what did you do to your 914 today |
DRPHIL914 |
Sep 20 2023, 07:37 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
The hand throttle has a rod that goes to a small pad on the pedal assembly where the throttle rod connects. When you pull the throttle arm up it pushes the attached rod forward and that applies pressure to the throttle pad, like stepping on the gas pedal, and the engine RPM's rise. I have always used them on my FI 6's. (IMG:style_emoticons/default/beerchug.gif) Michael, Ok, excellent, thank you for the clarification so i need to source the rod and the pad to be added to the assembly, some slight modification etc! thanks, Phil |
Shivers |
Sep 20 2023, 09:12 AM
Senior Member Group: Members Posts: 2,781 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
DRPHIL914 |
Sep 20 2023, 10:22 AM
These are all the pieces needed to make it work. Just in case you’re laying it out yourself. Once this tab is in the rest is fairly simple. Cool! that is so much more simple than what i was picturing in my head (IMG:style_emoticons/default/rolleyes.gif) - so i have to find someone to weld the tab on for me OR buy one that is already made- if anyone has one let me know. . |
eric9144 |
Sep 20 2023, 10:52 AM
Advanced Member Group: Members Posts: 2,744 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Registered for ÜnStock (IMG:style_emoticons/default/beerchug.gif)
https://www.pca.org/events/unstock |
DRPHIL914 |
Sep 20 2023, 01:49 PM
Registered for ÜnStock (IMG:style_emoticons/default/beerchug.gif) https://www.pca.org/events/unstock we need one of these on the east coast! Luftgekuhlt is coming east and is having a display event at the Chattanooga Motoring Festival in October, i am registered for that, should be a fun day!!! |
Craigers17 |
Sep 23 2023, 06:34 PM
Senior Member Group: Members Posts: 800 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Pulled the tank in preparation for relocating the fuel pump to the frunk and installing SS fuel lines. There's only minimal rust in the tank, so I'm going to see if the radiator shop will clean it up. Good news is there is still a lot of factory paint under the tank and no rust. If I have time tomorrow, I'll clean it up a bit. I might even install a front sway bar while the tank's out.
Jett |
Sep 24 2023, 08:34 AM
Senior Member Group: Members Posts: 1,670 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Still working on removing the undercoating and getting ready for under car repaint.
Attached thumbnail(s) |
g911 |
Sep 24 2023, 11:06 AM
Member Group: Members Posts: 222 Joined: 13-January 06 From: Not Tellin' Member No.: 5,413 Region Association: None |
VegasRacer |
Sep 24 2023, 03:30 PM
ELVIRA Group: Benefactors Posts: 8,706 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Cleaned and prepped Elvira for our pilgrimage to Rennsport. (IMG:style_emoticons/default/FERG.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smilie_wirdgut.gif)
Michael N |
Sep 24 2023, 04:32 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
Went to a local PCA cars and coffee. The organizer moved the cone to give me front spot parking. (IMG:style_emoticons/default/biggrin.gif)
On the 20 mile ride home the alternator light came on and stayed on regardless of RPM’s. When testing for voltage there is no gain at the battery when car is running at 2k rpm’s. I think the voltage regular or alternator is dead 3 days before Rennsport. I don’t think I can get it fixed prior to Rennsport which is a bummer. Generator bulb was fine. All fuses are good and I think my setup has the voltage regular built in with the alternator. (IMG:style_emoticons/default/headbang.gif) On a brighter note I was able to get it home. Changing battery so I can drive it to the shop this week. |
Shivers |
Sep 24 2023, 07:41 PM
Tough acts to follow. (IMG:style_emoticons/default/smile.gif)
Found this in my parts box, I was bored so I did some work on it. I cleaned, sanded and baked some paint on it. I drilled out the ID of the crank case breather. Some new nuts would look nice. Could someone please ID the size of those nuts for me. Thanks |
mikey63 |
Sep 25 2023, 10:27 AM
Member Group: Members Posts: 126 Joined: 30-March 10 From: Windsor,Ca Member No.: 11,529 Region Association: Northern California |
First annual Cowabunga car show at Hopmunks in Sebastopol.
I was asked to move from the back row to right in front of the main entrance! A little 914 appreciation! Attached image(s) |
DRPHIL914 |
Sep 25 2023, 11:21 AM
Still working on removing the undercoating and getting ready for under car repaint. what did you use to strip off the undercoating? i am going to do the floor pan next, i did the wheel wells and rear trunk area last year, and need to do this and then re-spray and then i am thinking about using raptor liner, are you going to coat it with tintable bed liner or something else? Phil |
Craigers17 |
Sep 28 2023, 01:05 PM
Installed a front sway bar. I'm a little worried about the brake lines rubbing against the shackles, but I'll just have to monitor it for now.
930cabman |
Sep 28 2023, 01:56 PM
Advanced Member Group: Members Posts: 3,697 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Still working on removing the undercoating and getting ready for under car repaint. what did you use to strip off the undercoating? i am going to do the floor pan next, i did the wheel wells and rear trunk area last year, and need to do this and then re-spray and then i am thinking about using raptor liner, are you going to coat it with tintable bed liner or something else? Phil I would love to strip the undercoating, but I am quite sure I won't live long enough (IMG:style_emoticons/default/happy11.gif) |
914sgofast2 |
Sep 28 2023, 02:01 PM
Senior Member Group: Members Posts: 650 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Pulled the tank in preparation for relocating the fuel pump to the frunk and installing SS fuel lines. There's only minimal rust in the tank, so I'm going to see if the radiator shop will clean it up. Good news is there is still a lot of factory paint under the tank and no rust. If I have time tomorrow, I'll clean it up a bit. I might even install a front sway bar while the tank's out. Check the gas tank for rust in the areas where the tank rests on the fabric body pads. I have had 2 tanks rusted out in those areas from the outside of the tank to the inside. I suggest replacing the fabric body pads with sold rubber ones that won't hold moisture and rust out the tank. |
cassmcentee |
Sep 28 2023, 04:58 PM
Member Group: Members Posts: 220 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California |
7 hours spread out over 3 days and...
My first engine drop complete! (IMG:style_emoticons/default/biggrin.gif) |
Jett |
Sep 28 2023, 08:13 PM
Still working on removing the undercoating and getting ready for under car repaint. what did you use to strip off the undercoating? i am going to do the floor pan next, i did the wheel wells and rear trunk area last year, and need to do this and then re-spray and then i am thinking about using raptor liner, are you going to coat it with tintable bed liner or something else? Phil I used many plastic razors, a fixed plastic scraper, and heat gun to get the bulk and then professional strength goof off with chemical mask and good ventilation. The paint shop uses a light texture and paint. Here is a pic of the Palma car to see the texture. Attached thumbnail(s) |
Shivers |
Oct 1 2023, 07:04 PM
Living in the desert, I’ve been obsessed with improving cooling. Since every little bit helps, here is that little bit. And yes I need a hair cut. (IMG:style_emoticons/default/biggrin.gif)
Front yard mechanic |
Oct 1 2023, 08:29 PM
Senior Member Group: Members Posts: 1,229 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Put a new low profile cardboard box under it.
Lo-Fi Version | Time is now: 25th November 2024 - 12:37 AM |
