866 Pages V « < 187 188 189 190 191 > »
carr914
post Mar 2 2014, 02:35 PM
Post #3761
Racer from Birth
Pulled the Spyder off the lift for the 1st time on months, Completed Ball-Joints, Installed Fuchs and played with Spacers, Installed Trunk & Door Seals, Put more SFI RollBar Padding in
anderssj
post Mar 2 2014, 04:29 PM
Post #3762
Dog is my copilot...
drove it (IMG:style_emoticons/default/smile.gif)
Type 47
post Mar 2 2014, 08:56 PM
Post #3763
I adopted a sister...an 88' 944T
I'm having issues with Photobucket, so I can't upload pics.
1stworks
post Mar 3 2014, 03:54 PM
Post #3764
Ran it out. .....
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1393883682.1.jpg)
2.0 d - jet power. (IMG:style_emoticons/default/biggrin.gif)
lvnzdrm
post Mar 3 2014, 04:55 PM
Post #3765
Modified my Bursch Exhaust to look way cooler.... I like it!!!Attached Image Attached Image
euro911
post Mar 3 2014, 05:06 PM
Post #3766
Which pic is the 'after' ?
lvnzdrm
post Mar 3 2014, 05:13 PM
Post #3767
QUOTE(euro911 @ Mar 3 2014, 03:06 PM) *
Top is the after, the bottom was before. It stuck out way too far.
euro911
post Mar 3 2014, 05:17 PM
Post #3768
(IMG:style_emoticons/default/agree.gif) ... looks much cleaner (IMG:style_emoticons/default/smile.gif)
lvnzdrm
post Mar 3 2014, 05:19 PM
Post #3769
QUOTE(euro911 @ Mar 3 2014, 03:17 PM) *
It also added like 50 HP.....Thanks
xperu
post Mar 3 2014, 05:39 PM
Post #3770
TEXAS
QUOTE(Mike Bellis @ Mar 2 2014, 12:24 AM) *
I put some satin paint on a set of Phone dials... Hard to see with the sun going down. These are one year only '86 944 turbo wheels, 16x8, 23mm offset.
Very nice car Mike
ndfrigi
post Mar 5 2014, 02:41 PM
Post #3771
Start cleaning early heat exchanger to replace my 75 H.E.
JStroud
post Mar 9 2014, 09:50 AM
Post #3772
Yesterday got both doors fixed and back on the orange car, the shift rod was rubbing on something in the tunnel, thought it was the clutch tube I installed, turned out to be to long a bolt on the drivers seatbelt, fixed that and put the front bumper on. Now just an alignment. (IMG:style_emoticons/default/driving.gif) then I'll probably sell it. White cars already back from McMark....now just install the -6 and hook everything up.
Today need to move the orange car to the garage and clean up the shop to make room for the 73 914 with steel flares that's coming today....oops.
Jeff
euro911
post Mar 9 2014, 02:27 PM
Post #3773
QUOTE(JStroud @ Mar 9 2014, 07:50 AM) *
Yesterday got ... to make room for the 73 914 with steel flares that's coming today....oops.
Jeff
(IMG:style_emoticons/default/blink.gif)
michael7810
post Mar 9 2014, 03:25 PM
Post #3774
Finished installing new front shocks, balljoints, turbo tie rods, elephant rubber bushings, stock front sway bar, rear shocks and 100lb springs. Fixed the loose breather fittings on the air cleaners, and cleaned her up. Tanking her to the shop on Wed for a 4-wheel alignment then she'll be ready for Route 66 Albuquerque trip in 2 weeks.
DRPHIL914
post Mar 9 2014, 06:35 PM
Post #3775
Dr. Phil
QUOTE(michael7810 @ Mar 9 2014, 05:25 PM) *
Hey, just getting ready to do the ball joints and tie Rods too. Btw. How long did that take? Any tips before I get started?
DRPHIL914
post Mar 9 2014, 07:46 PM
Post #3776
Dr. Phil
Today I finished my A/F gauge wiring , put my center console back and put the backpad back, ready to calibrate the meter, . Anyone have a refubished belly pan?
JStroud
post Mar 9 2014, 09:30 PM
Post #3777
QUOTE(euro911 @ Mar 9 2014, 12:27 PM) *
Jeff
I told you I like to buy cars. (IMG:style_emoticons/default/shades.gif)
Jeff
michael7810
post Mar 9 2014, 09:45 PM
Post #3778
QUOTE(Philip W. @ Mar 9 2014, 05:35 PM) *
I didn't have the ball joint nut tool but a brass drift and hammer worked just fine. I completely removed the A arms since I was doing bushings as well, that made the ball joint replacement easier in a vise. If you're installing turbo tie rods, I found it much easier to remove the tie rod end and slide the boot on the rod before installing. Much easier to fit the boot once the tie rod is in place because you don't have to force the small end of the boot over the large nut at the steering rack.
It took me a day for disassembly, day to clean, paint, and install new bushings and ball joints, and a 1/2 day to reassemble. I also did the shocks and installed a factory front sway bar. Good luck
ndfrigi
post Mar 9 2014, 10:49 PM
Post #3779
Removed muffler and next is to
Remove H.E. To install my SS H.E.
boxstr
post Mar 9 2014, 10:54 PM
Post #3780
New 74 914 at CAMP. Added a NOS front bumper top and chrome front bumper with DD tits.
Craig at CAMP
- Lo-Fi Version Time is now: 20th January 2025 - 06:54 PM
