what did you do to your 914 today |
914 Ranch |
Jun 1 2024, 02:21 PM
Team Sharp where the 914 grow wings Group: Members Posts: 1,443 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
I always like posting things here. So enjoy this picture. The frame works for a diffuser on my 914.
The skin goes on the inside of the frame. The aluminum angles get the strakes attached to them. The hole thing goes from the muffler bracket to the body line that is at the top of where the rubber bumper top was. |
TJB/914 |
Jun 1 2024, 03:36 PM
Mid-Engn. Group: Members Posts: 4,367 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
(IMG:style_emoticons/default/w00t.gif)
Went to a local PCA Rennstatt Rally Sport gathering in Ann Arbor, MI a few weeks ago. i finally got my 914 out of long time storage and it ran perfectly. Another 914 attended and our air cooled 914's were more popular than new water cooled ones. (IMG:style_emoticons/default/popcorn[1].gif) Tom Attached image(s) |
anderssj |
Jun 1 2024, 03:39 PM
Dog is my copilot... Group: Members Posts: 1,696 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
wonkipop |
Jun 2 2024, 12:12 AM
Advanced Member Group: Members Posts: 4,658 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
same here. (IMG:style_emoticons/default/driving.gif) 5th sunday in a row!!!!!! dunno why but autumn/winter down here has been typically chilly but clear skies. stop driving your teslas, i need the climate to remain in this condition for ever. (IMG:style_emoticons/default/beerchug.gif) |
Shivers |
Jun 2 2024, 12:30 PM
Senior Member Group: Members Posts: 2,745 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Just some paint
fiacra |
Jun 4 2024, 01:33 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 425 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Just some maintenance and a few upgrades over the past few days.
- Oil change - Transmission gear oil change - Put in the 914rubber speedo drive gear bushing kit (and stripped out the retaining bolt, but that's the subject of a whole different thread) - Put on the 914rubber reproduction LE front air dam that fits with their tow hitch - New front brakes, rotors, wheel bearings, PMB restored calipers and PMB soft lines - Switched out the Rivieras that came with the car for some decent quality Fuchs that I bought locally from a shop that did a 5 lug conversion on a 914. The have nearly new tires on them and I bought 5 wheels for essentially the price of the tires. Didn't really have the money to spend, but I couldn't pass them up. They look so much better than the Rivieras, which I guess will now go on my Karmann Ghia. Now to start cleaning up the garage..... |
914 Ranch |
Jun 4 2024, 04:24 PM
FlacaProductions |
Jun 4 2024, 05:47 PM
Senior Member Group: Members Posts: 1,767 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
that's a great list of accomplishments, @fiacra - Can you tell me about the brake/rotors/bearings operation? That's on my list for next winter. I have cores that I'm going to send PMB and will get their whole kit - which it sounds like you did as well...
fiacra |
Jun 4 2024, 09:14 PM
that's a great list of accomplishments, @fiacra - Can you tell me about the brake/rotors/bearings operation? That's on my list for next winter. I have cores that I'm going to send PMB and will get their whole kit - which it sounds like you did as well... @FlacaProductions You can't go wrong getting your parts from PMB. I didn't get the "brake bundle kit" but I might for my other car. I think that's a good way to go. Like many of us I have a few shelves full of parts that seem to accumulate over time and a lot of the parts I used came off those shelves. The PMB restored calipers came from another member. The brake lines I bought a while back from PMB as part of a group buy when they first introduced them. The LE air dam I literally bought two years ago and it has been sitting in the box since then. It is embarrassing to look at the shelves full of parts and wonder why I haven't put them on the cars yet. Now that I'm semi-retired it is a goal of mine to work through those piles of parts, and this project was another step in that journey. Other parts came from my friend's shop as he can order them at shop rates and get same day delivery for all the common parts. As far as the actual mechanical work, I did watch Ian's video on replacing the bearings as well as read the manual. If you have done bearings before this will be a piece of cake. If you haven't done bearings before, it will probably still be a piece of cake. I have a selection of different sized drivers for installing the bearing races but I like Ian's recommendation for using the old races to install the new ones. I used Swepco Moly 101 for the bearings. I put the grease in a heavy duty ziploc freezer bag and use it to squeeze the grease into the bearings. It's less messy and works well. My least favorite part of the whole job is working with brake fluid. When you disconnect the brake lines start at the connection from the line coming directly from the master cylinder and use a bleeder cap to cap it off. When reassembling start from the caliper and work your way back, that way you don't have brake fluid coming through the lines as you are trying to reconnect them. Bleeding the brakes is a well acknowledged PITA, but a Motiv pressure bleeder works really well in my experience. I bought one a few years ago and the four times that I've used it have easily made it worth the investment. My wife is kind enough to come in for a few minutes at the end as my last step is always to have someone work the pedal for one quick trip around the wheels for a final manual bleeding. For all of the above it really helps to have a lift of some type, but I have done all of this working on the floor before. The scissor lift really makes things a lot easier though. My apologies if all of this is blather is well below your actual mechanical skill level. There are all levels on this forum, and I'm very much middle of the pack. I have good tools, a place to work, no time pressure, and experts I can consult. You might be one of those experts and all of this is nothing new to you. Hard to tell from your question if this is what you wanted to hear, or you had some specific thing in mind. If you are a novice wrencher this is a project well within your skill set if you take your time and use the right tools. If you have done this before you will cruise through. There is always the inevitable "blip" along the way, such as my stripped speedo gear bushing retaining bolt hole, but there is always someone out there with wise words and a path forward if you get stuck. |
KSCarrera |
Jun 5 2024, 08:07 AM
Member Group: Members Posts: 316 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
Explored the limits of grip on my 914 hillclimber...
https://youtu.be/aijQsPYE878?si=SU88VzGw-0BxT60K |
SKL1 |
Jun 5 2024, 11:25 AM
Senior Member Group: Members Posts: 1,629 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Finally ordering passenger side mirrors for both cars, only took 50+ years to get around to it. My OCD isn't fond of drilling holes in a perfectly good door!!!
VegasRacer |
Jun 5 2024, 11:43 AM
ELVIRA Group: Benefactors Posts: 8,625 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
WOW, looks so much better than I thought it would. I agree, Joe. It looks better without the clothes pins. (IMG:style_emoticons/default/biggrin.gif) |
Chris914n6 |
Jun 5 2024, 01:05 PM
Jackstands are my life. Group: Members Posts: 3,400 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Drained the fuel and stole the pump to put on another car (IMG:style_emoticons/default/hissyfit.gif)
Side note: motor swapped cars are so much easier to work on (IMG:style_emoticons/default/aktion035.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1717614333.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1717614334.2.jpg) |
930cabman |
Jun 6 2024, 01:17 PM
Advanced Member Group: Members Posts: 3,596 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Drained the fuel and stole the pump to put on another car (IMG:style_emoticons/default/hissyfit.gif) Side note: motor swapped cars are so much easier to work on (IMG:style_emoticons/default/aktion035.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1717614333.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1717614334.2.jpg) What pump is this? are you happy with it, FI or carbs |
Geezer914 |
Jun 6 2024, 01:34 PM
Geezer914 Group: Members Posts: 1,718 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Look at Rock Auto Parts, Delphi fuel pump $81.79 75-76 914 FI
burton73 |
Jun 6 2024, 01:45 PM
burton73 Group: Members Posts: 3,658 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Mark picked up the blue boy at PMB. Off to the race track
Best Bob B |
FlacaProductions |
Jun 6 2024, 03:16 PM
That's fantastic!
What was the turn-around time from delivery to finished product? |
Geezer914 |
Jun 6 2024, 03:58 PM
Very nice! Visiting PMB must be like going to a 914 toy store!
Chris914n6 |
Jun 6 2024, 06:28 PM
Drained the fuel and stole the pump to put on another car (IMG:style_emoticons/default/hissyfit.gif) Side note: motor swapped cars are so much easier to work on (IMG:style_emoticons/default/aktion035.gif) What pump is this? are you happy with it, FI Currently listed as a Bosch 69414. When I bought it in 2019 it was a 0.580.464.070. It over specs for a stock motor. Bosch has been combining part applications and upgrading in the process. Good for 200hp and IIRC my 300hp future swap. I'm having a problem with it sucking air bubbles in because it fountains out the return inlet. Not a problem if the fuel level is higher than the top of the sock. Amazon $93 Much nicer pump than the Walbro I originally bought for the 3L, which quit pumping sufficiently. The fact that it sat in e10 for a year and still works is a credit to quality. @930cabman |
L-Jet914 |
Jun 6 2024, 07:21 PM
Member Group: Members Posts: 277 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I finally have had some time to tackle the transmission fluid leak that appeared after I replaced the original axle seals a few years back. I found out that the input shaft seal had finally failed. I have since tore the transmission down to its case and took it to work a few weeks ago and sent it through the heated aqueous parts washer. I have reassembled it with the help of a good friend of mine @Dominic including setting the shift fork clearances and 1st/Rev clearance. I am now tackling the clutch and flywheel replacement. I have installed the new pilot bearing into the new flywheel at the correct depth to allow the felt washer to seat properly. I've removed the extra pilot bearing I found in the crankshaft and installed the spacer that goes into the crank (which I am going to have to use some green Loctite designed for sleeves to hold it in place as it just slides into the crankshaft snout bore instead of having slight resistance on install per Jake Raby's input on the 914World Facebook group. I am figuring out how many shims to add etc. I am going to try and use a tool a coworker is letting me borrow that allows you to use feeler gauges instead of a dial indicator. The increasing heat in my area hasn't been nice to where I can get back out and continue tackling the project. I still have other projects to do on my 74 1.8 but one step at a time.
Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 20th October 2024 - 02:41 AM |
