euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
looked at it, dusted it, took my sunglasses out of it this morning. would be perfect weather (72) in the morning to drive to work but that "no commuting" clause from Hagarty holds me back ( so i drove the Boxster with the top down (IMG:style_emoticons/default/sunglasses.gif) ... I wouldn't consider driving to work every now and then "commuting" - to me, commuting is pretty much driving it every day. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,596 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Got this for the six...
![]() Tuned Muffler for MFI engine to replace the one I have on there. It's leaking due to rust. |
eyesright |
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region ![]() |
Three pairs of rebuilt visors from 914rubber came in today's FedEx delivery. Installed the first and need to get some mounting screws from Lowe's for the other two.
eyesright |
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
looked at it, dusted it, took my sunglasses out of it this morning. would be perfect weather (72) in the morning to drive to work but that "no commuting" clause from Hagarty holds me back ( so i drove the Boxster with the top down (IMG:style_emoticons/default/sunglasses.gif) - might need to reconsider my insurance coverage so i can drive it to work once and a while--might have to if i sell the boxster, since the wife totalled her jag i might need it a s the down payment on a newer model car(got my eye on a low milage E350 mercedes-very nice) I use American Collectors Ins., not as restrictive as Hagerty, stated value, mileage per year is tiered, give them a call. thanks for the tip, i will! I agree; American Collectors is great. Have it for my 914 & 944 and total is $300/year and not hassles. |
Matt Romanowski |
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 ![]() |
Updated the firmware in the dash, figured out where to put the IR tire and brake temps sensors, and searched for the small oil leak.
1stworks |
Member ![]() ![]() Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None ![]() |
jrrhdmust |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,402 Joined: 12-October 11 From: Alabama Member No.: 13,668 Region Association: None ![]() |
Sanded and painted under the dash and the center tunnel
hndyhrr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 563 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() ![]() |
took out pedal cluster ...... took it to machine shop to have pin drilled out. drill bites at my house wouldn't cut melted butter and machine shop is closer than drill bit store.
crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
adjusted the valves, adjusted the throttle cable, installed new sway bar bushings...
Oil change tonight....then race it! |
TJB/914 |
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,341 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest ![]() ![]() |
Took off my Ceramic Coated 2.0 liter Bursch Muffler on my 1974 914 F.I. garage queen and installed my new Ceramic Coated Triad Muffler.
Love the sound. (IMG:style_emoticons/default/first.gif) Tom Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() |
Alphaogre |
Member ![]() ![]() Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California ![]() |
So are those triad mufflers a muffler in the lower part and resonators on the upper part? Or is that just a larger diameter for the upper part?
crash914 |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,170 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
Figgered out why my brights only were working without problem and lows intermittently (IMG:style_emoticons/default/confused24.gif) turned ut to be the relay. Opened it up and adjusted the metal tab inside. Pretty cool stuff in there. Anyway, it works now and I learned sumpin' new. (IMG:style_emoticons/default/aktion035.gif)
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I put mine up on jack stands and started building a jig to hold the engine in position.
(IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) |
ovilla |
Member ![]() ![]() Group: Members Posts: 84 Joined: 25-February 05 From: Plainfield, IL Member No.: 3,660 ![]() |
Solved my no-start issue on my 75 2.0. Replaced my cracked ignition swith with a new one and also installed a Pertronix II. She idles and drives oh so beautifully now.
t collins |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None ![]() ![]() |
Drove it over to Backbone Rock and down the Snake
nsr-jamie |
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None ![]() |
Entered into a local car show
Attached image(s) ![]() |
t collins |
Lo-Fi Version | Time is now: 1st July 2024 - 02:51 AM |
