866 Pages V « < 185 186 187 188 189 > »
rmdinmd
post Feb 22 2014, 03:18 PM
Post #3721
2 weeks ago I added a triple gauge; gas, oil pressure and temperature, I also changed the steering wheel.
I also Installed a third brake light.Attached Image
Today I waxed it and polished the top.
Now I am getting ready to take it out and meet an old girlfriend and take a ride. (IMG:style_emoticons/default/piratenanner.gif) after this last week I deserve to take it out. Attached Image (IMG:style_emoticons/default/wacko.gif)
AfricanHijinx
post Feb 22 2014, 03:34 PM
Post #3722
love that wheel
dangrouche
post Feb 22 2014, 11:38 PM
Post #3723
dangrouche
added voltmeter, yes, I know its only entertainment (vs. ammeter) value only, but at least I know the voltage level.
got the thing for less than two bucks from China from eBay
http://www.ebay.com/itm/161148604200?ssPag...984.m1439.l2649
carr914
post Feb 23 2014, 04:16 AM
Post #3724
Racer from Birth
Went to the Paint Shop yesterday - they told me two weeks ago it would be finished in a week, 10 Days - it hadn't been touched since I last saw it (IMG:style_emoticons/default/mad.gif) WTF
rmdinmd
post Feb 23 2014, 01:33 PM
Post #3725
rekeyed the drivers door so I now can unlock it with a key. didn't dare lock it before as the key only worked the ignition. also cleaned this mess up while I was in there.
Forgot to get an after pic but much better. then lube it and the lock using a PTF dry lube. Passenger side will be another day.
anderssj
post Feb 23 2014, 05:49 PM
Post #3726
Dog is my copilot...
drove it (IMG:style_emoticons/default/smile.gif)
lvnzdrm
post Feb 23 2014, 06:23 PM
Post #3727
Figured out turn signals and 4-way flashers, replaced bulbs in instruments, did a 75 mile drive. This car has been off the road since 1991. It's nice to finally be driving it.
wndsrfr
post Feb 24 2014, 08:26 PM
Post #3728
Changed the fan belt on Kermee, easy to do thanks to the access hatch that Josh installed....also replaced the brake fluid with fresh ATE super blue from my dwindling stash....also easy thanks to speed bleeders.
Shindog1961
post Feb 24 2014, 11:57 PM
Post #3729
Rust removal around the jack points. Prepping my 1.7 engine to start putting it back together.
DRPHIL914
post Feb 25 2014, 07:01 AM
Post #3730
Dr. Phil
I pulled the front calipers , boxed up to ship to PMBPERFORMANCE. Ordering new tie rods and hard lines for the front. I should not be surprised, after doing the rear, I knew most all the suspension parts on this car are original and untouched .
I've never torn into the front suspension before, I need a bit ofhelp . How do you get the front center cap off? Do I just pry it off.? I am taking the rotor off to put my 5-lugs on and dont wnt to bend or break anything!
wndsrfr
post Feb 25 2014, 07:12 AM
Post #3731
I usually go at it with a flat blade screwdriver& tap it with a hammer....second choice is a big pair of channel lock pliers spanning the cap and a few taps with a small hammer to break it loose.
euro911
post Feb 25 2014, 01:14 PM
Post #3732
I work my way around the perimeter with a seal puller
ClayPerrine
post Feb 25 2014, 01:40 PM
Post #3733
I use this:
(IMG:http://www.914world.com/bbs2/uploads_offsite/buy1.snapon.com-1143-1393357221.1.jpg)
Snap-On Dust Cap Tool.
euro911
post Feb 25 2014, 08:09 PM
Post #3734
What are you, Clay? ... a dentist?
poorsche914
post Feb 25 2014, 08:40 PM
Post #3735
T4 Supercharged
QUOTE(euro911 @ Feb 25 2014, 09:09 PM) *
rosenfe
post Feb 25 2014, 08:51 PM
Post #3736
QUOTE(poorsche914 @ Feb 25 2014, 06:40 PM) *
installed a new throttle cable
chads74
post Feb 26 2014, 06:36 AM
Post #3737
Decided she needed a change of scenery, so took her out for a drive.
ClayPerrine
post Feb 26 2014, 04:01 PM
Post #3738
QUOTE(poorsche914 @ Feb 25 2014, 08:40 PM) *
Nope.. that is the Proper Tool for removing dust caps.
ndfrigi
post Feb 26 2014, 06:36 PM
Post #3739
Drove it from 9am to 1pm within orange county (Anaheim, Orange, Fullerton and Cypress) to 2 different Best Buy stores and Fry's Electronics and friends house. First time to drove it on 91 Freeway traffic which I thought I will have problem on my cooling system. Well I got maximum 230 to 235 degrees based on the Thermo dipstick.
And yesterday I was able to clean or remove old paint from this 2 wheels and maybe another 2 tomorrow.
Jetsetsurfshop
post Feb 27 2014, 07:49 PM
Post #3740
Loaded up for a track day.
- Lo-Fi Version Time is now: 20th January 2025 - 10:21 PM
