862 Pages V « < 287 288 289 290 291 > »
03blueboo
post Apr 8 2015, 08:24 PM
Post #5761
QUOTE(altitude411 @ Apr 4 2015, 11:16 PM) *
took every last bolt thing off including paint. (IMG:style_emoticons/default/evilgrin.gif)
The door handle is still on. (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis
post Apr 8 2015, 08:56 PM
Post #5762
Resident Electrician
I fixed my broken vacuum line to my boost solenoid. It was causing a 30psi boost spike. (IMG:style_emoticons/default/happy11.gif)
sdoolin
post Apr 9 2015, 06:26 AM
Post #5763
Fixed my no-start issue. Determined I had no fire/spark so cleaned tranny ground strap, cleaned battery terminals and cables, checked elec. connections at coil, checked all plug wires, cleaned and re-gapped points, replaced rotor.
Started right up.
stuttgart46
post Apr 9 2015, 06:53 AM
Post #5764
Welded in Patrick Motorsports stiffening kit.
john_f
post Apr 9 2015, 03:56 PM
Post #5765
Just drove it round the South Devon Coast today. Stopped at Slapton for an ice cream & a photo.Attached Image
euro911
post Apr 9 2015, 05:21 PM
Post #5766
Nice (IMG:style_emoticons/default/smile.gif)
I don't dare let my wife see that pic, else she'll be wanting a 5-lug conversion (IMG:style_emoticons/default/headbang.gif)
lonewolfe
post Apr 9 2015, 05:39 PM
Post #5767
QUOTE(john_f @ Apr 9 2015, 02:56 PM) *
That's a beautiful car! Are those 6x15 Fuchs?
john_f
post Apr 10 2015, 03:22 AM
Post #5768
They're certainly Fuchs. Tyre size is 205/60 R15 (Yokohamas) Diameter is 15". Not sure of the actual wheel width.
Thanks for the compliments!
DRPHIL914
post Apr 10 2015, 11:02 AM
Post #5769
Dr. Phil
----...exactly nothing, because i am with out wheels at the moment! i have a set of 16X6 and 7's that my friend and mechanic Mr. Bob Woodman is pulling off of his '74 DE car for me to do a test fit to make sure the 7's will work- if allgoes well, i should have my newly refurbished fuchs in about a month!
falcor75
post Apr 11 2015, 12:10 PM
Post #5770
Started threading the wiring harness back into the car, had the rear ends threaded thru the new snorkle with about 4 inches to go when it split open and was trash.
Then decided to tackle the airbox reinstall, got it back in place but but to slightly elongate the mounting holes in the brackets to get it to fit with the new top seal and mesh.... Then when threading the front harness back I found a damaged wire that the company that just has restored the harness missed.....wonder what else they missed... (IMG:style_emoticons/default/sad.gif) I so need to split some firewood and drink beer right now...
Porschef
post Apr 12 2015, 02:41 PM
Post #5771
How you doin'
Removed the top off and took her out with my daughter for a short shakedown prior to Friday's Hershey run. With the oil cooler installed, temps were right at 205-210. (IMG:style_emoticons/default/smile.gif) That's a relief... Had bled the brakes last week and that made a nice improvement in pedal feel, and overall braking. The swill that came out was pretty nasty.
The fuel pump is a question tho, it's buzzing and gently squealing at times but a quick run up to 95 gave no indication of any fuel starvation. I think that was the only time my daughter looked up from her cell phone... (IMG:style_emoticons/default/dry.gif)
post Apr 12 2015, 02:51 PM
Post #5772
Resident German
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/w00t.gif)
lonewolfe
post Apr 12 2015, 03:39 PM
Post #5773
QUOTE(Porschef @ Apr 12 2015, 01:41 PM) *
Boy, that last comment about your daughter sure sounds familiar. Sounds like me talking about my daughter! Ha ha!
Porsche930dude
post Apr 12 2015, 04:22 PM
Post #5774
Took it out of winter hibernation and cleaned it up. I have a few extra tops so I painted one checkerd and tried it on. I probrobly wouldnt run it all the time but it looks good if the mood is right. Now iv got to figure out why its not charging
euro911
post Apr 12 2015, 05:20 PM
Post #5775
QUOTE(Porsche930dude @ Apr 12 2015, 03:22 PM) *
... Now iv got to figure out why its not charging
It's the top (IMG:style_emoticons/default/slap.gif)
You've created a paradox, with unequal number of opposing colored squares linearly vs. laterally. The protons and electrons are bombarding each other, rather than flowing uniformly in one direction. (IMG:style_emoticons/default/idea.gif)
Put the other top back on and see if that helps (IMG:style_emoticons/default/poke.gif)
Maltese Falcon
post Apr 12 2015, 06:05 PM
Post #5776
...took a break from the 914 chores and went over to Santa Anita Park for a short 20 minute parking lot autocross. $70.00 , your choice of super car; Lamborghini, Ferrari, 997 turbo.
I drove the Porsche , left it in second, and used the dirty gravelly tarmac to whip the back end out, and get some good thrills. The Italian stallions were running hot and slow...good choice on the P car (IMG:style_emoticons/default/driving.gif)
Maltese Falcon
post Apr 12 2015, 06:07 PM
Post #5777
...even had the optional balderelli tire option !Attached Image
ndfrigi
post Apr 12 2015, 06:09 PM
Post #5778
Hi, can you share on a separate thread your oil cooler installation and type of cooler? Thanks!
r_towle
post Apr 12 2015, 06:17 PM
Post #5779
Custom Member
I took the car cover off the 911 and laid it on top of the 914. So technically I did something to the 914 today.
Mike Bellis
post Apr 12 2015, 07:58 PM
Post #5780
I fixed all the damage to my trailer so I can tow the 914 to WCR.
This is for Murphy's law. If I have the trailer, it will not need to be towed...
- Lo-Fi Version Time is now: 19th December 2024 - 09:23 AM
