866 Pages V « < 198 199 200 201 202 > »
crash914
post Apr 15 2014, 10:20 AM
Post #3981
its a mystery to me
re-packed CV joints, fitted up oil cooler, installed both deck lids, ordered new throttle cable for cable throttle linkage.
Now to just tighten bolts on the exhaust, install shift linkage, install battery and turn the key....
The exhaust is the tangerine exhaust...I hope to fire it up shortly..
Qarl
post Apr 15 2014, 10:05 PM
Post #3982
Shriveled member
Catalogued and sorted all the small hardware. Nuts, bolots, washers, screws, speed nuts, special hardware.
Figured out what goes to the players, what I have new, and what I need to order
Edit: Platers, not Players
(IMG:http://www.914world.com/bbs2/uploads_offsite/totallyconfidentandcompletelyinsecure.files.wordpress.com-271-1397657382.1.png)
bulitt
post Apr 16 2014, 05:54 AM
Post #3983
Achtzylinder
QUOTE(nsr-jamie @ Apr 15 2014, 11:14 AM) *
Mostly on the weekend was just driving the car and having some fun crusing around with my Daughter, weather was great here in Japan and the Cherry Blossoums were in full bloom, took a few pics....also some big news for me...I have officially ordered a full custom exhaust from Tangerine Racing.... (IMG:style_emoticons/default/evilgrin.gif) (IMG:style_emoticons/default/evilgrin.gif) (IMG:style_emoticons/default/evilgrin.gif) Can't wait !!
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.dreamgate.ne.jp-8305-1397574846.1.jpg)
Are there many 914's in Japan?
carr914
post Apr 16 2014, 06:15 AM
Post #3984
Racer from Birth
QUOTE(crash914 @ Apr 11 2014, 05:42 PM) *
Exhaust is the Tangerine by Chris Foley....no sound yet, I hope to fire it up this weekend...got to finish the stuff below first...it might run, but not long...
Personally, I wouldn't want to have a 90 Degree Fitting (or 2) between my Stat and the Filter Console
crash914
post Apr 16 2014, 07:18 AM
Post #3985
its a mystery to me
I agree, it is reworked..I just had the fittings stuck in to keep them from getting lost....I will most likely rework it a few times until i get what I want...Fittings are only $20 each....
minndodger
post Apr 16 2014, 07:38 AM
Post #3986
I just stare at my car and weep since I live in Minnesota and it is going to snow today. This weather (IMG:style_emoticons/default/stromberg.gif)
post Apr 16 2014, 08:04 AM
Post #3987
Modified the access cover to accept the cables.
euro911
post Apr 16 2014, 11:43 AM
Post #3988
Drove the 'BB' to my chiropractor appt. on Monday.
Drove it to the shop yesterday. Crated up the 2L motor I sold to Denis. Will be on it's way back to Maryland soon.
Now, on to check compression on a 2.7L.
Johny Blackstain
post Apr 16 2014, 11:44 AM
Post #3989
Cold, crisp & sunny day here in Virginia today, so I drove the LE (IMG:style_emoticons/default/biggrin.gif) Damn it was fun.
poorsche914
post Apr 16 2014, 12:12 PM
Post #3990
T4 Supercharged
QUOTE(Johny Blackstain @ Apr 16 2014, 01:44 PM) *
Keep on driving and she'll be ready for the trip to the Smokies this fall (IMG:style_emoticons/default/shades.gif)
ndfrigi
post Apr 16 2014, 12:20 PM
Post #3991
Drove it to Costco and stater bros to picked up wife various food supplies.
MartyYeoman
post Apr 16 2014, 01:03 PM
Post #3992
Valve adjust and fuel injection wiring repair.
It's happy now! (IMG:style_emoticons/default/smilie_pokal.gif)
boxsterfan
post Apr 16 2014, 01:22 PM
Post #3993
914's are kewl
QUOTE(Marty Yeoman @ Apr 16 2014, 12:03 PM) *
How's your 2056 coming? Let me know if you need an extra pair of hands.
wndsrfr
post Apr 16 2014, 02:19 PM
Post #3994
QUOTE(Johny Blackstain @ Apr 16 2014, 09:44 AM) *
Drive it over to Summit Point this Friday/Saturday....two teeners registered for PCA DE there. I'm driving Kermee.... (IMG:style_emoticons/default/driving.gif)
Johny Blackstain
post Apr 16 2014, 04:00 PM
Post #3995
QUOTE(wndsrfr @ Apr 16 2014, 04:19 PM) *
I'd love to, especially since it's only 1hr away, but I'm stuck @ home putting new tires on the Kubota, doing spring yard/house work & taking care of the neighbors dogs while they're away for Easter.
(IMG:style_emoticons/default/sad.gif)
euro911
post Apr 16 2014, 05:25 PM
Post #3996
Installed the front plate on the 'BB' and had the CHP sign off on the ticket.
CHP doesn't charge to verify the correction, local PD wants $25.
If correction is signed off, the original fine ($38.) is reduced down to $10. (IMG:style_emoticons/default/smile.gif)
Worked on one more MBZ wheel for the Westy
Before:
After:
Two more to go ...
DRPHIL914
post Apr 17 2014, 01:12 PM
Post #3997
Dr. Phil
QUOTE(Philip W. @ Apr 13 2014, 05:53 PM) *
Painting my fuchs. This is the first ones. I think its working out well. Using a pouring technique, similar to the dipping technique that was originally done.
so an update on this project. it worked , and really look great, but it takes a while to cure, and i should have thinned the enamel paint for it to flow easier, and to drain out and not be so thick. I made the mistake of "testing it " in several locations, one spot was a bit soft, not fully cured yet. this was the spare so i have 4 to go. SO on the next one i will thin it a bit, and i bought a hardener, that will accelerate the curing process and helps to actually speed the process and make it much harder, but does not hurt the bonding.
Qarl
post Apr 17 2014, 02:37 PM
Post #3998
Shriveled member
Prepped my GT Oil cooler shroud. Made the mounts for the Setrab cooler to the shroud.
I also patched up a previous hole on the opposite side of the shroud when I originally intended to run the oil lines on the passenger side.
Now that I'm going on the driver's side (GT-style), I had to patch the 2 holes I drolled on the opposite side!
Pics to come later.
Steve
post Apr 17 2014, 04:51 PM
Post #3999
All ready to be put back into the car.
New fuel lines and 916 Trans.
Rods914
post Apr 17 2014, 05:24 PM
Post #4000
Rods914
With the engine still in the car I replaced the two rubber seals on the Oil Cooler! What a pain! But it is done and no more leaks! (IMG:style_emoticons/default/biggrin.gif) Attached Image
- Lo-Fi Version Time is now: 20th January 2025 - 01:50 AM
