what did you do to your 914 today |
g911 |
Oct 27 2021, 09:48 PM
Member Group: Members Posts: 222 Joined: 13-January 06 From: Not Tellin' Member No.: 5,413 Region Association: None |
finally buttoned up the exhaust.
SKL1 |
Oct 27 2021, 10:03 PM
Senior Member Group: Members Posts: 1,637 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
914e- I'm not sure what those are either, but I don't think I've ever used them on either car for many years, especially since we moved to AZ full time 3 1/2 years ago...
Just take them off, and don't tell your wife. See if she even notices! |
infraredcalvin |
Oct 28 2021, 12:14 AM
Distracted Member Group: Members Posts: 1,571 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Chaznaster |
Oct 28 2021, 07:08 PM
Member Group: Members Posts: 324 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States |
Installed LEDs for dash illumination. Looks great!
Figured with that done I would start to figure out why my turn signal indicator lamp (on the dash) does not flash. Had read that not flashing was an indicator that one of the bulbs was out. So started with the bulbs and realized someone had swapped the driving light and blinker wires in the RT front driving light unit. That means the higher wattage bulb has been running when the parking lights were on. Digging a bit deeper, the wire was completely melted with bare copper showing through. My assumption is that the higher current draw turn signal filament was just pulling too many amps for that wire and it overheated. Started to trace it to see if I could get to a “good” section where I could splice but, tracing across the front of the car, it’s pretty clear the whole thing is melted. I imagine the only reason there was not a short is that the wire is buried (melted) in with the other wires in the harness. So the plan is to stop tracing and run a replacement wire from the fuse block (it looks like that is where is comes from in the wiring diagrams) and somehow pull it through. I may need to get creative about how I get from the block to the bulb until some time when I have the fuel tank out and can run it with the rest of the wires in that harness. The turn signal indicator is still not flashing … Never a dull moment! |
Shivers |
Oct 29 2021, 05:04 PM
Senior Member Group: Members Posts: 2,781 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Chaznaster |
Oct 30 2021, 05:52 PM
Installed LEDs for dash illumination. Looks great! Figured with that done I would start to figure out why my turn signal indicator lamp (on the dash) does not flash. Had read that not flashing was an indicator that one of the bulbs was out. So started with the bulbs and realized someone had swapped the driving light and blinker wires in the RT front driving light unit. That means the higher wattage bulb has been running when the parking lights were on. Digging a bit deeper, the wire was completely melted with bare copper showing through. My assumption is that the higher current draw turn signal filament was just pulling too many amps for that wire and it overheated. Started to trace it to see if I could get to a “good” section where I could splice but, tracing across the front of the car, it’s pretty clear the whole thing is melted. I imagine the only reason there was not a short is that the wire is buried (melted) in with the other wires in the harness. So the plan is to stop tracing and run a replacement wire from the fuse block (it looks like that is where is comes from in the wiring diagrams) and somehow pull it through. I may need to get creative about how I get from the block to the bulb until some time when I have the fuel tank out and can run it with the rest of the wires in that harness. The turn signal indicator is still not flashing … Never a dull moment! Pulled the new wire this evening. The old one was melted all the way to the fuse block. Even fished the new one behind the fuel tank so it runs with the harness all the way. Parking lights and turn signal/ hazard lights working perfectly! |
L97g |
Oct 30 2021, 06:32 PM
Newbie Group: Members Posts: 9 Joined: 24-April 20 From: Ohio Member No.: 24,175 Region Association: None |
Replaced the dash indicator lights with LED. Before and after shots of the high beam light below. Could not really even see it before … Just a quick question about replacing high beam indicator with an led bulb , have you tried your fog lights since the bulb switch? Mike |
Costa05 |
Oct 30 2021, 09:51 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Pounded out the passenger side rear wheel bearing. More like destroyed it.
76-914 |
Oct 31 2021, 08:29 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,634 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Arno914 |
Oct 31 2021, 11:30 AM
Member Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany |
35+ years after the PO cut the wire behind the fuse panel I fixed the door buzzer on my `71. Found out only now that the US 914´s had a 4-pole door switch. 2 for the interior light, two for the buzzer. Sounds so ugly, I love it. Bzzzzzz… (IMG:style_emoticons/default/biggrin.gif)
AZBanks |
Oct 31 2021, 03:30 PM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
914e- I'm not sure what those are either, but I don't think I've ever used them on either car for many years, especially since we moved to AZ full time 3 1/2 years ago... Just take them off, and don't tell your wife. See if she even notices! DUH!!!! Come on guys you should know this already. They are for wiping the dust off the windshield after a dust storm. On Friday. I picked up the 914 from the GCU parking garage and ran it through emissions testing It passed loaded HC's at 500 out of 500. Perfect score!! (IMG:style_emoticons/default/blink.gif) I found out you can ask the emissions testers for a one year or a two year cert on your test. If you don't ask, they will only give you a one year and they will NEVER tell you about the two year unless you ask for it(I wonder why that i$). |
mmichalik |
Oct 31 2021, 03:55 PM
MikeM Group: Members Posts: 732 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Got the engine lid put back on and fitted for the welting, rubber, grills lettering and the rain tray!
Attached thumbnail(s) |
anderssj |
Oct 31 2021, 05:23 PM
Dog is my copilot... Group: Members Posts: 1,707 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Chaznaster |
Oct 31 2021, 07:32 PM
Replaced the dash indicator lights with LED. Before and after shots of the high beam light below. Could not really even see it before … Just a quick question about replacing high beam indicator with an led bulb , have you tried your fog lights since the bulb switch? Mike Hi Mike. Funny that … my fog lights have not worked since I bought the car. I had that down as a winter project. Is this one of those cases where the current through or resistance of an LED is too low to allow high beams to turn on? I understood that fogs are designed only work when the low beams are on. And the indicator bulb was dead before installing the LED so maybe that was/is the issue?? Hmmm. |
colingreene |
Oct 31 2021, 08:25 PM
Senior Member Group: Members Posts: 731 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
put my heater duct back in after repairing the exhaust. What a pain in the ass that was.
worked on the carb balance some. |
Rand |
Oct 31 2021, 08:38 PM
I painted black into the areas between my paddles, and then boasted that I have german stars.
WTF. People please know that if you have black paint on your 4 lug fuchs, you are dumb. It devalues them so hard! The fake fuchers rejoice. Rant over. Get a clue. If you are new, take note. If you have painted 4lug fuchs, fix it. The real ones are never painted. Paint is a flag that screams fake. Don't do that to yours. |
Shivers |
Nov 1 2021, 07:14 AM
I painted up and installed these black arm things with a rubber strip on the end of them. I have no idea what they are used for. My wife seems to think they are required and she did point out all the other cars have them. So I put them back on. I think I have them on the correct sides. We have them here too, in the coachella valley. I think they are metronomes. However, that has not been proven. |
gandalf_025 |
Nov 1 2021, 07:31 AM
Senior Member Group: Members Posts: 1,472 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
g911 |
Nov 1 2021, 04:34 PM
Adjusted clutch and went for a burn
fixer34 |
Nov 2 2021, 05:56 PM
Senior Member Group: Members Posts: 1,182 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Took her for a 3.5 hr 115 mile roundtrip to pick up a shiny new muffler from Ben @mb911 . Sunny day, but about 50 degrees. Note to self-hook up the heat flappers.
Lo-Fi Version | Time is now: 24th November 2024 - 02:52 PM |
