what did you do to your 914 today |
DRPHIL914 |
Dec 8 2014, 10:23 PM
Dr. Phil Group: Members Posts: 5,811 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Put it on a trailer. Headed to the shop tomorrow. Got it started long enough to get up on trailer but it took 3 tries, could not keep it running kept dying would not stay idling at all. I am sure that George will figure it out, just hope it's not too many G.W's!!.
mgp4591 |
Dec 8 2014, 10:36 PM
914 Guru Group: Members Posts: 5,529 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
This morning I was able to do some prep work for my 71 1.7 rear suspension console installation and I cut a piece of metal for repair and was able to take a picture of the inside just below the "hell hole". Atleast not that bad looking! You might think about spraying some of Eastwood's 'Rust Encapsulator' in that long before you button it up (IMG:style_emoticons/default/idea.gif) ... and in the driver side too (IMG:style_emoticons/default/confused24.gif)I'm looking at a similar repair- how much cleaning do you have to do to use the Eastwood product and make it work? Just blowing it out and a little vacuum work? (IMG:style_emoticons/default/confused24.gif) |
euro911 |
Dec 8 2014, 11:22 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
"Internal frame coating is formulated to convert and encapsulate the rust INSIDE your frame. Our formulation also incorporates zinc phosphate to further protect the metal from future corrosion. The viscosity is stabilized to assure proper flow and penetration to the existing corrosion and will yield complete coverage when sprayed with the included "conical nozzle". Easy to use and perfect for rust proofing, this must-have product is aerosolized to simply spray the entire inside of the frame with the supplied extension tube and "conical nozzle" for complete coverage and elimination of the rust for years of protection."
For more info, Click here (IMG:style_emoticons/default/shades.gif) |
ndfrigi |
Dec 9 2014, 12:45 AM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
This morning I was able to do some prep work for my 71 1.7 rear suspension console installation and I cut a piece of metal for repair and was able to take a picture of the inside just below the "hell hole". Atleast not that bad looking! You might think about spraying some of Eastwood's 'Rust Encapsulator' in that long before you button it up (IMG:style_emoticons/default/idea.gif) ... and in the driver side too (IMG:style_emoticons/default/confused24.gif)Yes Sir Mark i already have the Eastwood internal frame coating and that is I will be doing next following the welding of new suspension console with one of our members help by next week. Thanks again! |
bulitt |
Dec 9 2014, 06:33 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
mgp4591 |
Dec 10 2014, 07:13 PM
This morning I was able to do some prep work for my 71 1.7 rear suspension console installation and I cut a piece of metal for repair and was able to take a picture of the inside just below the "hell hole". Atleast not that bad looking! You might think about spraying some of Eastwood's 'Rust Encapsulator' in that long before you button it up (IMG:style_emoticons/default/idea.gif) ... and in the driver side too (IMG:style_emoticons/default/confused24.gif)Yes Sir Mark i already have the Eastwood internal frame coating and that is I will be doing next following the welding of new suspension console with one of our members help by next week. Thanks again! Okay, now another Eastwood related question... I've still got the paper heating tubes in my longs and it makes sense that they need to come out to use this stuff. Any suggestions on the easiest way to do this? (IMG:style_emoticons/default/confused24.gif) |
bakerj |
Dec 10 2014, 07:50 PM
Newbie Group: Members Posts: 22 Joined: 28-August 14 From: central IL Member No.: 17,833 Region Association: Upper MidWest |
Fished hose that goes from spare to washer bottle out from under gas tank.
Filled washer fluid ....Check Filled spare tire... Check Hooked up hose to tire...Check Hooked up hose to washer bottle...Check Heard what sounded like a snake hissing inside the car... Found a few cups of washer fluid leaking out of dashboard onto Floor (IMG:style_emoticons/default/wacko.gif) |
euro911 |
Dec 10 2014, 08:31 PM
Okay, now another Eastwood related question... I've still got the paper heating tubes in my longs and it makes sense that they need to come out to use this stuff. Any suggestions on the easiest way to do this? (IMG:style_emoticons/default/confused24.gif) Not an easy task to remove those tubes, unless you're removing the outer longs anyway. If not, remove your seat(s), then pull the interior carpet up from long(s) and remove the the oval inner rubber plugs (2 each side) to gain access into the long(s). I'd suggest spending the $ for a good inspection camera (HF has one for approx $200.) and look at the innards to see where the best place(s) to thread the spray wand in through the long. You'll probably need to run through and spray multiple times to cover all the surfaces. Thread the spray wand in and then look with the camera again to be sure you know which side of the tube you're threaded through. After letting the first pass dry, insert the camera again to see how much you got covered. Spray again as needed, until all four surfaces inside the long(s) have been treated. If you have the shift lever, shift rod, cables and wiring, etc. out of your tunnel area, it's a good time to spray in there too. |
mgp4591 |
Dec 10 2014, 08:45 PM
Okay, now another Eastwood related question... I've still got the paper heating tubes in my longs and it makes sense that they need to come out to use this stuff. Any suggestions on the easiest way to do this? (IMG:style_emoticons/default/confused24.gif) Not an easy task to remove those tubes, unless you're removing the outer longs anyway. If not, remove your seat(s), then pull the interior carpet up from long(s) and remove the the oval inner rubber plugs (2 each side) to gain access into the long(s). I'd suggest spending the $ for a good inspection camera (HF has one for approx $200.) and look at the innards to see where the best place(s) to thread the spray wand in through the long. You'll probably need to run through and spray multiple times to cover all the surfaces. Thread the spray wand in and then look with the camera again to be sure you know which side of the tube you're threaded through. After letting the first pass dry, insert the camera again to see how much you got covered. Spray again as needed, until all four surfaces inside the long(s) have been treated. If you have the shift lever, shift rod, cables and wiring, etc. out of your tunnel area, it's a good time to spray in there too. All that stuff is out as I'm replacing floors too so I'll get all that. I've got a borescope so I'll check all the sides in the long. I'm not gonna use the heating tubes anyway so I thought I'd remove them but it looks like a pita. Still be nice to get rid of them... |
ndfrigi |
Dec 11 2014, 01:44 PM
eric9144 |
Dec 11 2014, 02:18 PM
Advanced Member Group: Members Posts: 2,760 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Took mine over to AAA to double the agreed value on my classic car policy...then came home an reinstalled my rain tray for the harsh San Diego winter weather (IMG:style_emoticons/default/av-943.gif)
ndfrigi |
Dec 11 2014, 02:34 PM
Took mine over to AAA to double the agreed value on my classic car policy...then came home an reinstalled my rain tray for the harsh San Diego winter weather Hi sir, just wondering how much did AAA valued your classic insurance? I'm a AAA member for several years but last 2012 I'm paying around $200 with AAA along with my multiple discounts. I did'nt get full comprehensive before. But last year I move my '75 914 to Hagerty and I only pay less than $200 with comprehensive and guaranteed coverage of $15k. |
Cairo94507 |
Dec 11 2014, 04:07 PM
Michael Group: Members Posts: 10,175 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
eric9144- Beautiful car! (IMG:style_emoticons/default/smilie_pokal.gif)
Dec 11 2014, 04:18 PM
Resident German Group: Admin Posts: 41,975 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
RAIN is coming! Got her tucked away under Amoy's awesome car cover! (IMG:style_emoticons/default/smile.gif) Attached image(s) |
ndfrigi |
Dec 11 2014, 04:23 PM
RAIN is coming! Got her tucked away under Amoy's awesome car cover! (IMG:style_emoticons/default/smile.gif) wow nice! Sir is that cover for 914 body? do you have the web site that I can check? thanks! |
Dec 11 2014, 04:29 PM
wow nice! Sir is that cover for 914 body? do you have the web site that I can check? thanks! Yes, it's specifically for the 914, but it's a custom made one off that my girlfriend made for me a while ago. (IMG:style_emoticons/default/wub.gif) |
ndfrigi |
Dec 11 2014, 04:36 PM
wow nice! Sir is that cover for 914 body? do you have the web site that I can check? thanks! Yes, it's specifically for the 914, but it's a custom made one off that my girlfriend made for me a while ago. (IMG:style_emoticons/default/wub.gif) Oh okay thanks for responding! |
euro911 |
Dec 11 2014, 05:25 PM
wow nice! Sir is that cover for 914 body? do you have the web site that I can check? thanks! Yes, it's specifically for the 914, but it's a custom made one off that my girlfriend made for me a while ago.(IMG:style_emoticons/default/wub.gif) What material did Amoy use to make it Andy? Is it really water-proof? I drove the 'BB' down to Automeister to visit 'Eileen' yesterday. Dropped off a set of front disc pads since they still had her up on the lift. Randy replaced one CV joint, all four CV boots, both rear slave cylinders and rear shoes. Engine analysis is next on the list. For now, the 'BB' is sitting out front under one of Perry's umbrella covers until the storm passes (IMG:style_emoticons/default/dry.gif) I'm thinking about fabricating some water deflectors for under the engine compartment's side grilles, that will channel some water into the side funnels (IMG:style_emoticons/default/idea.gif) |
eric9144 |
Dec 11 2014, 06:17 PM
Took mine over to AAA to double the agreed value on my classic car policy...then came home an reinstalled my rain tray for the harsh San Diego winter weather Hi sir, just wondering how much did AAA valued your classic insurance? I'm a AAA member for several years but last 2012 I'm paying around $200 with AAA along with my multiple discounts. I did'nt get full comprehensive before. But last year I move my '75 914 to Hagerty and I only pay less than $200 with comprehensive and guaranteed coverage of $15k. This year it was a whopping $89 for $12k in agreed value---I'd jumped on NADA the other day and 914 values are up so much I went in so they'd re-evaluate, I'm attempting to get it closer to double that (IMG:style_emoticons/default/beerchug.gif) Now if they'd only do the classic policy on motorcycles (IMG:style_emoticons/default/dry.gif) |
Dec 11 2014, 06:32 PM
What material did Amoy use to make it Andy? Is it really water-proof? Yes, it's water proof outdoor fabric. It's not the flimsy "coated" tent fabric, it is heavier than that and completely water proof. (IMG:style_emoticons/default/pat.gif) |
Lo-Fi Version | Time is now: 16th January 2025 - 11:47 PM |
