what did you do to your 914 today |
TINKERGINEERING |
Aug 11 2022, 02:09 PM
Member Group: Members Posts: 214 Joined: 15-March 20 From: Sierra Madre, CA Member No.: 24,031 Region Association: Southern California |
FlacaProductions |
Aug 11 2022, 02:52 PM
Senior Member Group: Members Posts: 1,802 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
That's a great move for that car, @burton73 !
burton73 |
Aug 11 2022, 02:58 PM
burton73 Group: Members Posts: 3,676 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
A great move for this car as I am near 70 and its just too hard for me now. My buddy mark and I did put all the suspension in front and rear and engine and trans and have War wounds to prove it. Bob B |
914 Ranch |
Aug 11 2022, 04:49 PM
Team Sharp where the 914 grow wings Group: Members Posts: 1,462 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
Michael N |
Aug 11 2022, 08:55 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
914 Ranch |
Aug 12 2022, 09:20 AM
Cairo94507 |
Aug 13 2022, 01:35 PM
Michael Group: Members Posts: 10,095 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Getting her ready for Werks Reunion on Friday. Spent about 4 hours getting her to look nice. My car is not a trailer queen so we will drive her down to Monterey, about 250 miles, then give her a quick wipe down on the lawn. Hopefully she represents well for our community. (IMG:style_emoticons/default/beerchug.gif)
914werke |
Aug 13 2022, 02:17 PM
"I got blisters on me fingers" Group: Members Posts: 10,946 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I am busy trying to resurrect my car from its protracted slumber...
goal is to drive to RRC~ |
Craigers17 |
Aug 13 2022, 06:43 PM
Senior Member Group: Members Posts: 804 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Drove it about 75 miles, worked on getting the scuff plates mounted on the GT Lid, and installed my new cell phone holder....Thanks! @Johannes !
Root_Werks |
Aug 15 2022, 12:40 PM
Village Idiot Group: Members Posts: 8,484 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Took the 914 to a car show locally on the island. Good turnout, 914 didn't win anything. 356C next to me took third place for German cars.
Fun day, great weather. Attached thumbnail(s) |
mikey63 |
Aug 16 2022, 09:32 AM
Member Group: Members Posts: 126 Joined: 30-March 10 From: Windsor,Ca Member No.: 11,529 Region Association: Northern California |
Got some new plates for the car.
ndfrigi |
Aug 16 2022, 11:33 AM
Advanced Member Group: Members Posts: 2,959 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
CCE |
Aug 17 2022, 07:42 AM
CCE Group: Members Posts: 328 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
Craigers17 |
Aug 18 2022, 03:05 PM
Added an exterior kill switch. Now the grill and side vents have to be primed, painted, and trimmed out.
914 Ranch |
Aug 19 2022, 04:35 AM
I put the rear wing back on the car to run and locate the wires. Once I got the wing in place I ran the wires and used a plastic wire clip with double sided tape to hold it down and led them to the wires coming out of the air box. So I only have 2 connectors in the hole circuit. One at the servo and one at the air box. I need more heat shrink. Pictures after sunrise.
More pictures in my build thread. |
mate914 |
Aug 19 2022, 07:22 AM
Matt Group: Members Posts: 797 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
https://www.youtube.com/watch?v=uow_y-61hxc https://www.youtube.com/watch?v=lTHjHWGmVYk Here my car story That was very nice. Well done. Matt |
Craigers17 |
Aug 21 2022, 08:28 AM
CCE |
Aug 21 2022, 09:32 AM
Cairo94507 |
Aug 21 2022, 12:08 PM
@CCE - Nicely done. Congratulations. (IMG:style_emoticons/default/smilie_pokal.gif)
DRPHIL914 |
Aug 21 2022, 09:23 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
stranded yesterday after cars and coffee, wouldn’t start. fuel pressure was good pump primed, no click or anything at the start position , so figured it was ignition switch, which ended up being correct.
i had just put the tow bar on last week so i got to test it out and towed the car home. pulled the steering, and the switch. Did some research about replacing it. i found that the Pelican article only applies to early cars. More search i found the correct description for a later car. -pull the steering wheel , 27mm socked for steering wheel, pull the switch assembly , first disconnect the wires from the back, then remove the signal and washer wiper lever assembly by removing the 4 small flat head screws. - remove the 6mm hex screw underneath and the whole ignition switch assembly will pull off - oh remove the circlip first inset key and turn to first position this moves the steering lock me hand lets the assembly slide forward, once out off the steering shaft , from behind remove the small screw holding the plastic ignition switch and pull it out the back (key should be back in the off position until new switch is put in and you reinstall the assembly. So props to Jeff Patterson of type4revolution in Pooler/Savannah Georgia , he had a used but like new German 6 pin switch that i was about to go over and get to install today!! i know i’ve seen other threads of others going thru this with the failed cheap switches. anyone able to source a new German switch? Pelican says they have one, al back together Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 26th November 2024 - 12:35 AM |
