861 Pages V « < 737 738 739 740 741 > »
Cairo94507
post Sep 5 2021, 03:56 PM
Post #14761
Michael
Caught this little 914 on a C-2 Corvette forum posting. Nice, representing our cars in New Mexico I believe:
cali914
post Sep 6 2021, 11:37 PM
Post #14762
cali914
Drove it to Easy for the first Saturday of the month event.Attached Image
Arno914
post Sep 7 2021, 01:05 AM
Post #14763
Region Association: Germany
Still need to troubleshoot the horns, I can hear a quick beep when i hit the button so I suspect the ground wires are not right on the horns or something like that.
Had the same problem. Check the fuse in the fuse box, it may be slightly corroded. Little wiggling solved the problem and made the dual horns sound loud and clear (Far better than the cheapy Mickey Mouse horns in todays cars, btw.). (IMG:style_emoticons/default/smile.gif)
mikey63
post Sep 7 2021, 10:23 AM
Post #14764
Hanging out with family at the Santa Rosa annual car show. My brother's Camaro and my Dad's Mustang.
Beach914
post Sep 7 2021, 10:40 AM
Post #14765
My brother took delivery of my new toy over the weekend up in Monterey. It’ll stay up there for awhile hopefully getting some work done on it. Ill see it in late October.
KSCarrera
post Sep 7 2021, 10:41 AM
Post #14766
Region Association: England
Drove up a hill a few times (well, on Sunday)... Weber IDFs don't like rapid left/right/left/right turns, despite raised vents and reduced float height. ITBs for next season...
https://youtu.be/iQKMellM8qk
Justinp71
post Sep 7 2021, 11:35 AM
Post #14767
QUOTE(mikey63 @ Sep 7 2021, 09:23 AM) *
Man I would like to have a camaro like that sitting next to my 914... (IMG:style_emoticons/default/biggrin.gif), one of my favorite muscle cars. 914 looks good too!
Shivers
post Sep 7 2021, 12:32 PM
Post #14768
QUOTE(KSCarrera @ Sep 7 2021, 09:41 AM) *
If the float height is too low, the fuel can move away from the jets and cause a hesitation. I put in the CB kits to get rid of the weber burble (technical term) in the tight turns.
@KSCarrera
SKL1
post Sep 7 2021, 01:12 PM
Post #14769
Nice split window too Cairo...
930cabman
post Sep 7 2021, 05:25 PM
Post #14770
Getting ready to pull the engine/trans. A new to me '75 example has several issues including a bad oil leak.
Gatornapper
post Sep 7 2021, 06:46 PM
Post #14771
While waiting for my new SS fuel lines to arrive before I put in the new fuel tank, I sprayed down the tank bay with a strong cleaner and then pressure-washed it.
Clearly the first time it's ever been cleaned.
Much more better and now ready for the new lines and tank.
GN
LefthandRev
post Sep 7 2021, 06:56 PM
Post #14772
In the month since acquiring this car, I've fixed numerous things.
  • Fixed the fuel flow issue to the Webers
  • Ran a hose between the cylinder head ports to stop oil leakage
  • Added shoulder belts instead of lap belts
  • Installed an alarm system
  • Installed a new bluetooth radio
  • fixed the driving/fog lights
  • Added headlamp relays and fixed high/low beams
  • painted the rear grill
  • cleaned up some rust accumulation, primed, then coated it
  • Added the shifter bushing at the firewall (YAY SHIFTING)
  • Fixed the targa latch squeak above my head. Maddening!
  • Changed the oil (simple, but didn't know how old it was)
  • Ordered rear sway bar down-arm (one was missing).
  • Added a fire extinguisher
  • Added the Ford solenoid hack to the starter.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1631062593.1.png)
Jett
post Sep 7 2021, 08:28 PM
Post #14773
Took the 75 Palma car in to have the first gear synchro addressed and turns out that 2end and 3rd gears are gone as well and the inner case looks like at some point it had ran the oil for too long. Ordered all the parts for a complete rebuild after the case spends time in a sonic cleaner.
We expect that this is the last gremlin before we call the restoration complete.
djway
post Sep 7 2021, 10:35 PM
Post #14774
QUOTE(cali914 @ Sep 6 2021, 10:37 PM) *
Any more pictures of the ducting?
mmichalik
post Sep 8 2021, 09:50 AM
Post #14775
MikeM
I put in a new set of Stainless Steel fuel lines on Monday. Will be installing the new gas tank on Thursday and we'll start her up.
A total PIA but, gratifying at the same time. (IMG:style_emoticons/default/smile.gif)
Gatornapper
post Sep 8 2021, 09:58 AM
Post #14776
What? We are on parallel paths? Only I'm a week behind you.......
QUOTE(mmichalik @ Sep 8 2021, 09:50 AM) *
Jett
post Sep 10 2021, 09:21 PM
Post #14777
Some pics from underneath
Jett
post Sep 10 2021, 09:27 PM
Post #14778
Double post
Shivers
post Sep 13 2021, 06:18 PM
Post #14779
Received new to me struts...Great Googly Moogly, if you know what I mean. (IMG:style_emoticons/default/drooley.gif)
Thanks Mark for everything. (IMG:style_emoticons/default/first.gif) Too hot here to work right now, Maybe in a couple days.
@mepstein
Gatornapper
post Sep 13 2021, 06:55 PM
Post #14780
DITTO but a week behind you - received the lines from Pelican today, installed them (lot easier than I thought but still a PIA to get the lines through the front grommet).
Few small things to do but hope to crank her up tomorrow.
GN
5 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
1 Members: slapshot
- Lo-Fi Version Time is now: 24th November 2024 - 07:28 AM
