticons/default/blink.gif) Looks Great! (IMG:style_emoticons/default/thumb3d.gif) |
lotus_65 |
Aug 6 2012, 03:12 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
put my heat exchangers back together...
it was down to 52 last night... BRRRRR! lol hey, if anyone else out there decides to hook up the passenger side after all the years of being capped, you'll probably get a surprise whisp-ing out of your defrosters for quite a while... and the smell isn't all that fresh! (IMG:style_emoticons/default/icon8.gif) |
MrHyde |
Aug 6 2012, 05:41 PM
Senior Member Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
welded in the patches into the hell hole, welded in a new engine shelf and battery tray.... Will post pics in my restoration thread..
mittelmotor |
Aug 6 2012, 06:25 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Got the rear suspension back on after sandblasting, painting, installing new bearings, bushings, and pressing in hubs. Also bolted on a front wheel to the new 5-lug conversion for the first time. (IMG:style_emoticons/default/piratenanner.gif)
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 26th November 2024 - 10:41 AM |
