866 Pages V « < 234 235 236 237 238 > »
JStroud
post Sep 11 2014, 07:34 PM
Post #4701
Started tearing down the 2.7 today, got the head assembly off one side. Pulled the cylinders to see if I could reuse them.......not (IMG:style_emoticons/default/headbang.gif) one is a Mahle, the other two KS, all Alusil, all with nice gouges.....no wonder it was burning oil (IMG:style_emoticons/default/blink.gif)
Soooooo I guess I need new P/C.....there goes my rebuild budget!!!
euro911
post Sep 11 2014, 08:22 PM
Post #4702
QUOTE(matthepcat @ Sep 11 2014, 03:39 PM) *
Decided to powdercoat instead a silver with gloss clear. Just coming out of final cure
(IMG:http://www.914world.com/bbs2/uploads_offsite/s24.postimg.org-11125-1410475166.1.jpg)
Good decision, the wheels look really nice (IMG:style_emoticons/default/aktion035.gif)
Well, almost finished up with the front yard project. May not look like it was a big job from the pic, but it took my friend (Mark) and I 5 full days de-rooting (hate magnolia tree roots) and installing a new sprinkler system. We filled 6 35-gallon trash barrels with roots and installed a 4-zone sprinkler system with 18 heads.
Wife is happy and this little honey-doo has earned me at least a couple of weeks to goof around with some automotive stuff (IMG:style_emoticons/default/mueba.gif)
I'll eventually get another muffler tip for the banana, and I'll run a sheet metal screw to secure it next time (IMG:style_emoticons/default/idea.gif)
post Sep 12 2014, 11:31 AM
Post #4703
Resident German
Looked at it (IMG:style_emoticons/default/shocked[1].gif) this morning ...
ndfrigi
post Sep 12 2014, 12:21 PM
Post #4704
Removed tarp cover and wash it a little bit. Thinking of starting this project.
bandjoey
post Sep 12 2014, 01:29 PM
Post #4705
bandjoey
Got a new drivers seat upholstry kit in the mail. Let's see how long before I get it on (IMG:style_emoticons/default/biggrin.gif)
JStroud
post Sep 12 2014, 03:40 PM
Post #4706
Got the other side taken apart today, seems all the pistons on this side were hitting the exhaust valves, no visible damage to the heads, but all three had small marks in the piston tops, also #6 has a broken ring, a chunk of piston missing and quite the gouge in the cylinder wall. Guess that's why it broke down at Parade. (IMG:style_emoticons/default/blowup.gif)
Found most of the ring pieces, not sure where the chunk of piston went.
Can't wait to see what I find when I split the case.
KaptKaos
post Sep 12 2014, 09:15 PM
Post #4707
Family
Rear brake pads swapped out.
Small problem tho.... see my thread: http://www.914world.com/bbs2/index.php?showtopic=242541
Advice appreciated! And no, unfortunately, a new set from Eric aren't in the cards right now. (IMG:style_emoticons/default/sad.gif)
Phoenix914
post Sep 13 2014, 05:58 AM
Post #4708
Discovered my ignition switch is cracked.
Hopefully, it explains the starting problems I've been having. Don't know why I didn't think of it sooner.
cary
post Sep 13 2014, 09:21 AM
Post #4709
Started a 10 day staycation yesterday.
So yesterday, I finished the hose plumbing on my new 2 port fuel pump relocation. And sprayed some RustOleum on my new battery tray.
Was about ready to drop in the gas tank when I decided to turn the outlet pipes on the tank 180 degrees. stripped one of the threads taking it off.
Black stuff in the hell hole is seam sealer. Decided to add some to that flange lip.
It got it painted later in the afternoon.
Today I'll will be running new fuel pump wires in the tunnel from the back. PO had them under the car in a fuel hose. Been that way for ten years. Time to get it done right.
Plus finish up prepping the 911 for tomorrows PCA AX at PIR in PDX. Just finishing up installing a Seines Shift Kit on it. That is a pretty cool gadget.
Beeliner
post Sep 13 2014, 11:16 AM
Post #4710
QUOTE(cary @ Sep 13 2014, 07:21 AM) *
Day 3, Spray more RustOleam on battery tray....
Day 4, Spray more RustOleum on battery tray....
Day 5, .............
rmdinmd
post Sep 13 2014, 02:28 PM
Post #4711
yesterday I adjusted my valves and installed the red rear reflector and covered up the holes in the rear.
before picture
after picture
Today I fixed the gasket leak on the carbs and then tuned them in. Air leak was from when I had to replace fan because of me. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
My first time adjusting carbs, used the syncometer. AF running around 11 to 12 at idle arounf 1000 RPM.
now to take it for a test (IMG:style_emoticons/default/driving.gif)
monkeywrench
post Sep 13 2014, 03:40 PM
Post #4712
Going to install flywheel, clutch and rebuilt trans
Trying not to be intimidated
abnrdo
post Sep 13 2014, 06:38 PM
Post #4713
Looked at it......still have a lot to do.
Mblizzard
post Sep 13 2014, 07:21 PM
Post #4714
Installed Chris Foley's oil pressure relief assembly. Super easy and seeing lower temps.
euro911
post Sep 14 2014, 12:58 AM
Post #4715
My neighbor Kim finally got his kart project running after working on it on and off for about 4 years. Moves pretty good with the little MAC motor (IMG:style_emoticons/default/aktion035.gif)
I grabbed a sheet of foam out of my shed and made a temporary seat for it
It looks just like the first kart one of my brothers gave me for Christmas when I was 10 or 11. Loads of fun (IMG:style_emoticons/default/smile.gif)
SKL1
post Sep 15 2014, 08:28 PM
Post #4716
Got my '73 restoration project running this afternoon for the first time during reassembly. Moved under its own power for the first time in 4 years!! Gotta get the rear suspension to settle some now...
BTW, I've got my old Simplex Challenger go-kart (which I got in 1961!) and recently found a rebuilt West Bend 580 just like it had way back when. Gonna restore the kart someday as well!!
SKL1
post Sep 15 2014, 08:52 PM
Post #4717
Ran under its own power for the first time in 4-5 years!! Got some major brake bleeding to do- glad I wasn't going very quickly or very far!!
Obligitory picture of maiden 30 foot voyage...Attached Image
post Sep 15 2014, 09:35 PM
Post #4718
Resident German
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/driving.gif)
cary
post Sep 16 2014, 09:16 AM
Post #4719
On staycation. Finally getting to play with my cars.
Stopped at the dealership to pickup a couple shift knob crush sleeves. Ran into Mark (914 Rubber). Had a good chat.
1st. I rehosed the fuel lines on the engine. Installed Chris's FI elbows. They are a thing of beauty. Hose to the regulator might be a tad short.
2nd. Rewiring the fuel pump. Built a taped up 2 wire cable to feed thru the tunnel.
That's were I'll start this am. After I pickup the Nissan spindle nuts to tidy up the fuel tank threads. Plus stop a NAPA for more fuel line and fuel injection hose clamps.
Porsche930dude
post Sep 16 2014, 09:15 PM
Post #4720
QUOTE(SKL1 @ Sep 15 2014, 10:28 PM) *
Those old Karts are very cool but pricey! I just sold a basket case west bend 700 off a weed wacker for $300. (IMG:style_emoticons/default/screwy.gif) now i can buy like 5 brand new weed wackers (IMG:style_emoticons/default/laugh.gif)
What did I do to the 914 today? Thought about driving it before the battery goes flat. (IMG:style_emoticons/default/blink.gif)
- Lo-Fi Version Time is now: 17th January 2025 - 08:03 AM
